Momentum cutoff, Lorentz violation and the vacuum state
The discussion revolves around the implications of introducing a momentum cutoff in the context of Lorentz violation and its effects on the vacuum state. Participants explore the theoretical consequences of a preferred frame and how this affects the notion of an 'empty' vacuum, particularly in relation to ground states and observations in different frames.
  • Some participants propose that introducing a momentum cutoff leads to Lorentz violation, necessitating a preferred frame.
  • There is a question about how to maintain the vacuum state as 'empty' in the presence of this preferred frame.
  • One participant suggests that if Lorentz symmetry is not preserved, the characteristics of the vacuum in other Lorentz frames become irrelevant.
  • Another participant asks what observations might be expected if a momentum cutoff is naively introduced in the preferred frame.
  • It is noted that applying a boost in the 'right' direction should result in the ground state appearing excited in a different frame.
  • Participants discuss the importance of the method used to compute the boost and the implications for free fields.
Participants express differing views on the implications of Lorentz violation and the nature of the vacuum state. There is no consensus on how to approach the calculations or the expected observations resulting from the introduction of a momentum cutoff.
Limitations include the dependence on the definitions of 'empty' vacuum and ground state, as well as the unresolved nature of the calculations regarding boosts and their effects on the vacuum state.
asimov42
Hi all - related to a question I asked some time ago: If one introduces a momentum cutoff, the result in the most basic case is Lorentz violation. That is, some form of preferred frame must be introduced. I'm wondering what this does to the vacuum state? That is, how does one keep the vacuum 'empty' despite this preferred frame? Or does the notion of the vacuum have to change?
By 'empty' I mean that the vacuum can only be in the ground state in the preferred frame, correct?
Correct. But if Lorentz symmetry is no longer the symmetry of the theory, then it is pretty much pointlesss to even ask how the vacuum (or anything else) looks in other Lorentz frames.
Thanks @Demystifier. If one were to do the totally naive thing and introduce a momentum cutoff in the preferred frame, without changing other aspects of the theory, what would one expect to observe?
An ugly but consistent theory that can be compared with experiments.
Certainly - but then there should be an expected (predicted) observation. For example, applying a boost in the 'right' direction should make the ground state in the preferred frame look excited in another, no?
Yes. I would call it a computational approximation rather than a "theory". Like ignoring the curvature of the Earth in a ballistic calculation.
I think it depends on how exactly do you compute the boost, i.e. what do you keep fixed. Have you tried to do the actual calculation? For free fields it should not be difficult.
  • · Replies 39 ·
  • · Replies 29 ·
  • · Replies 62 ·
12K
  • · Replies 105 ·
16K
  • · Replies 16 ·
