Motion in a Plane: Ellipse, K.E, P.E, and Constant Energy
  • Thread starter Thread starter abramsay
    Motion Plane
The problem involves a particle of mass m moving in the xy plane, described by the position vector r = acos(wt)i + bsin(wt)j, where a, b, and w are positive constants with a > b. The tasks include demonstrating the elliptical motion of the particle, analyzing the forces acting on it, and calculating its kinetic and potential energies at specific points.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the equation of an ellipse and how to show the particle moves in such a path. There are attempts to differentiate the position vector to analyze the forces involved. Questions arise about how to calculate kinetic and potential energy at specific points without explicit time values.
Some participants have made progress in understanding the elliptical nature of the motion and the forces acting on the particle. There is ongoing exploration of how to derive kinetic and potential energies, with various interpretations of the relationship between position and time being discussed.
Participants note the absence of specific time values in the problem, leading to confusion about how to evaluate the energies at points A and B. The discussion reflects a need to clarify the relationship between the particle's position and time in the context of the given equations.
abramsay
A particle of mass m is in the xy plane so that it's position vector is r = acoswti + bsinwtj, where a, b and w are positive constants a>b.
(a)Show that,
i) The particle moves in an ellipse
ii) the force acting on the particle is always directed towards the origin
(b) Find the,
i) Kinetic energy of the particle at A(a,0) and B(0,b)
ii) Potential energy at A and B
iii) The total energy of the particle and show that it is always constant.
(a)
i) I know this is the equation of an ellipse: (x - h)2 / a2 + (y - k)2 / b2 = 1 but I find it hard to show the particle moves in an ellipse.
ii) I differentiated twice to get a = -w2r so the minus sign shows that it is always directed to the origin.
iii) For a force to be conservative, the curl must be equal to zero. I tried doing that and got zero.
(b) I'm somehow stuck. I tried using 1/2mv2 but I don't know where to plug in the A and B.
iii) I know I should add the potential and kinetic energy to get the total energy and differentiate it to get something without t, but since I would not get the P.E and K.E, I couldn't go any further.
abramsay;2871955(a) i) I know this is the equation of an ellipse: (x - h)[SUP said:
2[/SUP] / a2 + (y - k)2 / b2 = 1 but I find it hard to show the particle moves in an ellipse.
Well, if [itex]\textbf{r}(t)=a\cos(\omega t)\textbf{i}+b\sin(\omega t)\textbf{j}[/itex], what are [itex]x(t)[/itex] and [itex]y(t)[/itex]? What are [itex]x^2[/itex] and [itex]y^2[/itex]? Can you multiply each by some number, add together the results and get one?
Good...
Again, what are [itex]x(t)[/itex] and [itex]y(t)[/itex] if [itex]\textbf{r}(t)=a\cos(\omega t)\textbf{i}+b\sin(\omega t)\textbf{j}[/itex]?
You should be able to answer this without plugging in any points (like A and B). What is [itex]\textbf{v}(t)[/itex]? What does that make the kinetic energy (as a function of time)? If [itex]\textbf{F}(t)=-m\omega^2\textbf{r}(t)[/itex], what is the potential that gives rise to this force? What do you get when you add the two together?
Do you think what I did is right?
i) I squared both each component of i and j and divided by a2 and b2 respectively to get 1.
I assumed at A, the y component is zero, differentiated the x component, squared it and multiply by half the mass. Did the same at point B.
[/QUOTE]
You seem to be missing the point. If [itex]\textbf{r}(t)=a\cos(\omega t)\textbf{i}+b\sin(\omega t)\textbf{j}[/itex], then you can immediately say [itex]x(t)=a\cos(\omega t)[/itex] and [itex]y(t)=b\sin(\omega t)[/itex].
Ok, I got that side.
This is for getting the Kinetic energy at points A and B.
Okay, and what were your results?
I got it to be: 0.5m(aw2coswt)2 at A and 0.5m(aw2sinwt)2 at B.
But at each point (A and B), [itex]t[/itex] will have a definite value...what value of [itex]t[/itex] makes [itex]\textbf{r}(t)=a\cos(\omega t)\textbf{i}+a\cos(\omega t)\textbf{j}[/itex]
equal to point A [itex](a,0)=a\textbf{i}+0\textbf{j}[/itex]?
But no t was given or told to be found in the question...I think I'm confused.
I think you're confused too:wink:
At a particular time the particle will be at point "A" (and at some other time it will be at point "B"). Since you know the position of the particle at any time is [itex]\textbf{r}(t)=a\cos(\omega t)\textbf{i}+b\sin(\omega t)\textbf{j}[/itex], you can calculate what time the particle reaches "A" and what time it reaches "B".
