Undergrad How Does Modal Logic Interpret Possibility and Necessity?
  • Thread starter Thread starter Nim
    Logic
This discussion focuses on the interpretation of possibility and necessity within modal logic. It establishes that a statement is considered logically possible if it is not ruled out by any true statement and that everything logically necessary is also logically possible. The example of "1+1=2" illustrates how the definition of the accessible frame affects its classification as possible or necessary, depending on the arithmetic context applied, such as normal decimal arithmetic versus arithmetic modulo 2.
  • Understanding of modal logic terminology
  • Familiarity with logical necessity and possibility
  • Knowledge of arithmetic systems, including decimal and modular arithmetic
  • Basic concepts of accessible frames in modal logic
  • Research the concept of accessible frames in modal logic
  • Explore the implications of modal logic in different arithmetic systems
  • Study the relationship between logical necessity and possibility
  • Learn about philosophical interpretations of modal logic
Philosophers, logicians, mathematics educators, and students interested in the foundations of modal logic and its applications in different logical frameworks.
Nim
One of the ways we use the term possibility is "We can go to Mars". Another way is "We may learn how to travel to Mars faster than light as our understanding of physics progresses".
What exactly does it mean in modal logic? Would a statement like 1+1=2 be considered possible in modal logic or necessary or both?
Logically possible means not ruled out by something that is true or is logically necessary. Everything that is logically necessary is also logically possible.
Likes Nim
I should have said "true in all possible worlds", rather than simply "true" -- a thing could be false in our world and still be logically possible.
Neither of those statements contains the term (or operator of) possibility. The first one is a simple statement of ability "We are able to go to Mars". The second does contain the notion of possibility and can be restated "It is possible for us to learn how to travel to Mars faster than light...".
Possibility has no meaning on its own, it acquires meaning with reference to a frame of worlds. If a proposition is true in any frame that is accessible then it is possible.
That depends on how you define the accessible frame. If the frame includes normal decimal arithmetic then the statement is clearly possible so the modal proposition "it is possible that 1 + 1 = 2" is true in that model. If the frame includes arithmetic modulo 2 then the modal proposition "it is possible that not (1 + 1 = 2)" is true, which in most formulations of modal logic implies that the proposition "it is necessary that 1 + 1 = 2" is false. Of course one could argue that 2 is not a value of arithmetic modulo 2 and so the proposition has no meaning in that world, but then you are in danger of straying into philosophy which is
  • where, in my (limited) experience, modal logic usually ends up
  • not allowed on Physics Forums.
  • · Replies 40 ·
  • · Replies 23 ·
  • · Replies 29 ·
  • · Replies 27 ·
  • · Replies 24 ·
