Michelson and Morley solved, relativity gone
  • Level: Graduate
  • Thread starter Thread starter paulanevill@fsmail.n
    Michelson Relativity
129 replies · 17K views · last reply
BTW paulanevill@fsmail.n I find your Idea of someones intellect as being a measuable function from their employ(s), rather silly, childish, and especailly & intently ignorant...
elas said:
]Nereid
What 'problems of inter-galactic light transmission'?
According to Encyclopedia Britainica one of the outstanding unsolved problems of light is the transmission of light between galaxies. It does not give details.
Perhaps you give the reason yourself in your reply "There are a number of predictions from this low density". Do they all give the same answer? If not there is a problem.
My main interest is in finding an explanation that fits the observation rather than accepting that the transmission of light is belond explanation or an act of magic. I usually get reffered to the standard explanations but, to date no one has been prepared to state why my explanation is unaceptable. Surely a debate should do more than repeat current teaching?
I have no idea what the Encyclopedia Britainica is referring to! Without any specific problems identified, let's assume there are no problems. :wink:
The 'low density' predictions refer to different phenomena, and AFAIK there are no inconsistencies nor observations that don't match theory. Later I'll post a few more details.
Maybe I missed your explanation (I'll read this thread again); are there *predictions* from this explanation which differ from 'the standard explanations'? If there are, and if those predictions are inconsistent with observations, then your explanation is unacceptable.
Well there is a problem intergalactically, sorta, closer to home two of the probes that were sent out, to explore the outer planets, have been leaving our solar system, and it is being remarked upon that they appear to be slowing down...
This begs a great question, is this appearance of slower motion simple a reality of the speed of light actually being different as we progress away from the Sun's gravitational field, or is the Sun's gravitational field somehow more active, or stronger, as you get farther away from it?...is it lightspeed changing, or gravity getting stronger? (or both?)
elas said:
*SNIP
Here's the only elas explanation that I found on this thread:
elas said:
*SNIP
Now consider all the debates about the speed of light and assume that our instruments are not allowed to record a greater speed than X; if all light traveled at a speed of 2x or greater, then all instruments will record a speed of X regardless of direction. This will not alter the red shift, so the distance calculations using red shift will remain the same, but any use of the measurements to calculate time will be open to question.
Next assume that light traveling in particle form is restricted to speed X (the maximum speed of particles) and light traveling in a purely wave form does so at a speed of 2X or greater and you have a possible explanation to the behaviour of light.
I really don't follow this explanation.
Let's go back to a time way before Einstein and Maxwell, to the 17th century.
Olaus Roemer calculated the speed of light by measuring a time difference and a (calculated) distance difference. Similar methods, of the kind
(calculated) speed = known distance/measured time
gave reasonable values for the speed of light, again well before Einstein or the publication of Maxwell's equation. Notice: no 'instrument' measures the speed, so the idea that any such is 'not allowed to record a greater speed than X' is meaningless, IMHO.
I also cannot follow the second part of your explanation - Young's double slit experiment shows that light has both a wave and particle nature. If, under your assumption that light has two forms - wave, and particle - which travel at different speeds, how to account for the results of the Young double slit experiment?
2clockdude:
No matter how man may synchronize the two clocks, this step
is interference by man, and is not allowed during a proper
scientific experiment because clock synchronization controls
the result.
Agree. This is how the GPS works and it is not proof that the speed of light one-way is invariant.
Nereid:
Does the GPS system work as advertised? Yes.
Did the dudes and dudettes who designed, built and maintain it use GR and SR in their work? Yes.
Did they use some alternative theory/theories instead? No.
Have any of these dudes and dudettes done a 2 clocks one-way light speed test? No.
the result.
If we aren't allowed to set up the initial conditions of the experiment, then no experiment we ever do has any meaning.
Every person who has ever turned on a GPS reciever has done a 1 way speed of light test, an SR time dilation test, and a GR time dilation test all at the same time.
Don't get me wrong, I'm really alright. It's just a case of the only way to motivate the intellectual is to wind him or her up a little. It was all done on purpose. Sorry folks.
Hummm so you assume that everyone' intellect needs "winding up"...and if your wrong, then people react to your "winding up" attempt and not to the actual question/answer needs, good dodge (I suppose) but I really do not believe that that is why you did that, but have 'no proof', soooooo...have a nice life!
No journal submission?
