Meselson-Stahl experiment banding patterns across replication hypotheses
  • Thread starter Thread starter SAT2400
    Experiment
1 reply · 2K views
SAT2400
In the Meselson-Stahl experiment, which banding pattern expected by which hypothesis/es would be the same?
A. A single, medium-density band after the first replication is expected by both the semi-conservative and the dispersive hypotheses.
B. A single, medium-density band after the second replication is expected by both the semi-conservative and the conservative hypotheses.
C. Two bands (one high-density, one low density) after the first replication is expected by both the semi-conservative model and the conserviative models
D. Two bands after the first replication are expected for both the conservative and the dispersive hypotheses.
E. None of the above.
I think it's C, but my friend said it's A...
Please help! Thank you!
Could you explain why you think your answer is right?
More generally, what should happen after each replication (first, second) under each of the three hypotheses? That's only 6 things, you should be able to do that in one post.
