Moment of Inertia (Triangular Prism)
The discussion revolves around calculating the moment of inertia of a triangular prism about the z-axis. The user initially attempted to evaluate the moment of inertia using incorrect integration limits, integrating z from 0 to H/2 instead of -H/2 to H/2. Clarifications were provided regarding the volume element and the density, emphasizing the need to consider the entire height of the prism for accurate calculations. The importance of symmetry in the triangular prism was highlighted, suggesting that the integration could be simplified by considering the geometry of the shape. Ultimately, the conversation focused on correcting the integration approach and ensuring proper limits for accurate results.
derrickb
A triangular prism (like a box of toblerone) of mass M, whose ends are equilateral triangles parallel to the xy plane with side 2a, is centered on the origin with its axis along the z axis. Find its moment of inertia for rotation about the z axis. Without doing any integrals write down and explain its two products of inertia for rotation about the z axis.
I=∫r2dm
ρ=M/V
r2=x2+y2
ρ=M/(.5bhH);H is total length along z-axis
ρdV=dM=.5ρdxdydz
I=∫∫∫x2+y2dxdydz
I evaluated this with integration limits
for x: 0 to a
for y: 0 to √3a/2
for z: 0 to h/2
after doing it all out and substituting M/V back in for ρ, I got an answer of 7Ma2/96. I muliplied by 2 since that integral was only for half of the object, so my final answer would be 7Ma2/48. I have an intuition that this is incorrect. Can anyone point me in the right direction? Are my limits of integration correct? Any help would be much appreciated. Thank you
Where exactly is the axis of the prism?
I=∫r2dm
ρ=M/V
r2=x2+y2
ρdV=dM=.5ρdxdydz
Where did the 0.5 come from in the last line?
I=∫∫∫x2+y2dxdydz
for x: 0 to a
for y: 0 to √3a/2
for z: 0 to h/2
I don't understand your limits at all. Why are you integrating z from 0 to half the height of the triangle?
Not sure I really understand what you're asking. It says it's along the z-axis
ρ=M/V
ρV=M; V=A*H; A=.5bh
ρ(.5bhH)=M
ρdV=dM
I substituted in .5bhH for V but looking back on it I don't think I should have.
would dM=ρdxdydz be correct?
Sorry that was a typo. "h" should have been "H"
I'll assume one of the edges of the prism lies along the z-axis then. Is that right?
ρ=M/V
ρV=M; V=A*H; A=.5bh
ρ(.5bhH)=M
ρdV=dM
Yes, that's generically correct because in Cartesian coordinates, the volume element is given by dV = dx dy dz.
I still don't understand why you're only integrating to H/2. It's not like dividing by 2 and then subsequently multiplying by 2 simplifies the calculation any.
The way I interpret it is that the axis of rotation is along the z-axis, and that the z-axis runs through the center of mass. Basically, the triangle is centered on the z-axis. The wording is very vague, and I am a little confused by what is meant.
So I should integrate from -H/2 to H/2 is what your saying?
That sounds reasonable. So the z-axis lies somewhere in the middle of the prism. Doesn't this mean that x and y should take on both positive and negative values? Have you drawn a sketch?
Yes.
You'll see that the integration over the z-coordinate simply amounts to multiplying by H. Rather than using dV = dx dy dz, you could write dV = H dx dy and forgo integrating over z altogether. The infinitesimal volume element would be a rectangular solid with sides of length dx, dy, and H. You can do this because every piece of that element is the same distance r from the axis of rotation.
Likes 1 person
I have drawn a sketch. I'm going to try and work it out with the z-axis in the center of the triangle, and then with the z-axis as one of the prism edges, and use the parallel-axis theorem. I can take a picture of my work then. I know x and y would have positive and negative values, but if I integrated from them, wouldn't they just cancel out because of the symmetry?
No, it wouldn't cancel out because r2 is positive regardless of the signs of x and y.
Why not 0 to H? It won't make any difference. In fact, forget z and just treat it as a flat triangle.
I suggest using the symmetry of the triangle. Cut it into six identical right angled triangles, each with a corner at the z axis. That will simplify the integration bounds.
