My calculator gives wrong values
  • Context: Undergrad
  • Thread starter Thread starter zorro
    Calculator Casio
18 replies · 16K views
zorro
I use a Casio fx-991MS calculator.
I observed this strange thing during some calculations.
Setting up the calculator in radian mode, I found out the sines of various angles (multiples of π) display showed 0 for lower values.
However when I entered angles from 1201π onwards, the answers were like-
sin(1201π) = 1.59 x 10-9
sin(1202π) = 4.82 x 10-9
sin(1203π) = -1.23 x 10-9
sin(1204π) = -2.36 x 10-9
I got 0 for sin(1220π) and some other numbers but mostly unexpected values for higher numbers.
I would like to find out if there is any different method in which a calculator finds out the value of sine of multiples of π in radian mode.
Mathematics news on Phys.org
Could it be that the internal representation of pi is getting rounded off and at these high values it's not be exact enough to be re-recognised as a multiple, so in effect you are calculating sin(0.00000001) (by taking away 2pi until it's in an acceptable range) or similar?
Well that might be a possible explanation but sine of some still higher values like 6000π is shown 0.
It could just be luck of the draw that the number it's ouputting for 6000 pi is small enough to come up as zero
Rounding errors.
That's just another name for what was already suggested.
Bingo! Pi is an irrational number; your calculator cannot represent it exactly. Your calculator cannot even represent 1/3 exactly. When you multiply 1201*pi on your calculator you do not get 1201*pi; you get something close to it.
Suppose you ask the calculator to calculate the sine of some number, call it x. The first thing your calculator is going to do is convert x to (pi/2) * some integer plus a remainder between -pi/4 and pi/4. If your calculator was exact it would get 2402*(pi/2)+0 for 1201*pi. Since your calculator is not exact it will instead get 2402*(pi/2) + some small number.
I have a $20 Sharp EL-520W that I've been using for about 15 years now. I can't find a multiple of [itex]\pi[/tex] that gives a non-zero result for SIN.[/itex]
[itex] <br /> It may calculate to more decimals than it shows. But I imagine if you go large enough you can still fool it; pi * 10^20, for example.[/itex]
[itex] <br /> Did you try in Radian mode?[/itex]
There you go. SIN(Pi * 10^20) results in an overflow error on my calculator, as does any power of 10 greater than 7.
In other words, SIN(Pi * 10^8) results in overflow, but SIN(Pi * 10^7) = 0.
BUT ... SIN(Pi * (10^7 + 1)) = SIN(Pi * 10,000,001) = 0.000001745 (approx)
and SIN(Pi * (10^7 - 1)) = SIN(Pi * 9,999,999) = 0.000001745 (approx)
It seems to start breaking down after SIN(Pi * 555,555)
... and, yes, this was in Radian mode.
I found something new again-
Input - sin(1201π) = 1.59 x 10-9
But sinπ(1201) = 0!
If I write any value this way (no matter how high), it shows 0!
@zgozvrm
Can you try this thing in your calculator?
But sinπ(1201) = 0!
@zgozvrm
That one's easy:
[tex]\sin \pi * (1201) = 0 * (1201) = 0[/tex]
Your calculator evaluates [itex]\sin(\pi)[/tex] first.<br /> Note that [itex]\sin(xy)[/tex] does not necessarily equal [itex]\sin(x)*y[/tex][/itex][/itex][/itex]
I take it from Abdul's post that he is asking you to calculate sin(pi*1201) versus sin(1201*pi).
Hint: a*b-b*a is not necessarily zero on your calculator or on a computer.
In that case, I get the same result:
[tex]\sin(\pi X) = \sin(X \pi) = 0[/tex]
for all values of X such that [itex]0 \le X \le 555,555[/tex][/itex]
Yes I meant that but I thought the calculator will understand sinπ(1201) as sin(π1201) which is wrong.
[itex] <br /> Only integer values of X <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":biggrin:" title="Big Grin :biggrin:" data-smilie="8"data-shortname=":biggrin:" />[/itex]
Abdul Quadeer said:
Only integer values of X :biggrin:
Yes, of course.
[itex] Wow, I can't believe you tried every value in that range! <img src="https://www.physicsforums.com/styles/physicsforums/xenforo/smilies/oldschool/bugeye.gif" class="smilie" loading="lazy" alt=":bugeye:" title="Bug Eye :bugeye:" data-shortname=":bugeye:" /><br /> <blockquote data-attributes="" data-quote="Abdul Quadeer" data-source="post: 2975383" cite="https://www.physicsforums.com/goto/post?id=2975383" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> Abdul Quadeer said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Only integer values of X <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":biggrin:" title="Big Grin :biggrin:" data-smilie="8"data-shortname=":biggrin:" /> </div> </div> </blockquote>Hmmm, okay, but still...[/itex]