If your idea is really all that great, why are you harassing people on an internet forum, rather than submitting a detailed paper to a peer-reviewed scientific journal? :rolleyes:
Even Einstein as a patent clerk submitted papers.
Good inisight for a newbie (to this forum anyway). Welcome to the site.
I tried that once...sorta... (sorry bout that 'Guys' didn't always know my own stength, kinda easier with that feedback impairment y'all gots)...getting published in a Journal? Nah, I was a...Uhmmm, Truck driver at that time, Nope! I was self employed?...uhmmm, maybe it was that other guy I was working for, or at that other place? anyways...don't even recall (right this second/minute) what Job I had, Hee hee heeeeeeee :cool: !
["2clockdude" wrote:]
the result.
[Russ W replied:]
[2clockdude notes:]
That comment is much better than the standard "Hey, you silly
crank, don't you know that SR's right as rain!"
Let's see if we can go forward from here.
It is clear that setting up the initial conditions cannot involve
rigging the outcome; however, in the case of light's one-way speed,
man _must_ rig the outcome by relating the clocks his way because
clock synchronization is a necessary part of any two-clock case,
and only man can synchronize clocks.
For example, if man forces clocks (as did Einstein) to obtain
one-way light speed invariance/isotropy, then of course they will
obtain this, but this result was not given by nature, it was given
only by man, so it is not a law of nature.
For another example, if man were to somehow absolutely synchronize
clocks, then they will obtain one-way light speed variance/anisotropy,
but this result would not be given by nature, so it would be a law of
nature.
If that which is critical to the output is controlled by man, then
the output (or result) cannot be a law of nature or a natural result.
Only if that which is critical to the output is fully controlled by
nature will the output (or result) be a law of nature or a natural
result.
This is why there could be a law of nature in the round-trip, one-
clock case. In that case, unlike the one-way, two-clock case, there
is not only _no_ synchronization, but nature herself fully controls
all of the critical parts of the experiment, namely, the clock's
intrinsic rhythm, and the rods' intrinsic lengths.
By slowing the clock and contracting the rods of the round-trip
experiment, nature was able to cause the outcome to be null; thus,
the law of nature in the round-trip case is invariance/isotropy.
Contrastingly, since the one-way, two-clock case calls for clock
synchronization, and since nature cannot synchronize clocks, it is
impossible to obtain a law of nature in the one-way case. This is
exactly why no one has ever performed the one-way Michelson-Morley
experiment.
Here is the only way that such an experiment could be performed:
Step 1: Nature conceives of a clock synchronization definition.
Step 2: Nature starts and relates two spatially-separated clocks
in accordance with Her synchronization definition.
Step 3: Nature uses the clocks to measure the one-way speed of a
passing light ray.
I hope that everyone can now clearly see that Nature cannot give us
Her result (or a law of nature) in the one-way case.
However, it is clear to me that Einstein did not see this at all
because of the following three steps he took:
[a] Einstein took it for granted that a one-way light speed law
of nature existed.
Einstein firmly believed that this one-way light speed law of
nature was invariance.
[c] Accordingly, Einstein based all of his special relativity solely
upon his firm belief that the "law of nature" in the one-way case is
"invariance."
But, as we know, there cannot be a law of nature in the one-way case,
so there cannot be a one-way postulate or any scientific theory based
upon such a postulate; ergo, special relativity is not a scientific
theory.
Special relativity makes no predictions that are not entirely based
upon a mere definition given by man, namely, Einstein's definition of
clock synchronization (which forces light speed invariance/isotropy
in the one-way case.)
Therefore, special relativity makes no scientific predictions about
the nature of nature.
For a prime example, once more consider the critical case of the
one-way speed of light per two clocks:
Einstein's invariance of this speed was/is due only to his clock
synchronization definition, which, as we said, simply forces clocks
to obtain one-way invariance, so this is certainly not a scientific
prediction, but is a mere man-given (rigged) result.
For another example, consider the case of special relativity's so-
called "time dilation"; all that happens in this case is that due
to the asynchronousness of Einstein's clocks, one observer will see
another observer's clock apparently run slow when it is compared
with the two clocks in the first observer's frame.
This last example is much easier to see pictorially, as follows:
[4]-->
[4]----Frame A-----[3]
......[5]-->
[5]----Frame A-----[4]
As is _forced_ by Einstein's definition of clock synchronization,
the observers in Frame A see the passing clock "run slow." This is
a result that was not given by nature, so it is not a law of physics;
indeed, it has nothing whatsoever to do with real time dilation (or
with real or intrinsic clock rhythms).
