Method of storing energy on the Moon
Al_
TL;DR
This article: https://phys.org/news/2026-01-lunar-nights-martian-storms-batteries.html says batteries are problematic in space. I propose a flywheel.
Batteries bad
The article linked above says batteries are problematic in space. I propose a flywheel, which is suited to the Lunar environment. 1) It is in vacuum already. 2) Magnetic suspension is less demanding in 1/6 gravity. 3) Superconductors need very low temperatures which are easily available 4) Craters provide ready-made disintegration safety containers 5) Local resources can be used to manufacture parts on the moon, e.g. spun basalt fiber has high tensile strength. 6) The device's performance will not degrade as quickly as a battery 7) It can store power for the duration of the Lunar night with minimal loss
Some points to consider before you get too excited:
1) Thermal cycling also kills motor/generators. I once headed a motor reliability project. The primary cause of failure was thermal cycling. If the energy storage is underground or inside a thermally insulated structure, thermal cycling will be minimal.
2) Estimate the cost to store a realistic amount of energy. A starting assumption is that you need to store enough to supply 100 kW for 3 weeks. That's 50 megawatt-hours. Calculate the mass and cost of batteries to store that much, then the mass and cost of a flywheel energy storage system. Note that the cost is the cost of a system installed and running on the moon. And that the mass is the system mass, not just the mass of the spinning rotor or battery cells.
3) Any concept that requires manufacturing on another planet must include the cost, energy requirements, and mass of the manufacturing plant that is shipped to that planet.
It is not a trivial problem.
One of the problems is thermal cycling. Superconductors are just about a different temperature window than batteries, but it's still a window.
I can assure you that local manufacturing of that kind of inertial mass would be a real nightmare.
I won't say that it's not possible or that there are no circumstances what would make this practical, but not in any close future.
If you gonna start digging, then you can just as well bury batteries underground, to reduce the temperature variations and radiation that cause their problems.
Solar energy can make rock wool from basalt on the moon. Make a rock wool blanket that weighs in at about 10 psi. Inflate it with 80% N2 and 20% O2 gas to keep the blanket floating above the equipment. You then have thermal convection for cooling during the 350 hours of day, and warm batteries for the 350 hours of night. Your engineers can live in comfort, playing extraordinary cricket in the covered crater.
  • Haha
Making anything complex and technically demanding out of moon resources is going to require large pre-investments in infrastructure and equipment. A whole lot of pre-planning and testing too; few factories doing novel things in difficult conditions work perfectly first go.
Seems like in-situ resources are more of a longer term goal than an initial setup for a moon base - perhaps one of the goals would be to demonstrate at small, demo scales that mining, refining, manufacturing things out of local materials is possible. I'm not convinced that any significant dependence on local resource use will be feasible or economically viable; such a base would be much more a demonstration of Earth's abundance than a demonstration of the moon's economic potential.
For all that weeks of energy storage seems a lot I suspect batteries will do it a lot better than flywheels, you just need to accept that you need a lot. Without the in-situ materials would flywheel systems mean shipping lower mass than with batteries? I suspect not. Batteries can be shipped as modular components. Not sure flywheels can.
Any habitat intended for people will have controlled temperature and atmosphere and include room for batteries. Very high grade thermal insulation will likely mean cooling rather than heating is the issue, even during the long cold nights.
The temperature, a couple of metres below the lunar surface, is stable between lunar days and nights, fortnights. That deeper temperature ranges from -20°C to -40°C (-4°F to -40°F) in equatorial and mid-latitude regions.
Batteries will need to be kept warm.
10 psi of rock wool overhead should be sufficient to keep the day-night temperature stable inside the habitat.
Heat can be removed from the living space by reducing the thermal carpet in the basement. By supporting an atmosphere, and circulating that through underground heat exchanging boreholes, there will be a greater capacity to dispose of heat, into a greater volume of the Moon rock.
I am doubtful anyone will build underground on the moon in the foreseeable future. I expect it to be an extraordinarily difficult challenge to attempt that kind of construction.
Modular buildings on the surface with high grade insulation and active heating/cooling systems will be good enough and they will be much easier to build (assemble) and cheaper.
