Molniya Orbit: calc angular displacement of ascending node
7 replies · 3K views
Paul Gray
Hello there :),
We have a molniya orbit with an eccentricity of [itex]e = 0.72[/itex] and a semi-major axis [itex]a = 26554 [km][/itex].
The task:
Calculate the angular displacement of the ascending node Ω after 100 sidereal days
Moreover I know from Wikipedia that a molniya orbit has an inclination of [itex]i = 63.4 [deg][/itex].
I considered using following formula
[tex]\Delta\Omega = - \frac{3\pi J_2 R_E^2}{a^2 (1-e^2)^2} * cos i[/tex]
But I am pretty sure it is the wrong formula, because time doesn't matter in it. (Even it has an Ω at the beginning ;)).
Hence I hope on insightful input provided by you :). Thank you for your help!
Paul
That formula gives you ## \Delta \Omega ## per some period of time. What is that period of time?
That's a simple but clever answer. I will give it a shot as soon as possible :). Thank you ...
Using the hint voko provided I get the following answer
[tex]\Delta\Omega = - \frac{3\pi J_2 R_E^2}{a^2 (1-e^2)^2} \cdot \cos i <br /> = \frac{3\pi 1082.7 \cdot 10^{-6} 6378^2}{26544^2 (1-0.72^2)^2} \cdot \cos 63.4<br /> = -2.139 \cdot 10^{-3} [\frac{rad}{rev}][/tex]
One revolution takes
[tex]1 [rev] = T = 2\pi \frac{a^3}{\mu_{Earth}}^{1/2}= 11.962h[/tex]
Hence the angular displacement of the ascending node after 100 sederial days (1day = 23.934h) is:
[tex]2.139 \cdot 10^{-3}\frac{23.934}{11.962}\cdot 100= 0.42798 [rad] = 24.5214[deg][/tex]
Is this a plausible result?
PS: I don't know what to do with the minus in front of [itex]-2.139 \cdot 10^{-3}[/itex] :)?
Thanks for your help!
I did not check the numbers, but the logic is sound.
Thank you very much voko. The numbers are not as important as the logic is :).
The minus in front of [itex]-2.139*10^{-3}[/itex] still bugs me. How can I get rid of it? Can I neglect it?
The minus gives you the direction of rotation.
Thank you, I got it :).