["wisp" noted:]
[Russ W replied:]
Question:
How did these persons synchronize their clocks?
(The only known method for synchronizing clocks is Einstein's
definition of synchronization, but this, as we know, merely
forces one-way invariance/isotropy, and so is _not_ a law of
nature.)(Also, since Einstein has only relative simultaneity,
it is clear that his clocks are not absolutely synchronous,
but are asynchronous, so they are incorrectly related.)(Of
course, no one in GPS cares because of their error corrections;
they openly state that such corrections can even override the
deliberate governmental barrier for civilian usage.)
And as far as the part about a SR time dilation test goes, how
can SR say anything about actual clock rhythms when each SR
frame's observers find _different_ "rhythms" for one and the
same passing clock? (I say that it is physically impossible for
a single (steady-speed) clock to have more than one atomic
rhythm.)
2clockdude,
I think your post is very interesting.
I would like to correct one error I noticed. You said that Einstein "firmly believed that his one-way light speed law of nature was invariance"
In fact, though, Einstein was not proceeding from any such belief. He said:
"That light requires the same time to traverse the path A to M as for the path B to M is in reality neither a supposition nor a hypothesis about the physical nature of light, but a stipulation[/] which I can make of my own freewill in order to arrive at a definition of simultaneity."
From Chapter VIII, ON THE IDEA OF TIME IN PHYSICS, SR
Einstein stipulated the speed of light as constant in order to have a tool to explore the greater point he was working toward about the Relativity of Simultaneity. Apparently he hadn't heard about the Michelson-Morley experiment at the time he wrote SR.
I don't know if this changes your interesting train of thought at all, but I thought you should know.
-Zooby
[zoobyshoe wrote, in part:]
[2clockdude replies:]
Hey, we're really making progress here! Yes, 'Zooby,' I am well aware
of Einstein's two different versions of light's one-way speed!
One version was that one-way invariance/isotropy is a LAW of nature
per experiment, and the other was that it was merely a _stipulation_
given only by mere man, which means that it would have exactly nothing
to do with physics (or with the nature of nature).
How do I know for sure that Einstein had _two_ versions; well, I
know for sure that he claimed to use the principle of relativity,
and I also know for sure that he claimed to have a scientific
theory called special relativity, and these two facts alone tell
us in no uncertain terms that Einstein was talking about a LAW
of nature in the one-way light speed case. (The principle of
relativity pertains _only_ to laws of nature, and any scientific
theory must of course pertain to the nature of nature.)
Furthermore, take a quick look at the title of Chapt. VII in
Einstein's book _Relativity_:
"The Apparent Incompatibility of the LAW of propagation of light
with the Principle of Relativity"
We know that here he was speaking of the one-way light speed LAW
because he gave a math formula showing that this LAW is c - v
in the Galilean case (for a departing light ray).
And, as I said above, since he was talking about the principle of
relativity, he had to have been talking about some sort of LAW of
nature. (Not to re-mention the fact that he claimed to have a
scientific theory based on a scientific postulate about the one-way
speed of light per two clocks.)
[Before I proceed to clear up the "two versions" theme, I should
address your claim that Einstein apparently had not heard of the
MMx when he created SR; please ponder the following from the first
page of Einstein's 1905 SR paper: "Examples of this sort, together
with the unsuccessful attempts to discover any motion of the Earth
relatively to the 'light medium,' suggest that ..."]
[I would also like to say that even though I was aware of the two
versions prior to my last post, I deliberately ignored the mere
definition (or mere stipulation) version in order to focus on the
more important version (re SR), namely, Einstein's claim that there
is a LAW in the one-way light speed case, and that SR was based on
this LAW being invariance.]
Well, there can be no doubt that Einstein had two entirely different
stories regarding one-way light speed invariance/isotropy, but the
problem for Einstein is this: Neither version has any real value for
or any relevance to science!
Here is the problem with Version One ("the one-way, two-clock light
speed law not only exists, but is invariance/isotropy"):
Since nature cannot synchronize clocks, and since there cannot be a
one-way, two-clock law without two synchronized clocks, it is clear
that there cannot be such a law, and it follows that there cannot be
a scientific postulate regarding such a law, and it further follows
that there cannot be a scientific theory based on such a postulate;
therefore, special relativity cannot be a scientific theory. (It says
absolutely nothing about nature that is not based 100% upon a mere
man-given definition of clock synchronization because 100% of the math
of special relativity is derived using Einstein's clocks in all frames.)
