Method of sections for truss member force
  • Thread starter NoobeAtPhysics
    Truss
2 replies · 3K views · last reply
NoobeAtPhysics
The truss is suspended by two pin joints. Each segment is 3 m wide and 4 m high. The applied force is F = 1 N. What is the force in member 2?
Truss diagram of a row of seven triangular panels with members numbered 1 to 14, a downward force F arrow on the right end, and pin supports at the left end.
Sum of force = 0
Using method of sections (to get force at 3), so taking the right portion
I am trying to understand the sum of the force in the y direction of the section.
sum of force y of portion =0 =-1 - J_3 cos(180-arctan(3/4))
My question, do we use 180-angle when looking at the angle,
also is it negative J_3, since the J_3 is pointing downwards?
I already know that the answer is 1N, I just don't understand this part.
Thank you.
I think you are looking for force in 3 by cutting right hand section thru 12,3, and 9? Forget about signs plus or minus from trig. You know that F acts down, so the vert force in 3 must act up, pushing in towards the member. Pushing forces are compression forces, usually designate as negative. Tension forces are positive. Use the properties of a 3-4-5 right triangle to get the compressive force in member 3.
