Moment of Inertia Calculations for Varying Mass Rod and Hollow Ring
The discussion revolves around calculating the moment of inertia for a slender rod with a varying mass distribution and a hollow ring. The original poster presents two distinct problems involving the moment of inertia, seeking clarification on the calculations and concepts involved.
  • The original poster attempts to derive the total mass of a rod with a mass per unit length that varies with distance and questions the correctness of their integration approach for calculating the moment of inertia.
  • Participants discuss the implications of the axis of rotation for the hollow ring and express uncertainty about the setup and calculations for both problems.
  • Some participants question the relationship between the moment of inertia at different ends of the rod and the impact of the center of mass on these calculations.
The discussion is ongoing, with participants providing insights and questioning assumptions. Some have offered guidance on checking units and clarifying the axis of rotation, while others are exploring different interpretations of the problems without reaching a consensus.
There is mention of homework constraints regarding the inclusion of certain variables in the final answers, and participants are navigating the implications of varying mass distributions and axis placements in their calculations.
loz1588
Hi. I'm having trouble with moment of inertia in general, and so I have questions about two problems (I tried using latex, but it didn't seem to be loading properly).
The first problem:
A slender rod with length L has a mass per unit length that varies with distance from the left-hand end, where x=0, according to dm/dx=gamma*x, where gamma has units of kg/m^2.
Calculate the total mass of the rod in terms of gamma and L.
Use I=int r^2dm to calculate the moment of inertia of the rod for an axis at the left-hand end, perpendicular to the rod. Use the expression you derived in part (a) to express I in terms of M and L.
Repeat part (b) for an axis at the right-hand end of the rod.
I=int r^2dm
and dm/dx=gamma*x
I got the first part by integrating dm/dx; the answer was (gamma*L^2)/2
I'm not sure how to do the second part. I originally solved for dm and plugged that into the integral and solved, but the program said gamma was not part of the answer. Is that correct?
The second problem:
Find the moment of inertia of a hoop (a thin-walled, hollow ring) with mass M and radius R about an axis perpendicular to the hoop's plane at an edge.
I'm not sure where to start on this one. My first issue is I'm not sure where the axis is, and once I figure out that, I'm not sure what to do.
Thanks for any help!
Show your working.
In the second question, it says the axis is perpendicular to the hoop at the edge.
I=int r^2dm
I know that r=L/2, so I substitute that into get I=int (L^2)/4 dm.
I then use my answer from the previous part and solve for L; I get (2M/gamma)^1/2. Plugging that into the earlier equation, I now have I=int M/(2*gamma)dm. I can pull out 1/(2*gamma) so that I have I=(1/2*gamma) int Mdm. I'm not sure of the bounds, however, but I evaluated the integral from 0 to L. My final answer is (L^2)/(4*gamma). I'm not sure if this is correct, though, because it doesn't involve the variable M.
Once I have the correct answer, though, is it true that the moment of inertia for an axis at the right-hand end of the rod is simply the negative of that answer?
Check your units. Remember that gamma is mass/ unit volume.
I don't think so. Try holding a baseball bat at the wrong end. It's a lot easier to swing meaning the MoI is a lot less.
Your problem can probably be solved by working out the center of gravity of the rod, and then assuming all the mass is there.
I'm not quite sure what you mean by check your units. Are you saying plug in M/V for gamma? But then won't I have V in the final answer, which isn't allowed?
First, I see from the question that gamma has units mass/area, not mass/volume so the units do add up.
I agree with your calculations for the first question but it doesn't make sense to me. If the centre of mass was exactly in the middle of the rod, then the MoI will be be tha same at both ends. But if it's say, 1/3 along from end, then the MoI from one end is M(L/3)^2 and from the other it's M(2L/3)^2.
I don't see how this ties in with
I = \int_0^L \gamma x^2 dx
unless the limits are changed to reflect the centre of mass.
I'm sorry I thought this was going to be easy and I hope I haven't confused the issue. Let's hope someone else can help.
  • · Replies 40 ·
  • · Replies 21 ·
  • · Replies 28 ·
