Moment of inertia of a semicircle
The moment of inertia of a semicircle with mass M and radius R about an axis perpendicular to its plane through point A is calculated using the formula I = I_cm + Md^2, resulting in I = (1/2)MR^2. This outcome is consistent with the moment of inertia of a complete disk of mass M due to the mass distribution being uniform. For a quarter disk, the moment of inertia also simplifies to I = (1/2)MR^2, demonstrating that the average squared distance from the axis remains constant across these shapes.
  • Understanding of moment of inertia concepts
  • Familiarity with the parallel-axis theorem
  • Knowledge of integration techniques in physics
  • Basic principles of mass distribution in geometrical shapes
  • Study the derivation of moment of inertia for various shapes using integration
  • Learn about the parallel-axis theorem and its applications
  • Explore the differences in moment of inertia between solid and hollow objects
  • Investigate the implications of mass distribution on rotational dynamics
Students and educators in physics, particularly those focusing on mechanics and rotational motion, as well as engineers working with materials and structures involving rotational dynamics.
kottur
A uniform disk of radius R is cut in half so that the remaining half has mass M. (Figure (a))
1. What is the moment of inertia of this half about an axis perpendicular to its plane through point A? Express your answer in terms of the given quantities.
2. Why did your answer in part A come out the same as if this were a complete disk of mass M? Express your answer in terms of the given quantities.
3. What would be the moment of inertia of a quarter disk of mass M and radius R about an axis perpendicular to its plane passing through point B? (Figure (b))
Moment of inertia of a semicircle.
I_{P}=I_{cm}+Md^{2}
I_{cm}=I=\sum_{i}m_{i}r_{i}^{2}
Is d=R?
1. I_{P}=I_{cm}+Md^{2}=MR^{2}+MR^{2}=2MR^{2}
Does this make sense?
No, your work doesn't make sense. You're applying the parallel-axis theorem. If you don't know what a variable stands for, look it up in your book or notes. Don't just guess. What do d and Icm correspond to? Does it make sense to apply the theorem to this problem?
Can I treat it as a solid cylinder with I=\frac{1}{2}MR^{2} since I know that it has mass M?
I'm not sure how to go about it being a semicircle?
Okay, I figured out that the answers to 1. and 3. is I=\frac{1}{2}MR^{2} but I really want to understand why.
No, you can't, because it's not a solid cylinder.
You're expected to derive the answer using
I = \int r^2\,dm
Okay, I think I understand. Please correct me if I'm wrong.
Is it because the mass is always M? We always have to use the moment of inertia of a whole circle with mass M which is I=\frac{1}{2}MR^{2}. But in this case the mass of half of the circle is M so 2M for the whole circle. So the moment of inertia of the whole of the circle is I=2*\frac{1}{2}MR^{2}=MR^{2} and then the moment of inertia of half of the circle is I=\frac{1}{2}MR^{2}.
Same goes for the quarter of a circle.
Am I right?
Sort of, but you're missing the key point.
Suppose you had a ring and solid circle, both of mass M and radius R. The ring has a moment of inertia equal to MR2 whereas the circle's is half that. Why are they different?
I'm not sure. Is it because the ring is hollow?
From the definition of moment of inertia I don't see why they should be any different. I don't understand this well enough.
Thank you for all the help. :)
The moment of inertia is the mass of the object times the mass-weighted average of the squared distance from the axis. Because the ring is hollow, all of its mass has to sit at a distance R from the center; hence, you have <r2>=R2 and I = MR2. With a solid disk, the mass is spread out. Only a small amount of the mass is at a distance R from the center, and the rest is closer. When you work out the math, you find <r2>=R2/2, so I=1/2 MR2.
Can you see why <r2> would be the same for the full circle, the half circle, and the quarter circle?
Okay I understand the explanation. I want to look at I=\int r^{2}dm that you told me to use in the first place.
How do I use that to give me the correct answer I=\frac{1}{2}M R^{2}? If I'm supposed to integrate r^{2} then it's \frac{1}{3}r^{3}.
What we want to do is look at little strips of constant r. In the full, solid circle, this would be a circle of radius r (not R). If we increase r by the infinitesimal amount dr, we can approximate that the density ρ is constant for the entire strip, and the infinitesimal area dA is simply the length of the strip multiplied by the width dr. The mass dm of that strip is therefore given by dm=\sigma\,dA = \sigma (2\pi r)dr.
That's an example of the basic procedure you need to follow to figure out dm for various shapes. You find the shape corresponding to constant distance r from the axis of rotation. Multiply its length by dr to get the area, and then multiply by the density to get dm. If you're working with a three-dimensional shape, you'll get a surface of constant r, e.g. a cylinder. You find its area and then multiply by dr to get a volume. Again, you multiply by the density to get dm. If you go through the examples in your book, you'll see that's all they're doing each time.
To get the moment of inertia, you need to integrate
I = \int r^2\,dm = \int_0^R r^2\sigma(2\pi r)dr = \frac{1}{2}\sigma\pi R^4 = \frac{1}{2} (\sigma \pi R^2) R^2 = \frac{1}{2} MR^2where M=\sigma A = \sigma \pi R^2.
To connect this back to what I said in my previous post, suppose we were to pull M out right at the start, so we have
I = M\int r^2\,\frac{dm}{M}The quantity dm/M is the fraction of the total mass M that is at a constant distance r from the axis. Can you see why the integral gives you the mass-weighted average <r2>?
In the case of the circle, dm/M is equal to
\frac{dm}{M} = \frac{\sigma(2\pi r)dr}{\sigma\pi R^2} = \frac{2r\,dr}{R^2}Show that for the half circle and the quarter circle, you get the same expression for dm/M. Since dm/M is the same for all three shapes, you get the same average for r2 and hence the same moment of inertia.
  • · Replies 28 ·
16K