Here is the problem with Version Two ("one-way, two-clock light speed
invariance/isotropy is purely a mere stipulation given in order to have
a working definition of 'simultaneity."):
As the twin SR phrases "relative time" and "relative simultaneity"
tell us, Einstein's time and Einstein's simultaneity are not absolute,
but are merely relative. But I dislike the use of the terms "relative"
and "absolute"; for clarity, they should be replaced with the terms
"incorrect" and "correct."
In other words, Einstein's stipulation produced incorrectly-related
(i.e., absolutely asynchronous) clocks.
Therefore, Einstein's definition of synchronization (i.e., his stipulation
of one-way light speed invariance/isotropy) gives us _incorrect_ clocks.
So here are the bottom lines for Einstein:
Bottom Line 1:
[one-way "law" case:]
Einstein has no scientific theory because there cannot be a law of
nature in the one-way, two-clock light speed case.
Bottom Line 2:
[definition of clock synchronization (stipulation) case:]
Clocks which are baselessly and arbitrarily forced to obtain one-way
light speed invariance/isotropy will not be correctly related.
(Of course, over relatively small distances and for measuring relatively
slow speeds, Einstein's clocks will suffice because their error of
synchronization in such cases is very small due to the very rapid speed
of light through space, but as far as theory goes, clocks which are
asynchronous are simply asynchronous clocks, period.)
In either case, Einstein loses in a big way.
2clockdude,
I googled "On the Electrodynamics of Moving Bodies" and I agree that the sentence you quoted strongly indicates Einstein must have been aware of MM, since he was aware of "...the unsuccessful attempts to discover any motion of the Earth relatively to the `light medium'..."
I happened to notice, just below this, the following:
"We will raise this conjecture (the purport of which will hereafter be called the `Principle of Relativity') to the status of a, postulate, and also introduce another postulate, which is only apparently irreconcilable with the former, namely, that light is always propagated in empty space with a definite velocity c which is independent of the state of motion of the emitting body. These two postulates suffice for the attainment of a simple and consistent theory of the electrodynamics of moving bodies based on Maxwell's theory for stationary bodies."
Here Einstein describes both the Principle of Relativity and the invariance of c as postulates. I don't see him asserting that one or the other (or both) is a law of nature.
[zoobyshoe wrote:]
You need to know the meaning of the phrase "scientific postulate."
A scientific postulate is the prediction of a law of nature (given
solely by nature, with zero interference by man) or of the physical
existence of some specific phenomenon.
Here is an example of the latter:
"The American theorists Murray Gell-Mann & George Zweig independently
postulated the existence of quarks."
[from American Physical Society - "A Century of Physics" - a
physics timeline at http://timeline.aps.org/servlet/Event?evtId=113]
Dictionary definition of postulate (verb):
To assume to be true.
A scientific postulate is a guess, a supposition, a
hunch, or a hypothesis about the nature of nature.
All scientific postulates must pertain to the nature of nature.
All scientific postulates must be experimentally testable.
Given that your claim is that Einstein claimed that his one-way
light speed invariance was a postulate, I have to ask you the
following simple question:
How can one-way light speed invariance occur experimentally?
One cannot postulate one-way invariance if one has already forced
it via one's definition of clock synchronization.
Note carefully that all scientific postulates and theories _must_
be falsifiable (or at least testable), but it is clearly impossible
to falsify (or to even test) Einstein's one-way light speed invariance
because it is _mandated_ via definition (just as are the length of an
inch and the value of water's boiling point in degrees F).
One can postulate one-way light speed invariance IFF (if and only
if) it could possibly happen in nature (at least in principle), but,
as I have taken great care to point out, one-way light speed invariance
simply cannot happen experimentally, so it cannot be scientifically
postulated.
If you really believe that Einstein postulated one-way invariance,
then tell us how this postulate could possibly be tested experimentally.
(Just show on paper a test for one-way invariance.) (There can be no
such test because one-way invariance cannot occur in nature. This is
why no one has ever performed the one-way Michelson-Morley experiment,
including Michelson, Maxwell, Lorentz, and Einstein.) (In fact, no one
has ever even shown _on paper_ how such an "experiment" could be carried
out!) (And, as I said, this is because no such "experiment" exists, not
even in principle!)
