PFStudent
- 169
- 0
Conventionally, the Galilean Transformation relates two reference frames that begin at the same location and time with one reference frame moving at a constant velocity [tex]{\vec{v}}[/tex] along a positive [itex]{x}[/itex]-axis (which is common to both reference frames) with respect to the other reference frame. It follows that the transformation relating the two reference frames: [tex]{K(x,y,z,t)}[/tex] and [tex]{K^{\prime}({x^{\prime}},{y^{\prime}},{z^{\prime}},{t^{\prime}})}[/tex] is the following,
[tex]{x^{\prime}} = {{x}-{vt}}[/tex]
[tex]{y^{\prime}} = {y}[/tex]
[tex]{z^{\prime}} = {z}[/tex]
[tex]{t^{\prime}} = {t}[/tex]
Consider the following, what would the Galilean Transformation equations be if one reference frame was moving with a constant velocity [tex]{\vec{v}}[/tex] along a radial direction [itex]{\vec{r}}[/itex] (which is common to both reference frames) with respect to the other reference frame? Given reference frames: [tex]{K(x,y,z,t)}[/tex] and [tex]{K^{\prime}({x^{\prime}},{y^{\prime}},{z^{\prime}},{t^{\prime}})}[/tex]; find this Galilean Transformation.
Knowledge of Transformations.
Conventionally, in a Galilean Transformation we are only concerned with the constant velocity [tex]{\vec{v}}[/tex] of one reference frame moving along a common [itex]{x}[/itex]-axis between both reference frames with respect to the other reference frame. Consequently, the vector components of [tex]{\vec{v}}[/tex] are:
[tex]{{\vec{v}} = {{v}_{x}}{\hat{i}}[/tex]
Taking reference frame: [tex]{K^{\prime}({x^{\prime}},{y^{\prime}},{z^{\prime}},{t^{\prime}})}[/tex]; as the reference frame moving at constant velocity [tex]{\vec{v}}[/tex] with respect to reference frame [tex]{K(x,y,z,t)}[/tex] along a common [itex]{\vec{r}}[/itex] direction we note that velocity [tex]{\vec{v}}[/tex] now has vector components: [tex]{{\vec{v}} = {{{{v}_{x}}{\hat{i}}}+{{{v}_{y}}{\hat{j}}}+{{v}_{z}}{\hat{k}}}}}[/tex]. It follows then that the Galilean Transformation equations must also reflect the displacements along the axes: [itex]{x}[/itex], [itex]{y}[/itex], and [itex]{z}[/itex]; consequently the new Galilean Transformation becomes,
[tex]{x^{\prime}} = {{x}-{{{v}_{x}}{t}}}[/tex]
[tex]{y^{\prime}} = {{y}-{{{v}_{y}}{t}}}[/tex]
[tex]{z^{\prime}} = {{z}-{{{v}_{z}}{t}}}[/tex]
Is that correct?
Thanks,
-PFStudent
