Miller indices for SC cube planes FAN, KFA, HAN
  • Thread starter Thread starter Dell
    Cube Fan Planes
9 replies · 2K views
Dell
for the following SC cube, find the miller indexes for the planes:
FAN
KFA
HAN
http://lh6.ggpht.com/_H4Iz7SmBrbk/SvhiU8OeicI/AAAAAAAAB8M/o8QPR2ht2gA/Capture.JPG
what i leared to do was find the points that the plane intercepts the x,y,z axis, i chose axes such that x+ is pointing right and y+ upwards, then i divide to get a ratio, and then ()^-1
i chose the length of a side of the cube to be "a"
FAN -> a,a,a -> 1,1,1 -> 1 1 1
KFA-> a,inf,a -> 1,inf,1 -> 1 0 1
now for the 3rd one i have found the intercept with the z axis which came out as 1.5a
HAN-> a,a,1.5a -> 1,1,1.5 -> 1 1 2/3
my question is if i am meant to do it like that or if i am meant to divide by 1.5a instead of just a
HAN-> a,a,1.5a -> 2/3,2/3,1 -> 1.5 1.5 1
up until this question i have only had whole numbers in the muiller index, so i thought another option could be
HAN-> a,a,1.5a -> 2,2,3 -> 0.5 0.5 1/3
but then i have on;y fractions,
could someone please clear this up for me, which way (if any )) is the correct way?
It's customary to use all whole numbers.
now my second question is does it matter what i call xyz?? since they arent defined in the question, i chose xyz as i said but a friend of mine chose different and we obviosly got different answers. for example he would get 2 3 3 for the above index.
is there any standard axes system or can i choose any right handed system?
Your friend's answer is equivalent since, as you suggest, Nature doesn't have a preferred coordinate system.
Mapes, would it not be 223 since it intercepts the z axis at1.5 times the point it intercepts the x,y axes. or is this correct since i apply ()^-1 to the whole index?
233 looks right to me. If you look at the surface normal, there's one direction whose resolved component is smaller and two whose components are equal and larger. Plus, I agree with your original calculations.
can you explain what you said about the normals a bit more, how do i see that there is one which ils smaller?
Well, the plane contacts point H instead of point F, so it's not angled towards the z axis as much as it would be if it were a 111 plane. But this is kind of the "casual" way of estimating the indices. The reciprocal approach is the rigorous way, which you showed in your first post.
