MySQL: Using Aliases & Old Names
  • Thread starter Thread starter EdmureTully
    Mysql
3 replies · 2K views
EdmureTully
If you rename an attribute or a relation with the keyword AS in MYSQL can you use the alias created outside the query where you renamed the attribute, also can you use the old name?
Not that I am aware of.
The database does not store aliases you used in some query.
Interesting, I never tried that. It is not possible.
SELECT * FROM `tablename` AS t WHERE t.fieldname=1 -> works
SELECT * FROM `tablename` WHERE tablename.fieldname=1 -> works
SELECT * FROM `tablename` AS t WHERE tablename.fieldname=1 -> does not work ("Unknown column 'tablename.fieldname' in 'where clause'")
If you have some good reason for having external (global) aliases to columns or tables then you can create a view
