Minimum work done to push the cube over
The discussion revolves around the minimum work required to push a cube over, focusing on concepts of gravitational potential energy and the center of mass in a physics context.
  • Participants explore the relationship between the center of mass and the block's stability, questioning how much force is needed to reach a critical position for the block to fall over. There are discussions about the change in gravitational potential energy and the implications of horizontal movement.
Participants are actively engaging with the problem, raising questions about the critical position of the center of mass and the energy required to reach that state. Some guidance has been offered regarding the nature of the critical position and the implications of energy changes, but no consensus has been reached.
There are constraints regarding the lack of information on horizontal distance and the specific definitions of the critical position, which are under discussion.
hello478
image below
w=f*d
my attempt:
centre of mass of standing block is at 0.6
and the fallen block is at 0.25
so then change in height = 0.35
and mg = 4000 N
so change in gpe = 4000* 0.35 = 1400J
but wouldnt we take into account that we only have to apply force till the centre of mass is outside of the block so would it still require the force which is equal to its weight
and what about the distance it falls forward? wouldnt that also take force?
correct answer is 200N
You are asked for the minimum energy which has to be supplied to make the block roll over.
Imagine you are doing it. You have to supply some energy to rotate the block through some angle to reach a critical position – and then the block will fall over naturally, without you having to supply further energy.
So the question is: what is the minimum energy you need to supply to get the block to the critical position?
And the underlying question is: what is the ‘critical position’?
As an increase or a decrease?
How can the mass centre ever be outside the block? What did you mean?
You are not given a horizontal distance of movement.
I took that to mean that if you drop a vertical line down from the CM, it crosses the side of the inclined block and not the base.
yeah this is what i meant
so like, shouldnt it be considered?
Try plotting the position of the center of mass as you rotate through 90 degrees.
the critical position is option c, a little before that, as soon as cg is out of base...
in this green pic, would the block return back or fall over??
It takes no more work. Once it is falling forward, job done.
What is the position of the CG for these three pictures?
a) equilibrium
b) inside base
c) outside base
the green pic, tip of base
another question for green pic
As you have drawn it, that is rather beyond the critical position. When only a tiny bit beyond the critical position, how much work have you done? Do you need to do any more?
Assuming zero velocity, the green pick is an unstable point like being at the top of a hill.
Try plotting on a grid. You need to quantify the position of the CG.
Another hint: the problem with your calculation is that the end state has lower potential energy than the initial state, so you are calculating energy “released”.
  • · Replies 30 ·
