Homework Help: Momentum of a photon
  1. Feb 7, 2013 #1
    Find the momentum of a 140eV photon.
    2. Relevant equations
    momentum equations
    e=mc^2
    3. The attempt at a solution
    140eV=2.24*10^-17 J
    p=mv
    p=(E/c^2)c
    p=E/c
    p=(2.24*10^-17)/(3*10^8)
    p=7.466666*10^-26
    Is this correct? (other than significant digits)
  3. Feb 8, 2013 #2
    Dick
    Your derivation is little suspect since m=0. You should probably really be using E^2=(mc^2)^2+p^2*c^2. But the only problem aside from signficant digits is that you didn't put any units on it.
  4. Feb 8, 2013 #3
    Simon Bridge
    As it happens - yes. But don't forget to write in the units!
    The actual energy-momentum relation is ##E^2=m^2c^4+p_2c^2## and photons have ##m=0##.
    As Dick says, you got the right answer through the (apparently) wrong method.
    Technically you can say that p=140eV/c since "eV/c" are units of momentum :)
  5. Feb 8, 2013 #4
    How about this:
    140eV=2.24*10^-34 J
    m=E/c^2
    m=2.488888889*10^-34
    if a photon has no mass (even though the course asks me to find the mass of a photon several times) then how did i get this answer?
    p=h/λ
    mv=h/λ
    mc=h/λ
    λ=.......
    never mind. this is getting roundabout.
    the course has me calculate the mass value for a photon several times.
    when it would ask me for the momentum of a photon, however, it would have me use the formula : p=h/λ
    however, it would also supply a frequency so that i could actually calculate wavelength.
    i don't know of any way to calculate wavelength in this case, so i just used the standard p=mv for a particle
  6. Feb 8, 2013 #5
    Simon Bridge
    Nope - m=0 for a photon.
    And you left off the units again.
    But you are close (see post #3).
    Mass is a form of energy so there is a sense in which you can attribute a total mass to a photon. It's just potentially misleading to think of it that way.
    i.e. the ##m## in the relation is the rest mass. For a moving mass, the mass-energy relation is ##E=\gamma mc^2##.
    But you do have the frequency - for a photon: ##E=hf=hc/\lambda##
  7. Feb 8, 2013 #6
    Dick
    You were basically right the first time. E=p/c. Just put units on it! And 140eV is not 2.24*10^-34 J.
  8. Feb 8, 2013 #7
    Ha, yeah. Its getting late. Its 2.24*10^-17
  9. Feb 8, 2013 #8
    ah. haha. thank you mr planck.
    intuitively, i know that for photons, m=0
    but the course doesn't teach it that way. i don't really know what's what.
    E=hf
    f=E/h
    f=3.378582202*10^16 Hz
    λ=v/f
    λ=c/f
    λ=0.000000009m
    λ=9nm
    p=h/λ
    p=7.366666667*10^-26 Js/m
    I don't feel right about the unit.
    h is in Js and lambda is in m
  10. Feb 8, 2013 #9
    Dick
    If you put all that together you just get E=pc again. J*s/m=(kg*m^2/s^2)*(s/m)=kg*m/s. That's a mass times a velocity, so sure it's a good momentum unit.
  11. Feb 8, 2013 #10