Exploring other options, in the spirit of thought experiment... we might consider sunshades/heat reflective canopies over a base to moderate the extremes; without weather those can be very light weight. But I suspect modular buildings will work okay so that won't be necessary.
The Moon cannot really offer much, but there is one serious advantage (compared to above-LEO space stations): there is enough local material for effective radiation shielding.
If it'll be the Moon for any long term presence, then some kind of 'underground' will be on the table.
Then your foreseeable future is only short term. The planning must be for a longer period, with the evolution of a manufacturing industry, and the extraction of oxygen from the minerals present in the basalt.
I do not suggest building underground, build a sandwich on the surface, but with insulation and an atmosphere.
The first shelter will be a prefab, the second will be a cover for a small crater. If it is lightweight, it will not protect the habitat from the extremes of heat and cold. No one wants to live in a thin walled balloon. It will need a large volume of rock wool insulation, manufactured on site. The floor will be too cold, so it will need a carpet of insulation.
Good point about radiation shielding. Except I think that, along with the dire absence of commercially exploitable opportunities, it builds the case for NOT attempting any long term habitation on the moon and for making our future 'explorations' crewless.
What are they going to be doing above and beyond surviving? Who is going to pay their way? Is it a reasonable allocation of Earth's valuable resources?
Operating rock mining, extraction plant, and solar furnaces for material processing. Manufacture and maintenance of automated satellite and solar furnace and PV panel manufacturing plant. Assembling interplanetary vessels for launch from the Moon.
The organisation that wants the satellites, vessels or power.
Yes. It is a productive investment.
The initial cost on Earth, of the minimum prefabricated habitat and plant, will allow zero Earth cost from then forwards.
It uses lunar materials and power to do, on the Moon, what is otherwise more expensive on Earth.
If making basalt fiber on the moon presents problems, then I propose making the flywheel on Earth.
For a energy storage solution, I am not proposing shielding the flywheel from cosmic rays or micrometeorites. It would be some distance from a habitat, with different shielding.
Thermal cycling can be reduced by a simple sunshade, keeping it cold during the day and reducing radiative cooling at night. In the day the shade could be angled to expose the flywheel to the dark sky but shaded from the sun. At night the shade could cover up more to reduced radiative cooling.
Or - of course, if you find a lava tube, that works better.
Even assuming a stable optimal temperature, the flywheel is better than batteries both in durability and weight.
Have you compared the weight of the energy-storage flywheel, to the weight of the equivalent batteries?
Yes, and while real examples of both vary, a flywheel without the mass of a vacuum container is broadly similar to battery. But with the best materials, up to 1000Wh/Kg is claimed as possible for a flywheel. Batteries can't match that with a reasonable lifespan.
I have to wonder how far is locally processed basalt from 'best materials' ...
Indeed. Perhaps I shouldn't have added that to the proposal, it just complicates things.
I do think it is possible that basalt fiber might eventually become a product available in quantity on the Moon.
But for the first flywheels, the components would all come from Earth.
Yes.
Carbon based fibres will be expensive and hard to find.
If there is a manufacturing plant on the Moon, with a solar furnace operating during the lunar day, basalt wool will become the most common fibre or string available.
True. My main argument is that batteries fade over time, but a flywheel won't.
That is not your decision to make.
Once a solar furnace is operating on the Moon, it will be possible to extract chemical elements from the melt, using electrolysis, driven by PV energy. That will be a game changer when it comes to manufacturing solid state batteries and capacitors, for use on the Moon, and in spacecraft departing from the Moon, to all points out there.
As you say, you would need a lot of batteries. Flywheels brought from Earth would by a similar mass, but they would last far longer. And sure, they can easily be modular.
Not my decision, but at the moment, with the current state of technology, they do fade.
'Fade' is one of the parameters that will play a part in the selection of future lunar energy-storage technologies. Fade may become irrelevant when considering other more important parameters, those you are ignoring, because you do not yet know what they are.
The decision will be made by the financiers of the project, after they have read the reports from the engineers.
@AI_ It is possible that flywheel storage will emerge as the superior option; predicting the future is hard.
