How to Use the Midpoint Formula to Find the Other Endpoint of a Line Segment?
  • Context: MHB
  • Thread starter Thread starter nycmathdad
    Formula
The discussion focuses on using the midpoint formula to determine the other endpoint of a line segment given one endpoint and the midpoint. The formula derived is \(x_2 = 2x_m - x_1\) and \(y_2 = 2y_m - y_1\). Two specific examples are provided: for the first segment with endpoints (1, -2) and midpoint (4, -1), the other endpoint is calculated as (7, 0). For the second segment with endpoints (-5, 11) and midpoint (2, 4), the calculations are similarly straightforward.
  • Understanding of the midpoint formula in coordinate geometry
  • Basic algebra for manipulating equations
  • Familiarity with Cartesian coordinates
  • Ability to perform arithmetic operations on integers
  • Study the derivation of the midpoint formula in detail
  • Explore applications of the midpoint formula in geometry
  • Learn about line segments and their properties in coordinate geometry
  • Practice solving problems involving endpoints and midpoints
Students in geometry, educators teaching coordinate geometry, and anyone looking to strengthen their understanding of line segments and midpoints in mathematics.
nycmathdad
53. A line segment has (x_1, y_1) as one endpoint and (x_m, y_m) as its midpoint. Find the other endpoint (x_2, y_2) of the line segment in
terms of x_1, y_1, x_m, and y_m.
54. Use the result of Exercise 53 to find the endpoint (x_2, y_2) of each line segment with the given endpoint (x_1, y_1) and midpoint (x_m, y_m).
(a) (x_1, y_1) = (1, −2)
(x_m, y_m) = (4, −1)
(b) (x_1, y_1) = (−5, 11)
(x_m, y_m) = (2, 4)
I need help with 53 and 54.
Mathematics news on Phys.org
Beer soaked query follows.
(x_m, y_m) = (2, 4)
What have you done so far?
Call the other endpoint (x_2, y_2). Then x_m= (x_1+ x_2)/2 so 2x_m= x_1+ x_2 and x_2= 2x_m- x_1. Similarly y2= 2y_m- y_1.
x_2= 2(4)- 1= 8- 1= 7
y_2= 2(-1)- (-2)= -2+ 2= 0.
(x_2, y_2)= (7, -0). Check: ((7+1)/2, (-2- 0)/2)= (8/2, -2/2)= (4, -1).
(x_m, y_m) = (2, 4)
Why don't you try the last one?
Country Boy said:
Call the other endpoint (x_2, y_2). Then x_m= (x_1+ x_2)/2 so 2x_m= x_1+ x_2 and x_2= 2x_m- x_1. Similarly y2= 2y_m- y_1.x_2= 2(4)- 1= 8- 1= 7
(x_2, y_2)= (7, -0). Check: ((7+1)/2, (-2- 0)/2)= (8/2, -2/2)= (4, -1).Why don't you try the last one?
You said:
"Call the other endpoint (x_2, y_2). Then x_m= (x_1+ x_2)/2 so 2x_m= x_1+ x_2 and x_2= 2x_m- x_1. Similarly y2= 2y_m- y_1."
In your reply, where did 2x come from?
m++
There is NO "2x" in what I wrote. If you mean "2x_m", multiply both sides of x_m= (x_1+ x_2)/2 by 2.
Beer soaked ramblings follow.
Fourteen years of Precalculus review and you're still stumped by the midpoint formula?
I can see that your quest for Calculus understanding will be a very rough and even longer ride.
For someone who once pretended he's on his way to mastering Calculus as https://mathhelpboards.com/members/harpazo.8631/, it is disappointing to see you struggling once again with basic stuff.
Maybe you can see this more clearly if Countryboy decided to give his excellent answer in LaTex.
Too hammered right now to do it, so see a somewhat similar application of your present dilemma at https://mathforums.com/threads/symmetrical-line.356080/
But then again, I might already be in your prestigious Ignore List and you might not see this at all.
I didn't use LaTeX because the original post did not! Here:
https://mathhelpboards.com/goto/post?id=124850
53. A line segment has $(x_1, y_1)$ as one endpoint and $(x_m, y_m)$ as its midpoint. Find the other endpoint $(x_2, y_2)$ of the line segment in
terms of $x_1$, $y_1$, $x_m$, and $y_m$.
Call the other endpoint $(x_2, y_2)$. Then $x_m= (x_1+ x_2)/2$ so $2x_m= x_1+ x_2$and $x_2= 2x_m- x_1$. Similarly $y2= 2y_m- y_1$.
54. Use the result of Exercise 53 to find the endpoint $(x_2, y_2)$ of each line segment with the given endpoint $(x_1, y_1)$ and midpoint $(x_m, y_m)$.
(a) $(x_1, y_1) = (1, −2)$
$(x_m, y_m) = (4, −1)$
$x_2= 2(4)- 1= 8- 1= 7$
$y_2= 2(-1)- (-2)= -2+ 2= 0$.
Country Boy said:
I didn't use LaTeX because the original post did not! Here:Call the other endpoint $(x_2, y_2)$. Then $x_m= (x_1+ x_2)/2$ so $2x_m= x_1+ x_2$and $x_2= 2x_m- x_1$. Similarly $y2= 2y_m- y_1$.$x_2= 2(4)- 1= 8- 1= 7$
Nicely done. I thank you.
Translation: I love cajoling members into doing my work without showing any kind of effort whatsoever on my part.
You're such a sweetheart!