I considered submitting my theory to a journal. But it meant signing away copyright and you loose control of your work, and the journals make profit from selling your work.
I think that placing your ideas freely on the Internet or self-publishing is just as effective.
2clockdude,
A postulate (noun) is:
a hypothesis advanced as an essential presupposition, condition, or premise of a train of reasoning.
Merriam-Webster's Collegiate Dictionary, 10th edition
postulate - OneLook Dictionary Search
Address:http://www.onelook.com/?w=postulate&ls=a
The definitions you gave lack the important point that a postulate is put forth in the service of a train of logic to see where it will lead if followed. Postulates are similar to stipulations in that they don't have to be proven to start the train of logic. Einstein took his two postulates and followed the train to his theory of relativity.
Experimental testability is, I believe, a requirement of a scientific theory, not of a postulate. You do not go about testing a theory by testing its postulates. If you could do that they wouldn't be postulates to begin with, but facts. To the extent SR has been experimentally tested and passed it lends credence to the postulates.
"Signing away copyright" doesn't mean squat. It just means you can't make money off of photocopied/reproduced copies of the paper. This is because the journal took time typesetting it for you. You still own intellectual property rights, if you have applied for a patent. Journals are not a profit-making venture. Have you seen any journal publishers driving Ferraris? I haven't. Most barely make back enough to break even. And even then, scientists gripe all the time about how expensive subscription or page charges are.
An independent person can submit their work to a journal without page charges for free, which is a pretty good deal, considering how many people will read it. Journal articles have been reviewed and are much more respected than some e-mailed Word document on some theory. We scientists get this stuff all the time. Usually we hit delete. Submission to a journal is the essence of the scientific process. Let a few people look at it and judge the merit and suggest improvements before the rest of us waste any time.
I promise that the vast majority of scientists are open minded and would welcome an overturn of a paradigm, since it gives us all a lot of interesting problems to work on.
As long as they are not requiring you to sign away your Moral rights (your right to your name, on your work...and no one else's!) in copyright law, then you have nothing to worry about...what they want is the right to grant the right, to others, to copy the work(s)
[zoobyshoe noted:]
You are merely repeating what I said re postulates, only with slightly
different words.
[zoobyshoe noted:]
Postulates don't have to be proved, but they must pertain to that
which could happen in nature - if only in principle; however, that
which Einstein "postulated" - as I have said - _cannot_ happen in
nature even in principle. (It cannot happen naturally because nature
cannot synchronize clocks.)
And a postulate is definitely not anything like a stipulation; the
latter is merely a man-given convention, like the length of an inch,
and, as I said, such conventions or definitions have nothing to do
with the nature of nature or with experimental results.
A physics postulate is the assumption of the truth of the occurrence
of something physical. As you said above, it is simply a scientific
hypothesis or a supposition. But the problem in Einstein's case is the
fact that his postulate or hypothesis or supposition assumed the truth
of that which cannot happen, not even in principle.
Perhaps the following will clear this matter up for you:
Do you believe that Einstein believed that he was hypothesizing that
the natural value of light's one-way speed is c in all frames? If so,
then you are saying that Einstein believed that the outcome of the
experiment which uses two clocks to measure light's one-way speed is
supposed to be invariance. But there cannot be such an experiment
due to the inability of Nature to synchronize clocks. (The one-way,
two-clock speed of light cannot be measured without two clocks
which have been temporally related in some way, and only if Nature
relates the clocks will the result be a natural one, i.e., one that
can be hypothesized about.)
[zoobyshoe noted:]
Since a scientific postulate is a scientific hypothesis, it is clear
that a scientific postulate must be testable and falsifiable or it
says nothing about the nature of our world.
There are two major problems with the following sentence of yours:
"To the extent SR has been experimentally tested and passed it lends
credence to the postulates."
In the first place, SR = Einstein's light postulate, and in the second
place, this makes it impossible to test SR.
I challenge you to list a single scientific test of SR, i.e., any
experiment which either tests the sole basis of SR (namely, Einstein's
claim of one-way invariance) or any experiment which was _not_ rigged by
the use of clocks related by Einstein's definition of synchronization
(which forces one-way invariance).
