Mystery noise in flue (no, it's not a critter)
  • Thread starter Thread starter DaveC426913
The discussion revolves around a peculiar noise emanating from a chimney flue, described as a rapid beating sound occurring 10 to 15 times a second. Participants explore various hypotheses regarding the source of the noise, considering both biological and mechanical explanations, while noting the noise's timing and characteristics. The context includes potential connections to the operation of a forced air furnace and the structural features of the chimney.
  • One participant describes the noise as a "thoomp" sound, suggesting it resembles a small plastic door slamming rapidly.
  • Another participant proposes that the noise could be caused by a woodpecker, sharing a personal experience with similar sounds.
  • Some participants suggest that the noise might be related to the operation of the cooling system, speculating it could be a pump or an off-balance fan.
  • There are suggestions to investigate the chimney using an inspection camera or to check for woodpecker activity.
  • A hypothesis is raised about the possibility of an active damper in the fireplace being linked to the HVAC system, potentially causing the noise due to a malfunction.
  • Some participants express skepticism about the woodpecker theory, noting the sound's characteristics and the location of the noise.
  • One participant mentions the possibility of a bat flapping its wings, although this is met with humor regarding the size of the bat required.
  • Another participant suggests that the ornamental flue might contain a fan rather than a pump, which could explain the noise.
Participants express a range of competing views regarding the source of the noise, with no consensus reached. Some lean towards the woodpecker explanation, while others propose mechanical causes related to the HVAC system or the chimney structure.
Participants note limitations in their ability to investigate the chimney directly and the uncertainty surrounding the noise's relationship to the HVAC system. The discussion reflects various assumptions about the functionality of the ornamental fireplace and its components.
This discussion may be of interest to homeowners experiencing similar unexplained noises in their chimneys or those curious about potential interactions between HVAC systems and chimney structures.
DaveC426913
2025 Award
TL;DR
A noise has started in my chimney flue that I can't identify
Just on the last few days a noise has started in my chimney flue that is quite peculiar.
Please read the full description before posting theories. I've consider as many as I can think of.
  • The noise is a beating. It is a whamming about 10 to 15 times a second. Sharp, rapid.
  • Lasts about a second. Not sure if it is always exactly the same length. It may occasionally last 1.5 seconds.
  • It is an active whamming; not just flapping. It's too fast and too sharp to be just passive flapping.
  • It does not peter in or peter out, and it does not change rhythm - at all. i.e. artificial - not biological.
  • The sound each beat makes sounds to my ear like a small plastic door (like a flue) slamming open and closed very fast. Each beat makes a "thoomp" sound, but so fast it's just "TBTBTBTBTB!"
  • The happened about eight times within 15 minutes yesterday, and then stopped, and then once today so far.
  • The fireplace is not functional - purely decorative.
  • I don't really have an option to open the chimney and look up the shaft.
  • The noise emanates from near the ceiling on the inside. From the roof on the outside.
  • I went out and looked at the chimney but there's nothing to see. I was able to hear the noise from the outside so I can tell it is coming from the chimney flue, i.e. not from within the house.
  • My house is built in the last half century or so. This is my chimney. That corner of the house is an angled fireplace (fake).
    Drat, you can't see it in Street View:
There are only three (four) things I can think of that a noise even close to this:
- an electromagnetic doorbell ringer / damped fire alarm bell ringer
- a woodpecker
- a clapper:
I am not suggesting that's what this is, simply it sounds like nothing else. It's too fast and perfect.
Things it is not:
It is not a critter.
It is not the wind. (there was no wind either day)
Things it might be related to:
The only thing that coincides with the sound, the location and the sudden onset on this new noise is that we just recently turned the forced air furnace from heat to cool. Wondered if @russ_watters had any opinion.
DaveC426913 said:
- a woodpecker
That's what it was when it happened to me. Is there a chance you couldn't see the bird when you looked if it was on the other side of the chimney top? What is the chimney top/guard made of? Ours was aluminum, and the dummy didn't seem to care. Eventually I was able to chase it away with tennis balls...
  • Haha
BTW, you could ask a few neighbors if they hear the same thing. Our nextdoor neighbor had the same issue with woodpeckers in the past.
Chimney is brick, topped with ceramic flues.
This is pretty close, but two flues, not one:
It has no cap as far as I can see. Not sure how that works.
If it were a woodpecker, it would have to be inside. When I was outside looking up, the sound was def coming from inside, muffled, echo-y.
Can you get up on the roof and look down the chimney with a strong flashlight? If you see woodpecker divots, that would explain it. You should probably cap that chimney anyway (unless it's sealed) to keep the rain out.
