My notes for this chapter suck, so I
  • Thread starter Thread starter billbennett770
    Notes
7 replies · 2K views
billbennett770
Given the continuous probability density function f(x) = (x-2)/18 2 ≤ x ≤ 8, find P(6<x≤8)?
For a continuous random variable, if you have a pdf f(x) on the interval a to b,
P(c≤x≤d)=∫dcf(x)dx
E(X)=μ=∫baxf(x)dx
Var(X)=∫ba(x−μ)2f(x)dx
For this problem, you are given with pdf f(x) and the interval is given. So you need to evaluate the integral.
∫baf(x)dx= ∫8,2((x-2)/18))... I honestly lose it from here.
P(c≤x≤d)=∫dcf(x)dx
E(X)=μ=∫baxf(x)dx
Yes, your notes are a mess. Let's see if we can straighten things out.
For this problem, the expectation E(x) and the Variance Var (x) are not required.
You are given a certain probability density function (pdf) and asked to find the probability that x will lie between 6 and 8.
The cumulative density function (cdf) is the integral of the pdf from -∞ to +∞ and by definition:
[itex]\int^{∞}_{-∞}[/itex][pdf (x)] dx = 1
This is not a difficult integral to evaluate since your pdf = 0 except between x = 2 and x = 8.
You should check your pdf to make sure that the relation above is satisfied.
Since the area of the pdf over the entire range of x is 1, this means that all possible outcomes of whatever the pdf represents have occurred. If you want to find the probability of occurrence of whatever is represented by the pdf on a certain interval of x, you would take the integral of the pdf between the limits of that interval.
okay then. From P(6<x≤8)
∫ f(x) dx = ((x²/2) -2x)/18
at x = 6 : ((6²/2) -2*6)/18= (18 -12)/18 = 1/3
at x = 8 : ((8²/2 -2*8)) = ((32 -16))/18 = 16/18 = 8/9
: 1/3 < P(6<x≤8) ≤ 8/9
Not as well I thought I did, or at least not how it pertains to continuous proability density. First, I am really perplexed why I am given 2 ≤ x ≤ 8 --or is this just another way of saying [2, 8]? Also, how do you evaluate P(6 <x ≤8)? I have only done int he past when the question employs both ≤ and , as in P(6 ≤x ≤8).
For example, here is a previous question I did:
Is f(x) 2/(x^2) on [1,2] a probability density function? Why or why not? If it is, find P[1.5 ≤ x ≤ 2]
∫ba f(x)dx = 2,1 2/(x^2) dx = [-2/x] 2, 1 = -1+2=1
So yes because it is positive.
∫1,5,2 (-2/x) = 1/3
So it it just (8/9) - (1/3)
Exactly the same as it does to anything.
That just means that f(x) is defined on that interval.
What is ##p(2\leq x\leq 8)## - evaluate it.
Yes. ##x\in (2,8]## is the same as saying ##2<x\leq 8##
The probability is the area under f(x) inside the range. The difference in area inside a<x<b and inside a<x≤b is zero. Sketch it out for a bunch of arbitrary functions and see.
There you go.
