Molecular sensing fluorescent proteins and FRET pairs
The discussion revolves around the relationship between fluorescent proteins (FPs) and Förster Resonance Energy Transfer (FRET) pairs, particularly in the context of biological visualization techniques. Participants explore the mechanisms of fluorescence and FRET, as well as the challenges associated with using identical fluorophores in FRET measurements.
  • One participant questions whether fluorescent proteins and FRET pairs are related or serve different analytical purposes, expressing uncertainty about their connection.
  • Another participant explains that FRET can occur between any pair of fluorescent molecules, including organic dyes and fluorescent proteins, indicating a potential relationship between the two.
  • A participant raises a concern about distinguishing between identical fluorophores in FRET experiments, specifically when using fluorescein-fluorescein pairs.
  • Several participants discuss the challenges of measuring FRET efficiency between identical fluorophores (homo-FRET), noting that it relies on analyzing the anisotropy of emitted light.
  • There is mention of how the polarization of emitted light can provide insights into FRET efficiency, particularly when fluorophores are attached to larger molecules.
Participants express varying levels of understanding and uncertainty regarding the relationship between fluorescent proteins and FRET pairs. While some clarify aspects of FRET, the discussion does not reach a consensus on the initial question posed about their connection.
Participants highlight the complexities involved in measuring FRET efficiency, particularly with identical fluorophores, and the dependence on specific experimental conditions such as the polarization of light.
rwooduk
Hope this is in the right place, apologies if not.
We have studied green flourescent protein GFP and others (RFP, CFP etc) as a means of analysing an organism / sample, you need two that have unique fluorophores. We have also studied the use of FRET pairs such as florecein-florescien or florecein-rhodamine for studying interatomic distance / molecular structure.
My question is are flourescent proteins and FRET pairs related or are they for completely different analyses?
Think I'm getting the two mixed up, or are they related? i.e. do FP's contain the chemical in Fret pairs?
Hope this question makes some kind of sense I am really not a biologist!
Biology news on Phys.org
In biology, we often make use of fluorescence to visualize molecules. Fluorescent molecules will absorb light of a certain wavelength, and emit light of a slightly longer wavelength. The two most common types of fluorescent probes used in biology are small organic dyes (such as fluorescein or rhodamine) and fluorescent proteins (such as GFP, YFP, CFP, etc.).
Förster Resonance Energy Transfer (FRET, sometimes referred to as fluorescence resonance energy transfer) is a phenomenon that can occur with any pair of fluorescent molecules. When FRET occurs, one fluorophore can transfer its energy to a fluorophore that emits at a longer wavelength. This process can occur for any fluorophore, so you can have FRET occur between organic dyes (such as the fluorescein-rhodamine pair you mentioned), between fluorescent proteins (CFP-YFP is a popular pair of proteins to use for this purpose), or between an organic dye and a fluorescent protein.
The problem I'm having is that if you use florecein-florescien then how would you be able to distinguish between the two in FRET? if that makes sense.
aside from that, that's very helpful thank you!
Measuring the FRET efficiency between two identical fluorophores (homo-FRET) is difficult because the donor and acceptor fluorescence are not spectrally distinct, but it is possible. Measuring homo-FRET relies on looking at the anisotropy of the emitted light; that is, the polarization of the emitted light compared to the polarization of the excitation light.
When you excite a sample with polarized light, only those fluorophores whose transition dipoles align with the light will be excited. If these fluorophores are rigidly attached to large (greater than tens or hundreds of kilodaltons) molecules, then you would not expect these molecules to rotate much during the lifetime of the excited state (~ a few nanoseconds), so the emitted fluorescence will have the same polarization as the excitation light. FRET, however, will tend to randomize the polarization of the emitted light because FRET can transfer energy to fluorophores whose transition dipoles were not aligned with the original excitation light. Thus, fluorescence anisotropy measurements allow you to measure the FRET efficiency between fluorophores with identical or near-identical emission spectra.
When you excite a sample with polarized light, only those fluorophores whose transition dipoles align with the light will be excited. If these fluorophores are rigidly attached to large (greater than tens or hundreds of kilodaltons) molecules, then you would not expect these molecules to rotate much during the lifetime of the excited state (~ a few nanoseconds), so the emitted fluorescence will have the same polarization as the excitation light. FRET, however, will tend to randomize the polarization of the excited light because FRET can transfer energy to fluorophores whose transition dipoles were not aligned with the original excitation light. Thus, fluorescence anisotropy measurement can allow you to measure the FRET efficiency between fluorophores with identical or near-identical emission spectra.
wow, that's a very detailed explanation and clears things up immensely, thank you very much!
