Multivariate calculus problem: Calculating the gradient vector
The discussion focuses on calculating the gradient vector for a function using multivariate calculus. The partial derivatives are determined as ##f_x = \frac{2\ln{(x)}}{x}## and ##f_y = \frac{2\ln{(y)}}{y}##, leading to the gradient vector ##\nabla{f} = \begin{bmatrix} \frac{2\ln{(x)}}{x} \\ \frac{2\ln{(y)}}{y} \end{bmatrix}##. Additionally, the derivative of the vector function ##\mathbf{r}(t) = \left(\cos{(t)}e^{\sin{(t)}},-\sin{(t)}e^{\cos{(t)}}\right)## is discussed. The application of the chain rule is emphasized, particularly in the context of deriving composite functions.
  • Understanding of multivariable calculus concepts
  • Familiarity with gradient vectors and partial derivatives
  • Knowledge of the chain rule in calculus
  • Ability to interpret vector functions and their derivatives
  • Study the properties of gradient vectors in multivariable functions
  • Learn how to apply the chain rule in multivariable calculus
  • Explore the concept of open sets in calculus
  • Practice calculating derivatives of vector functions
Students and professionals in mathematics, particularly those studying multivariable calculus, as well as educators looking to clarify concepts related to gradient vectors and derivatives.
squenshl
Let ##U := \left\{(x,y)\in \mathbb{R}^2: xy\neq 0\right\}## and let ##f: U\mapsto \mathbb{R}## be defined by
$$f(x,y) := (\log_{e}{(|x|)})^2+(\log_{e}{(|y|)})^2.$$
1. Calculate ##\nabla f(x,y)## at each point of ##U##.
2. Let ##\mathbf{r}: (0,1)\mapsto \mathbb{R}^2## be defined by ##\mathbf{r}(t) := \left(e^{\sin{(t)}},e^{\cos{(t)}}\right).##
Calculate the derivative of ##\mathbf{r}## at each point of ##(0,1).##
3. Justify whether you can use the chain rule to calculate the derivative of ##f\circ \mathbf{r}.##
If it is justifiable, calculate the derivative of ##f\circ \mathbf{r}## using the chain rule.
None
1. We find the partial derivatives of ##f## with respect to ##x## and ##y## to get ##f_x = \frac{2\ln{(x)}}{x}## and ##f_y = \frac{2\ln{(y)}}{y}.## This makes the gradient vector
$$\nabla{f} = \begin{bmatrix}
f_x \\
f_y
\end{bmatrix} = \begin{bmatrix}
\frac{2\ln{(y)}}{y}
\end{bmatrix}.$$
2. We have
$$\mathbf{r}'(t) = \left(\cos{(t)}e^{\sin{(t)}},-\sin{(t)}e^{\cos{(t)}}\right).$$
After this I'm a little confused. Any help is appreciated.
For (3), what does your version of the chain rule say?
If your multivariable calculus textbook is rigorous, it might also want you to show that ##U## is an open set (which is easily seen by a drawing).
The derivative of ##\mathbf{r}## at each point of ##(0,1)##?
That confused me initially too. It would be clearer if it said "at each point in the open interval (0,1)."
Okay (1) and (2) are done.
So for (3), assuming ##t > 0##, ##f\circ \mathbf{r} = \ln{(e^{\sin{(t)}})}^2+\ln{(e^{\sin{(t)}})}^2 = \sin^2{(t)}+\cos^2{(t)} = 1## so the derivative is ##0##.
For #3, you need calculate the derivative using the chain rule if it can be applied.
Okay then I’m lost how do we then justify whether to use the chain rule?
I'm sure the conditions are stated in your textbook or were covered in lecture. Look them up.
