Calculate Acetic Acid Adsorbed by Activated Charcoal
  • Context: Chemistry
  • Thread starter Thread starter Hydrous Caperilla
    Acid Moles
The discussion focuses on calculating the amount of acetic acid adsorbed by activated charcoal using a 0.06N acetic acid solution. Initially, 3 grams of activated charcoal were added to 50 mL of the solution, resulting in a filtrate strength of 0.042N after one hour. The calculations revealed that 0.9 millimoles of acetic acid were adsorbed, equating to 54 mg, but the textbook answer was 18 mg due to a miscalculation regarding the mass of charcoal. The importance of keeping the volume constant during adsorption calculations was emphasized, as the volume change is negligible.
  • Understanding of normality and molarity in solutions
  • Basic knowledge of adsorption principles
  • Familiarity with stoichiometric calculations
  • Ability to perform unit conversions (grams to milligrams)
  • Learn about adsorption isotherms and their applications
  • Study the principles of solution concentration calculations
  • Explore the concept of equilibrium in adsorption processes
  • Investigate the properties and applications of activated charcoal in chemical processes
Chemistry students, researchers in material science, and professionals involved in adsorption processes will benefit from this discussion.
Hydrous Caperilla
(Q.) 3 g of activated charcoal was added to 50 mL of acetic acid solution (0.06N) in a flask. After an hour it was filtered and the strength of the filtrate was found to be 0.042 N. The amount of acetic acid adsorbed (per gram of charcoal) is :
I thought of finding the volume first by using the formulae :N1V1=N2V2 and then get the volume but I realized that finding volume won't help so I am out of ideas
The volume doesn't change.
How many moles of the acetic acid before adding the charcoal, how many moles after adsorption?
the n factor for acetic acid is 1 so it's molarity will be same (o.o6M). and from the formulae ,we can calulate the moles but I don't know how to calculate moles after adsorption
You have 50 mL of a 0.042 M solution, how do you calculate number of moles in such case?
What is the definition of the molar concentration?
Molarity X Volume=0.042 X 0.05
Doesn't volume increase with addition of solutes
In general you are right, it does. But in most cases change can be neglected.
Please pay attention to what you post, each your post contains unnecessary multiple quotes (I will remove them now). Use "preview" button to see what it will look like. You can also edit your posts for a short period of time.
So I want to post the steps I have understood
Step 1 Before Adsorption
No of moles of acetic acid in the solution=50X0.6=3milli moles(n factor of acetic acid is 1 so Normality=Molarity)
Step 2
No of mole of acetic acid after adsorption=50(volume is not changing which I don't understand)X0.042=2.1 millimoles
Step 3
Moles adsorbed= O.9millimoles
Step 4
Weight of acetic acid=0.9X60/1000=54mg
My textbook gives the answer as 18mg...what did I do wrong now and can you tell me more about when to keep volume constant
That's correct.
Looks OK.
what did I do wrong
Reread the question, you have missed something.
Almost always, only when the concentration changes are huge it really matters.
0.06 M acetic acid contains 3.6 g of acetic acid per liter.
0.042 M acetic acid contains 2.5 g of acetic acid per liter.
The difference is 1.1 g. Imagine removing the acid from the solution - you are removing 1 g from 1000 g, so you can expect volume change in the 0.1% range at best. Negligible.
I get it now.
I forgot to divide it by the mass of charcoal so it makes sense now.
Thanks
10K
