Multiplying Fractions Clarification
  • Thread starter Thread starter swingGG
    Fractions
Multiplying fractions involves multiplying the numerators and denominators directly, but simplifying can make the process easier. In the example given, the transition from 2*5/3*12 to 1*5/3*6 occurs by dividing both 2 and 12 by their common factor of 2. This simplification is valid because it maintains the equality of the fraction, as dividing by a number is equivalent to multiplying by one. Understanding prime factorization can help identify common factors for simplification, although it is often quicker to spot small common factors directly. With practice, recognizing these simplifications becomes intuitive, enhancing overall mathematical proficiency.
swingGG
Hi! I am quite new at Maths in general, just recently started get an interest for it (Aswell as general physics/philosophy) and I am trying to learn on my own, so if this question is totally retarded, feel free to let your anger out haha.
Anyway, I borrowed a book from a friend that looked fun, "Mathemathics for Engineers".
And after 5 pages i ran into some trouble, with one of the explanations in the book.
So they show how we multiply fractions, this is the example used:
\frac{2}{3} * \frac{5}{12} = \frac{2*5}{3*12}=\frac{1*5}{3*6}=\frac{5}{18}
So what I am not really understanding is how we go from \frac{2*5}{3*12} to \frac{1*5}{3*6}.
What it looks like is that they have divided 2 by 2 and 12 by 2. I understand why this is done, to shorten the number down, the results will still be same, 5/18 or 10/36. But why the 2 and 12? Just because they are the easiest ones to shorten? And if so, which are the rules for shortening numbers down?
Mathematics news on Phys.org
Well, you could expand your fraction first as:
(2*5)/(3*12)=(2*5)/(3*2*6) Agreed that this is legal, writing 2*6 instead of 12?
Now, knowing the multiplication rule, you can do it BACKWARDS as well, writing:
(2*5)/(3*2*6)=(2/2)*(5/(3*6)) (That is, "demultiplying" the fraction 2/2 from the other fraction!)
But, a number divided by itself equals 1, so you get:
(2/2)*(5/(3*6))=1*(5/(3*6)).
Since multplying any number with 1 equals itself, we may collect our results as, precisely,
(2*5)/(3*12)=5/(3*6).
The details of why this works has to do with prime numbers. Essentially every number can be expressed as a multiple of prime numbers, such as
6 = 2*3
12 = 2*2*3
18 = 2*3*3
etc.
And prime numbers are already in the form we require, so
7 = 7*1
So if we took the long approach of changing every number in the fraction into its prime number factors, we would get
\frac{2*5}{3*12} = \frac{2*5}{3*(2*2*3)}
Now, all we need to do from here is cancel out any common factors from the numerator and denominator, so we cancel out 2.
If we were to try and cancel say, the 5 and 3 or the 5 and 12, we will quickly realize there is no way to do it. Why? Well, just as how we could express every number as a multiple of primes, the theorem also states that every number has a unique representation of prime multiples. You can't multiply some prime numbers together to get a number and then find other primes to multiply together to get to that same number.
But of course we aren't going to take this long approach of breaking each number down into its prime factors, then cancelling. After enough practice, you should just be able to spot small common factors and cancel them instantly. For example, in the problem you presented, the 2 and 12 were both even, so they both have a factor of 2, so you'd start by cancelling that.
Thanks a lot for the fast replies! <3 Understand it now!
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
11K
10K
10K