Bear in mind that SR's "time dilation," SR's "mass increase," and SR's
"length contraction" are all fully dependent upon Einstein's clocks, so
are simply circular and therefore irrelevant results. (They are circular
because of the following fact: If one artificially forces clocks to obtain
one-way light speed invariance, and if one then uses these clocks to make
any measurements, then all such measurements are merely given by man, and
not by nature, so they have nothing to do with the nature of nature or
with physics per se. For example, here is how light's one-way invariance
is circular in Einstein's world: If I force clocks to obtain one-way light
speed invariance, then I will obtain it. For another example, here is how
SR's "time dilation" is circular: If I compare two of Einstein's absolutely
asynchronous clocks in Frame A with a passing clock, then I must of course
"see the passing clock running slow" because of the _given_ (mandated by
sheer man-given definition) absolute asynchronousness of Einstein's A-frame clocks.)
So far, you have tried to use a scientific postulate, a stipulation, and
a combination of the two, but you still have failed to show how SR be a
scientific theory or how Einstein's so-called light postulate can be a
scientific postulate or hypothesis.
No one can test a stipulation or a definition, but a scientific postulate
or a scientific hypothesis or a scientific theory must be both testable
and falsifiable.
And just in case none of the above hits home, here is my backup
version:
I need you to tell me the full physical meaning of Einstein's light
"postulate" (my quotes). In other words, what exactly was Einstein's
hypothesis, presupposition, condition or premise in this case? What
physical process was being presupposed or hypothesized? I claim that
he was hypothesizing that if two clocks were used to measure light's
one-way speed, then the experimental result must be invariance. I
also claim that no such experiment can be performed due to the simple
fact that clock synchronization is not a natural phenomenon. But I
would like to hear your claim as to the exact physical meaning of
Einstein's light "postulate" (my quotes).
So I suppose you don't want the correct solution to the michelson and morley interferometer. You'd rather keep on talking about relativity, and such, as if you really understand it. The problem has been solved and there is no need for the likes of you to waste you time on it any longer. Einstein was wrong, but then he was only a patent clerk. I on the other hand, I have spent over twenty years as a professional engineer, creating products and solutions to problems far more difficult than a silly, incorrect, interferomter model.
If you want the solution which destroys relativity then email me a request at paulanevill@fsmail.net, the file is too big to leave here. If on the other hand you are not man enough, then please feel free to continue your unprofessional tittle tattle. Ta ra.
Paul A Nevill BEng (Hons.), MIEE
So, tell me, can you prove it by taking pictures of the experiment and such?(Not really pictures, but you get my point)
Well, 2clockdude, I have recently been reading another thread on this very subject started by someone with a different name than you but who seems to have an identical argument to yours. I find this odd because your argument is so idiosynchratic.
I suspect, at this point, that you and he are the same person, and that this peculiar argument that relativity doesn't even qualify as a proper theory is being offered here for entertainment purposes.
['zoobyshoe' noted:]
... this peculiar argument that relativity doesn't even
['2clockdude' replies:]
Authorship is irrelevant to the argument, and my argument
was certainly not for entertainment; if that is all you
have gathered, then you have not understood a word that I
have said. (OTOH, you may just be copping out.)
Let me make one more valiant attempt to get through:
Somebody, somewhere, at some time has made the claim that
light's one-way speed per two clocks is invariant. My
question to you is How can that be?
(Show us on paper how it can happen experimentally.)
Tom Mattson
Of course, we don't have to use SR. There are aether theories that are experimentally indistinguishable from it. But the question is, "Why on Earth would you want to add the superfluous assumption of an aether?"
What about all the superfluous assumptions that have crept into ST for historical reasons, I have made it clear time and time again that I do not criticize the mathematics, but, I do criticize the vast array of entities used to explain the numbers; most of which cannot not be defined. This includes the latest addition ie 'strings'.
Without wish to repeat myself, the solution can be obtained by leaving me your email address here, or emailing me on paulanevill@fsmail.net
[Tom Mattson noted:]
an aether?"
[twoclockdude replies:]
For one thing, SR is not a scientific theory because it makes no
predictions about nature. Everything in SR is based solely on a
definition - including light's one-way speed invariance - so none
of SR pertains to the nature of nature (because, as I just said,
it is nothing but a mere convention plus its irrelevant results).
Definitions and conventions from man are not natural laws or parts
of nature. For example, the length of an inch is a mere convention,
so it is not a part of nature, so it does not belong in any theory
of nature as a hypothesis. This is exactly why Einstein's invariance
of the one-way speed of light does not belong in any scientific
theory. (This 'invariance' is given only by convention or by mere
definition, just as is the length of an inch.) (Nothing in nature
says - or could say - that light's one-way speed is invariant,
so no scientific theory can say this.)
