Why Do Monotonous Functions Have Only One Unique Solution?
  • Context: Undergrad
  • Thread starter Thread starter Physicsissuef
    Function
The discussion revolves around the properties of monotonic functions, particularly focusing on why such functions have only one unique solution for equations involving them. Participants explore definitions, examples, and the implications of monotonicity in various contexts, including specific equations.
  • Some participants assert that monotonic functions can only cross a horizontal line (e.g., y=0) once, implying a unique solution for equations of the form f(x)=a.
  • Others challenge the understanding of monotonic functions, questioning whether all functions are monotonic increasing or decreasing.
  • A few participants express confusion about the nature of specific functions and their monotonicity, particularly in relation to equations like 5^x + 7^x = 12^x.
  • There are claims that certain functions, despite being monotonic, can yield multiple solutions under specific conditions.
  • Participants discuss the definitions of monotonic increasing and decreasing functions, emphasizing the implications for the uniqueness of solutions.
  • Some participants provide examples of functions and equations, attempting to illustrate their points about monotonicity and solutions.
Participants generally do not reach a consensus on the nature of monotonic functions and their solutions. There are competing views on whether certain functions can have multiple solutions despite being monotonic, leading to ongoing debate and confusion.
Some participants express uncertainty about how to determine if a function is monotonic, indicating a need for clarity on definitions and methods of analysis. There are also references to specific equations that may not adhere to monotonicity, complicating the discussion.
This discussion may be of interest to students and individuals seeking to understand the properties of monotonic functions, their implications for solving equations, and the nuances involved in defining and identifying such functions.
Physicsissuef
Why there is only one solution of the monotonous functions, when all of the functions all monotonous?
For example, I read that this example is monotonius function and because of that have only one solution
5^x + 7^x=12^x
x=1
btw- how to solve monotonius functions?
In English that would be "monotonic". What do you mean by "all of the functions are monotonic? And my problem is not with your saying that 5^x + 7^x=12^x is monotonic but that it is a function at all! That is an equation. Perhaps you are confusing "function" with "equation" but in that case, I don't recognise the phrase "monotonic equation".
In any case, the definition of "monotonic" is that if f(x)= f(y) then x= y. You cannot have two different values of the independent variable giving the same value of the dependent variable.
That means, in particular, that if f(x) is a monotonic function then the equation f(x)= a, for any a, cannot have more than one solution- it has either no solutions or one.
There is no general method for solving equations involving monotonic functions. Many polynomial functions, of odd degree, are monontonic but there is no general method of solving them.
Yes, you are tottally right. I mistranslated all the things, and you are reading my mind... I was supposed to say, that every function is either monotonically increasing or monotonically decreasing. What is the difference between the functions \frac{5^x}{12^x}, \frac{7^x}{12^x} and some other function like 5^2^x=5^1
f(x)= \frac{5^x}{12^x}= \left(\frac{5}{12}\right)^x and g(x)= \frac{7x}{12^x}= \left(\frac{7}{12}\right)^x are functions. It would make no sense to say "solve for x" since x could be any number. The last, 5^{2x}= 5 is an equation (the "=" between two different functions is a give-away!). It is only true if x= 1/2.
I can't understand, why monotonic function have only one solution?
but also f(x)=5^2^x is monotonic function, so also 5^x(lets say 5^x instead of 5) must bee monotonic function.
5^2^x=5^x
Make it simpler, take f(x)=x and f(x)=2x. What about that? Should I dare to write x = 2x?
Are you looking for the intersection points of these functions? Because it seems like you are. Then, you can look for the unique arguments of these functions at the intersection points since they are monotonic.
No, I can't understand why monotonic function have only one solution?
If f(x)= f(y), which is larger, x or y?
Hi Physicsissuef! :smile:
"monotonic increasing" means that, if x < y, then f(x) < f(y).
So if f(a) = 0, then f(x) < 0 for all x < a, and f(x) > 0 for all x > a.
In other words, a is the only value of x for which f(x) = 0. :smile:
(If you draw a graph, isn't that obvious? :confused:)
But isn't all function monotonic increasing, or monotonic decreasing?
Hi ! :smile:
"monotonic decreasing" means that, if x < y, then f(x) > f(y).
In other words, the graph of a monotonic increasing function always goes up :biggrin: ,
but the graph of a monotonic decreasing function always goes down :cry: .​
"monotonic" doesn't mean single-valued (though the inverse of a monotonic function will be single-valued, over its range).
tiny-tim said:
Hi ! :smile:
then why everywhere that because of monotonic function it has only one solution?
Because, if y = f(x) is monotonic, it can only cross y = 0 once.
So there is only one value of x for which y = 0. :smile:
But it also have one value for x5^2^x-5^x=0
I don't understand. :confused:
Are you saying that 5^2^x - 5^x is monotonic increasing, but that 5^2^x - 5^x = 0 has more than one solution?
Yes. Some functions are monotonic increasing or decreasing, but they have 2 or more solutions.
ok, what are the two solutions of 5^2^x - 5^x = 0?
No, I am not talking about this function, I am talking about some function else, like:
5^x+5^2^x-6=0
ok, what are the two solutions of that?
y^2+y-6=0
y_1=2
y_2=-3
Ok, I wrong about this one.
But here is another one:
3^x^2^-^\frac{5x}{7}-3^\frac{2}{7}=0
the solutions are:
x_1=1 ; x_2=\frac{-2}{7}
Or this one:
(x-2)^x^2^-^3^x^-^4-1=0
it is x^2 up in there. Also for the previous example it is x^2 instead of x2
Hi Physicsissuef!
If you mean 3^(x^2 - (5x/7)) - 3^(2/7), that obviously is not monotonic - it is +∞ for both x = -∞ and +∞.
And the same for (x-2)^(x^2 - 3x - 4) - 1.
(btw, use more brackets, and less ^s)
Look, Physicsissuef, this is a waste of your time - if it's monotonic, it can't be 0 for two different values! :smile:
3^(x^2 - (5x/7)) - 3^(2/7), have 2 values which will give us zero. Only two, not more.
… "monotonic" means either "always down" or "always up" … !
Yes, but it's not monotonic!
It stats at +∞, it goes down, and then it goes up, to +∞.
"monotonic" means either "always down" or "always up"! :smile:
Ok, I understand now. Thanks. And is 5^x+7^x-12^x=0, monotonic decreasing or increasing?
I've no idea! :smile:
Why? :confused:
It is zero at negative infinity, nonzero until x=1 and then nonzero again. Thus, it cannot be monotonic. Because if it was monotonic, it should not come back to zero once it is nonzero, which gives you another hint about the derivative of such functions.
But keep in mind, that some people consider constant functions as monotonic, and distinguishing the nonconstant monotonic functions as "strictly" increasing and decreasing
Why did you think 5^x+ 7^x- 12^x is monotonic?
because of my book. It said like that.
5^x+7^x=12^x is monotonic function, that's why it has one solution
  • · Replies 33 ·
