Momentum, Ball being thrown on Ice
The discussion revolves around a physics problem involving momentum conservation during an inelastic collision where a person catches a ball on ice. The initial momentum is calculated using the mass of the ball and its velocity, while the final momentum combines the mass of the person and the ball after the catch. Several participants struggle with unit conversions and arrive at incorrect final velocities, initially calculating values around 15.571 m/s instead of the correct 6.42 m/s. Miscalculations in the final velocity stem from errors in the mass used in the equations. Ultimately, participants clarify their mistakes and confirm the correct approach to solving the problem.
Nickym707
You are standing on a sheet of ice that covers the football stadium parking lot in Buffalo; there is negligible friction between your feet and the ice. A friend throws you a ball of mass 0.400kg that is traveling horizontally at 10.5 m/s . Your mass is 65.0 kg .
If you catch the ball, with what speed do you and the ball move afterwards?
I set the momentum before equal to the momentum after, then solved for final velocity.
v2= (MaVa1+ MbVb1)/(Ma+Mb) and since the body isn't moving at all than the MbVb1 just is zero. you also want the 10.5 m/s into cm which is 1050 cm/s
I keep getting 16.1 and the answer is 6.42...
This seems to be a relatively simple problem, though I am getting 15.571, rather than 16.1. Given the fact that this will be an inelastic collision with the person catching the ball, I change
m1iv1i + m2iv2i = m1fv1f + m2fv2f
to
m1v1 + m2v2 = m3v3
Then,
[STRIKE](65.0 kg)(0 m/s)[/STRIKE] + (.400 kg)(10.5 m/s) = (65.4 kg)v3
v3 = 15.571
Also, I may have missed something, but I do not understand why you wished to change m/s to cm/s.
Im sorry, I was unclear, the problem asks us to change it to cm/s. I'm having problems because the webwork is saying that the answer is not 15 or 16...
That's strange, especially considering that our answers would give 1500 and 1600 cm/s. The only way that I can think of that much of a change would be an error in units somewhere, seeing that the problem doesn't seem to want you to take energy loss into account.
to
m1v1 + m2v2 = m3v3
Then,
v3 = 15.571
I'm not sure how the answer is 15.571 since I've calculated it to be 0.0642
I just looked back over my work, and I divided by 4.2 instead of 65.4, and just ended up with the reciprocal. I'm not really sure how I overlooked that, but at least I figured it out. I'm guessing he did something similar, as he came out with a similar answer to what I had.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