Nuclear is high on the list of options, but may need improved versions that can be ramped up and down according to varying demand or else need storage to go with it, but less storage. Or possibly, oversized above peak demand and shedding energy somehow.
Seems there is plenty of time for energy and storage technologies to continue improving and to better evaluate their capabilities and costs before any firm plans for moon bases are in place. I've seen some nice artist visualizations but have yet to see anything like a plan. Let alone a business case for any of the supposed opportunities. I remain doubtful.
The low cost (and still declining) of solar here on Earth, but not all the time or everywhere, is a powerful incentive for storage, with de-carbonization for the climate an overarching driver that isn't ever going to go away.
But I am of the view that useful technological developments will emerge (or not) as spin offs from the totality of Earth based R&D, which will primarily be done for Earth based reasons - that achieving these grand space ambitions will depend on the spin offs of others more than dedicated space R&D will deliver high value spin offs.
The overlap with military tech is large and I suspect is fundamental to sustaining high levels of taxpayer funding but if it is a choice between world peace and ongoing geopolitical conflict driving high levels of aerospace R&D there isn't much doubt which I would be willing to sacrifice. Perhaps international meteor defense can become a shared peaceful space ambition that drives ongoing space R&D. (According to Pew a few years ago, meteor defense is the most supported goal for NASA by the US public).
Another alternative. . . . .
From time to time 'they' suggest projects for supplying Earth with energy from solar satellites. I always see downsides to that. But a similar system of orbiting solar satellites around the Moon could do the same job with some huge advantages; the Lunar Night is long but two or three equatorial satellites could maintain solar power input although probably not in synchronous orbits ( one month period). You'd be spoiled for choice of target receiving sites - all well away from human activity and no maintenance problems.
The geometry would be different with the curvature of the Moon and that could limit the coverage of any but very distant orbits. I must look this up but I'm sure someone here can point out why it would be a disaster or too expensive.
Al_ said:
TL;DR: This article: https://phys.org/news/2026-01-lunar-nights-martian-storms-batteries.html says batteries are problematic in space. I propose a flywheel.
Batteries bad
That editorial is questionable as properly designed batteries do operate and last in space quote a long time as well as could function properly on the moon.
Seriously, google up "what kind of batteries are used in outer space" and "The longest-lasting power sources in space".
Li-ion batteries commonly used on earth last 22 years or more, and earth is not an environmentally friendly place for batteries.
Are you forgetting nuclear sources? Some early probes were (still are) powered that way.
That was you rreply to the question "who would pay"? The timescale doesn't ever seem to be included as a relevant factor and 'investors' have not invested in such long-term projects since Pyramids and cathedrals. The only incentive for such long term thinking is not based on Capitalism but on religion and the belief in 'investment' for the afterlife. Modern religions may believe in an afterlife but not (afaiaa) on taking stuff with you when you 'pass'. Far too long term for investment funds to be interested in.
I have a suspicion that space colonisation may turn out to be a form of Ponzi scheme, getting money from investors now to pay for future demands for more money. The only serious motive for investment in Space is based on an arms race. A scary thought. I hope that comment won't be taken as being too political. Imo I'm just considering one of the relevant factors involved.
@sophiecentaur The principle commercial opportunity - once we look beyond communications and Earth observation satellites, that service a large pool of paying customers - appears to be taxpayer funded contracts. I don't think that can ever be sufficient; the gap between costs of investment and returns on investment are too large.
I would like to think asteroid mining can become a viable commercial space enterprise, with (I think) the ability to produce rocket fuels in situ for extremely durable/long lasting in-space rockets a fundamental element - an economic as well as technology threshold that has to be surpassed for the mining and refining of target minerals (Platinum Group Metals and maybe Cobalt and Nickel) to be viable.
I do think that meteor defense is a long term not for profit motive that has enough potential benefit to survive world peace and international cooperation. Just one of those flyby asteroids, even modest sized, hitting somewhere would bring home the worth of such preparation and planning. And is still very ambitious, with strong embedded incentives to support ongoing R&D for better space technologies.
Space technology is as good for the US economy as was arms manufacture.
The USA has previously primed and driven its economic pump with military spending, but now, with the uptake of military spending in Europe, the USA will need to find space for alternatives.
20K
