Calculating Potential Energy in a Rotary Mousetrap Spring System
The discussion focuses on calculating the potential energy (PE) in a rotary mousetrap spring system, specifically addressing the relationship between the angle of the spring and the energy stored. The potential energy is derived using the equation PE = ½k(rΘ)^2, where k is the spring constant, r is the radius, and Θ is the angle in radians. The conversation confirms that the spring in a mousetrap is typically a torsion spring, leading to the alternative expression for potential energy as PE = ½kθ², where τ represents torque.
  • Understanding of potential energy calculations in mechanical systems
  • Familiarity with torsion springs and their properties
  • Knowledge of calculus, specifically integration techniques
  • Basic physics concepts related to torque and angular displacement
  • Study the principles of torsion springs and their applications in mechanical systems
  • Learn about the derivation of potential energy formulas in rotational dynamics
  • Explore experimental methods to measure spring constants in torsion springs
  • Investigate the relationship between torque and angular displacement in mechanical systems
Physics students, mechanical engineers, and anyone interested in the mechanics of rotary systems and energy calculations in springs.
JLT
Calculate the potential energy created by the spring in the mousetrap as a function of the angle the spring is pulled back.
PE = ∫Fdx = ∫ kxdx = ∫k rΘ rdΘ ??
Is this a linear spring? we can use x = rΘ, and dx = rdΘ, so PE = ½k(rΘ)^2
↑↑ does that look good to everyone, or is there a better soln to this?
Is this an experiment? What measurements could you take to help determine if it is linear and to determine k?
Is there a diagram with this?
It sounds like a so-called torsion spring. Mousetraps generally use those.
OK, although for a rotary system the spring constant is usually given as τ = kθ, τ = torque, then
p.e. = 1/2 kθ2.
  • · Replies 20 ·