For another thing, as far as light's speed through space is
concerned, the aether essentially exists. Why? Because we know
the value of this speed (it is c, and it was given by Maxwell's
equations as well as the Kennedy-Thorndike experiment), and we
know that it does not vary in 'empty' space. What more could you
ask for re 'absolute' motion detection? (Well, as Einstein said,
you would need truly or absolutely synchronous clocks in order to
correctly measure light's passing speed in order to determine
your own speed through space. There, now, wasn't that simple!
(And no actual aether was even needed!)
I would like to step backward to the original purpose of MM null experiment.
The purpose was to find the special frame of reference required by Maxwell's theory of electromagnetism.
Newton's laws of motion and law of universal gravitation work on all frames of reference. And space and time are separated frames.
The rest frame that MM experiment was looking for is the ether frame. And this cannot be found.
In order to remove the requirement of EM for a special frame, the frames of space and time were combined into spacetime.
Unless the ether is found, special relativity will just have to remain the best theory of finding the rest frame of the universe.
The truth is there is no such "rest frame" anywhere in the universe. Everything is in motion even at the local infinitesimal region of spacetime as what GPB probe will detect the gravitomagnetism of spinning spacetime. But GPB might still fail to detect this local motion since it's more of a double spins configuration than that analogous to the gyroscope. If one of the double spins is much more dominant, GPB might be able to detect the precession and wobbles.
2clockdude said:
For one thing, SR is not a scientific theory because it makes no predictions about nature.
Have you checked out Nereid's links to the numerous predictions/experiments verifying SR? Any specific ones you disagree with?
This 'invariance' is given only by convention or by mere definition, just as is the length of an inch.
No. Thats a pretty fundamental misunderstanding of SR - and possibly experimental physics itself.
So...you are saying you agree that there is no aether?
2clockdude, your posts display a rather severe misunderstanding of the way science works - ie, how experiments must work, what a "theory" is, what is and isn't acceptable in a theory, experiment, postulate, etc., etc. I've used the baseball analogy before: if you want to play baseball, you have to follow the rules. You're not following the rules: the game you are playing is therefore not science.
[2clockdude wrote:]
[russ_watters replied:]
you disagree with?
Name one that is not fully dependent upon Einstein's definition
of clock synchronization. All two-clock measurements in SR are
dependent upon this definition, so all of the so-called SR
"predictions/experiments" are merely the direct results of
said definition, so none are given by nature, and all are given
only by man via a definition.
For example, here is SR's "time dilation":
Given, a single clock passing two Frame A clocks:
[4]->
[4]----Frame A----[3]
---------------------[5]
[5]----Frame A----[4]
The A-Frame observers declare, "Look, Ma, the passing clock is
running slow!"
But, as anyone can see, this "time dilation" of SR has nothing to
do with
There are at least two physical reasons why SR's "time dilation"
has nothing to do with actual or intrinsic clock rhythms, as follow:
[1] No two real clocks can both be slower than each other.
[2] No single real atomic clock moving inertially can have more
than one atomic rhythm (and yet Einsteinian observers in various
frames find that a single passing clock "runs at many different
rates.")
[2clockdude wrote:]
So you tell me what's the basis for one-way, two-clock light speed
invariance.
[2clockdude wrote:]
It's easy to prove that there is no aether, but the proof is moot
because as far as light's speed through space is concerned, there
is an aether. This is because this speed is known, and it never
changes. (No light ray can outrun another in 'empty' space; all
light rays in space always move at the same speed.)
As Einstein himself said, given the absolutely synchronous clocks
of classical physics, light's one-way, two-clock speed would vary
with frame velocity. This is due to the two facts I just mentioned.
We don't need an actual aether to have absolute time and to measure
our speed through space. All we need is a pair of (absolutely or
actually) synchronous clocks.
Einstein's clocks are not truly or absolutely asynchronous because
he was unable to determine absolute simultaneity, as he freely
admitted, but as his followers seem determined to ignore or twist
into something else.
Einstein's SR is not a scientific theory because it says nothing
at all about nature. ALL of SR's results are given only by man
via a mere definition of clock synchronization because ALL of SR's
two-clock times (i.e., the times in the SR transformation equations
and its composition of velocities theorem times) are dependent upon
Einstein's definition of synchronization. (None of SR's times are
given by experiment or by nature, so none are a part of physics.)
