Mountain climber: average speed, angle, and vertical velocity
11 replies · 13K views · last reply
davidco
Brandon is climbing a mountain. He starts from an elevation of H1=511m above sea level. In 6.18 hours he climbs to an elevation of H2=2746m above sea level. The length of his path is L1=16000m.
A)What is the average angle of ascent the path makes with the horizontal?Theta=
B)What is his average speed along the path in meters/second? average speed=
C)What is his average vertical velocity? Vup=
D)After he eats he hikes back down to their starting point in T2=4.24 hours
What is his average vertical velocity? Vdown=
avg speed=total distance/total time
avg velocity=v=Delta x/delta t
tan theta=opposite/adjacent
A)tan theta=opposite/adjacent
Im so confused as to what equations to use.
B)avg speed= total distance/total time
16000M/22680S=0.705m/s
C)avg velocity=v=Delta x/delta t
D)Confused on D as well
Please give some suggestions or the correct equations will be great.thanx Dave
You are on the right track. If you haven't done it already, one thing that helps is to draw a picture.
For a, you have the correct equation. Hint: what does L1 represent in a simple idealized geometric shape?
For c & d: be careful. The problem says average vertical velocity.
Also, looks like you double posted by mistake.:smile:
Hotvette thanks a lot for the help just got a few more questions.
If your talking in terms of a triangle L1 would represent my hypotenuse I believe. So would 16000m be my hypotenuse is what your suggesting. But don't I have to choose the equation involving the hypotenuse to find the angle. Like:
sin theta= opp/hyp
or
cos theta= adj/hyp
But my question is what is the equation for vertical velocity?
Thanx Vette
For the angle yes, use:
sin theta = opp/hyp
average vertical velocity = vertical displacement/time
Thank you learn,
But I am wondering if my hyp=16000m and I am trying to find theta. what's my opp or how do i find my opp.?
davidco said:
Thank you learn,
What distance does he travel vertically? they give you initial height and final height...
Thanx Learn,
Ok so if I subtract the H2=2746m- 511m=my distance is 2235m
So to find theta I did this:
sin theta=opp/hyp
sin theta=2235m/16000
theta=7.98 degrees or 8 degrees
Please tell me this is correct
davidco said:
Thanx Learn,
sin theta=opp/hyp
yup, looks right to me. But I get 8.03 degrees.
Thanx,
For my average speed =total distance/total time,do I use the 16000m for total distance/6.18hrs or do i convert hrs to seconds. Since my answer has to be in m/s?
Question so if vertical speed= deltaV/T,would my deltaV= .705m/s?I got .705m/s from my average velocity equation which was 16000m/22680s=.705m/s for avgV. Is average vertical velocity and vertical velocity the same equation?
