Movement vs expansion in space
  • Level: Graduate
  • Thread starter Thread starter exander
    Observer
49 replies · 4K views
Ibix said:
I was thinking that we have a reasonable idea that the number density of galaxies is homogeneous, but really we only know its isotropic because we're seeing back into the past and the visible density does vary with distance. We attribute that to ##a## varying only with time, but the "only" is an assumption derived from the cosmological principle.
Yes, exactly. In other words, our homogeneous model is consistent with the data we have (on large enough distance scales), but that in itself does not prove that the universe must be homogeneous (on large enough distance scales).
PeterDonis said:
... but that in itself does not prove that the universe must be homogeneous (on large enough distance scales).
What could prove "that the universe must be homogeneous (on large enough distance scales)"?
Would the detection of primordial gravitational waves be a prove? If that proves the correctness of the inflationary theory then I think that even if the creation of matter particles at the end of inflation doesn't happen exactly silmultaneous this would cause slightly different matter densities only locally.
PeterDonis said:
If we only need to satisfy isotropy, then any spherically symmetric spacetime will do (for example, Schwarzschild).
Spherically symmetric spacetime has only 3 linearly independent spacelike KVFs (Killing Lie algebra has dimension 3). They are rotational KVFs about a fixed point on any spacelike hypersurface of constant Schwarzschild coordinate time (contrast with a maximally symmetric spacelike hypersurface that has got ##3*4/2=6## linearly independent KVFs).
Therefore such spherically symmetric spacetime is isotropic only about a specific "spatial" location (i.e. about the points that a specific timelike worldline intersects any of the spacelike hypersurfaces of constant Schwarzschild coordinate time).
Strictly speaking, nothing. We don't prove physical theories - they are always provisional. However, going to a distant galaxy and checking that the universe appears isotropic from there too would spike Peter and my (pedantic and not terribly plausible) "it's just isotropic from our current location" objection. Or you could wait a few million years until you can see what the matter density in distant galaxies looks like it does now in our neighbourhood (although there may be model-dependent objections to that approach).
Same arguments apply, I'm afraid. It has to be said that the more independent bits of evidence you gather that are consistent with a homogenous model, the more contrived the isotropic-only model usually has to be. We'd usually prefer the less contrived model - but we don't ever strictly rule it out until it's directly falsified.
But at least experimental support for inflation would support the L-CDM model and thus postulates like homogeneity on which this model is based, right?
You would have to prove that there are no models that fit our current data that are not homogeneous.
Not specifically. Experimental support for inflation by itself does not tell us anything about what happens after inflation ends. The Lambda-CDM model is about what happens after inflation ends.
As far as inflation is concerned, you have this backwards. Inflation models predict that the universe will be homogeneous to a very high degree of accuracy at the end of inflation, in which case we would expect it to be homegeneous on large enough distance scales today. But that in itself doesn't support the Lambda-CDM model specifically. It just tells us that the general class of FRW models is the right general class to be using.
In general, yes. But note that FRW spacetimes that are homogeneous are spherically symmetric too. So a spherically symmetric spacetime can have more than just one set of 3 such KVFs.
Note that this way of looking at it assumes that the vacuum Schwarzschild region ends at the surface of an ordinary object, i.e., that we are not talking about a black hole. For a Schwarzschild black hole, there is no "fixed point". But the rotational KVFs are still there and the spacetime is still spherically symmetric.
Again, see the caveat I gave above.
Yes, but the volume of such "ordinary object" can be taken in principle as infinitesimal. Therefore the 3 rotational KVFs are about that "location", I believe.
If you give it a small enough mass, yes--but then you're making the spacetime very close to just being flat.
However, you don't need to do that. See below.
They are about the center of mass of the object. If the spacetime is spherically symmetric, the object must be, which means the rotational KVFs exist inside the object as well as outside. No need to make the object infinitesimal in size.
Just to clarify relations between homogeneity and isotropy:
- isotropy about a point obviously does not imply homogeneity
- isotropy everywhere (about all point) implies homogeneity
- homogeneity does not imply isotropy (there can be the 'same' preferred direction at every point, e.g. a cylinder for a case of 2-surface geometry)
- homogeneity plus isotropy about one point implies isotropy everywhere.
For a 2-surface the maximally symmetric condition requires ##2*3/2=3## independent isometries.
In the case of the cylinder there are only 2 KVFs (the translation KVFs) and no global "rotation" KVF about any point (i.e. any linear combination with constant coefficients of the 2 independent KVFs doesn't result in a "rotation" KVF about any point).
Yes, this is homogeneous but nowhere isotropic.
Nevertheless for the cylinder ##\mathbb S^1 \times \mathbb R##, as explained in this video at minute 36:00, the Killing equation has a third local solution that, however, cannot be globally extended as smooth KVF on the entire manifold.
Yes, this is obvious when you consider that the metric of the cylinder is flat: it's the same as the metric of the Euclidean plane. So locally it must have the same solutions to Killing's equation as the flat Euclidean plane does.
Yes, because the global topology of the cylinder is different from that of the Euclidean plane.
An instructive exercise is to consider the spacetime version of this, where the metric on the cylinder is the 1x1 Minkowski metric.
In other words there is not any finite diffeomorphism/isometry that "rotate" points about any point on the cylinder.
No, there is not any global isometry that does that for the entire cylinder. But there are local isometries that do it for finite open regions centered on some chosen point.
Ah ok, yes. Just take a finite open region and unroll it on the plane.
