Momentum in two different k-points
  • Level: Graduate
  • Thread starter Thread starter hokhani
    Momentum
5 replies · 2K views · last reply
hokhani
For two different points [itex]k[/itex] and [itex]k\prime[/itex] in the Brillouin zone, can we have the same momentum? (By momentum I mean the real momentum, not the crystal momentum [itex]\hbar k[/itex] or [itex]\hbar k\prime[/itex]).
Sure, e.g. phonons all have true momentum=0, independently of the k value. For other particles, like electrons, doesn't have a well defined value in crystals, i.e. the electron is not in a momentum eigenstate. Hence, the momentum distribution of electrons with different k values will in general overlap, so that it is possible to obtain the same momentum when measuring it.
I think maybe not for Bloch wave states, although I am not sure.
If there is crystal momentum at some real momentum p would be shown in ##<n, k| p>##
$$\psi_{nk}(x) \propto e^{ik\cdot x} u_n(x)$$
$$<n, k| p> \propto \int dx e^{i(p/\hbar - k)x}u_{n}(x)$$
This can be interpreted as a Fourier transform. Because ##u_n## is periodic it will only have Fourier components at certain frequencies.
$$p/\hbar - k = G$$
for any
$$G = g_1\mathbf{b}_1 + g_2\mathbf{b}_2 + g_3\mathbf{b}_3,\, g_i \in \mathbb{z}$$
with ##b_i## being reciprocal lattice vectors.
Note that this does not mean that there is a momentum component at that value of ##k##, it just means there could be. Whether or not it does depends on ##u_n##.
So, although each ##k## couples to many different values of momentum, it seems those values of momentum are not shared with others in the same B.Z. But you will not get the values of ##p##to overlap for two ##k## in the same BZ. I am trying to illustrate this idea with the following crude picture.
You would have to go out of the BZ to get another value of k that corresponded to the same p. Once outside the BZ you could add a reciprocal lattice vector.
$$p_0/\hbar = k_1 + \underbrace{0}_{G_1} = \underbrace{k_1 + \mathbf{b}_1}_{k_2} - \mathbf{b}_1 = k_2 + G_2 $$
So
$$k_2 =k_1 + \mathbf{b}_1$$ would also correspond to the same momentum ##p_0##. This was by using a different value of ##G##, ## G_2 = - \mathbf{b}_1 ##. But by adding ##b_1##, we left the BZ of ##k_1##.
Yes, I think so but if we take the expectation value of momentum, namely p=m vgroup , where vgroup is proportional to the slope of energy band, it seems reasonable to have the same momentum at different points of BZ.
I am confused. When an electron absorb a phonon, it receives both the energy and momentum of that phonon; and a phonon mode is characterized by its energy and momentum (wavevector), and all modes in one branch have their energy-wavevector characteristics face, correct?
Second, as an electron is not in a momentum eigenstate, it would not be associated with any specific k value. But I agree with that the electron will take a k value once it is measured.
You are confusing true momentum p and crystal momentum (or wavevector) k. When an electron absorbs a phonon, the wave vector is conserved up to a lattice vector. True momentum is also conserved, but it is not carried by the phonon, but by the whole crystal.