Does the noise cease to happen if you turn the cooling function off?
The 10 - 15 Hz "wham" could be a pump or an off-balance fan associated with the cooling system.
It could be a bat, flapping its wings, prior to receiving takeoff clearance.
I have yet to associate it with the air system. I only suspect it because of the location (in the flue) and the seasonal timing.
It really, really does not sound like anything coming up to speed or anything coming down to off. It's perfectly regular in period, pitch and amplitude - from the first thunk to the last - like an electromagnetic doorbell chime (if you muted the actual chime).
I know pump sounds from my old house. They sound like a pump coming online and going offline. This does not.
It would have to be a big bat.
  • Wow
It's only the large ones that require ATC clearance.
  • Haha
See if you can find a willing plumber with a sewer inspection camera to investigate the chimney interior. You might even be able to rent an inspection camera somewhere.
Oh, and please keep us updated on any results , or lack thereof.
Cheers,
Tom
A little stream of droplets of water sometimes gets into an electrical cable in a confined space... ?
Assumption:
Ornamental fireplaces don't have flues/chimneys. Whoever built it intended it to function.
Hypothesis:
There is a potentially large advantage in controlling the source of the combustion air for a fireplace. Depending on the mode of your HVAC (heat, vent, cool), the 'best' source varies. Your fireplace has an active damper controlling combustion air - it is slaved to your HVAC Mode. When the HVAC operates, the damper initializes. A bad position sensor (worn out spot on the potentiometer) on the damper will cause the sound that you describe - in terms of both regularity and duration.
Second-Hand Evidence:
I'd love to claim that I just thought of this scenario. Sadly, this is the sound that I hear every time that I start my truck. The mix damper in my AC system has this issue. I actually have the replacement part in hand, but can't bring myself to take the dash apart to fix an annoying (but brief) problem.
Or not.
Perhaps the ornamental flue has a fan, not a pump. The lowest spectrum look likes a small one-speed electric fan fitted in the flue.
My vote is for a woodpecker, assuming that they are present in your area. Around here, we have one that often pecks on our metal flue cover early in the morning, presumably to announce his presence to other woodpeckers and to claim his territory. The sound is pretty much as you describe it (only more metallic.)
If I had to bet on it, this, or something like it, is where I would place my money.
You would expect a fan to spin up-to-speed, especially if it is whamming away on something.
If the noise is regular enough, and you can get by without electricity for a bit, turn off the power and see what happens. You may even be able to be standing with your hand on the main breaker/switch and turn off the power mid-rattle. See what happens. My guess is it's a woodpecker.
Alas, it is not regular enough. It happened about eight times in the space of an hour on day 1, once on day 2 and, so far, not at all today.
Okay, this is a long shot, but do any of your neighbors have a Ring doorbell camera or other camera that has a view of your chimney? If they do, you could ask them to take a look at the times you've heard the noise to see if any birds/bats were flying in or out of your chimney.
Alternately, if you have a WiFi camera of some sort, you could reposition it to have a view of your chimney...
Is it associated with the wind?? Seems like 10Hz could be a resonance of the chimney stack. Is the chimney cap solid and robust? The damper?
No wind. First thing i checked.
hutchphd said:
The damper?
Damper is a possibility, except it's so regular and short and ... whammy. Like an electromagnetic doorbell contraption.
I would check whether the chimney is equipped with a butterfly valve/flap to limit unwanted airflow - and that whether there is any other possible source for sudden air pressure change in the house than wind.
A flap is my assumption. That's what it sounds like.
It has not recurred. I can only assume it is closely tied to the household air system switching from heating to cooling at that time.
Or if the chimney temperature s slightly cooler than its surrounding air, there can be pressure to produce a backward flow. This might set something aflutter.....maybe the AC has some lightweight plastic air control flaps?
Yeah, but this is a pretty deliberate whammywhammywham. Like it's being powered, and like it's in a loop.
On second thought, the frequency is too high (10Hz, did I take that right?). Just as you said, like it was powered...
Any chance for a chimney-length resonance?
:oldconfused:
Like an organ-pipe, I mean.
No, I get what resonance is in a pipe, but of what?
Here, have you ever seen one of these?
You hold it by the handle and shake it back and forth and it makes a sharp, fast whapwhapwhapwhap sound.
You cannot make it slow down and you cannot make it quieter. it's either whapwhaphwhap or nothing.
That's what this sounds like, but up in the flue (so, hollow and echoey)
  • · Replies 16 ·
  • · Replies 25 ·
  • · Replies 54 ·
11K
  • · Replies 42 ·
10K
  • · Replies 28 ·
33K
  • · Replies 31 ·
