DaveC426913 said:
Hint: same decade, still sci-fi genre. A cult classic.
I got it, "The Adventures of Buckaroo Banzai Across the 8th Dimension"
That was good one, especially because there was a "red herring" involved. Nashville (1975). I was just about to post that answer but wanted to double check and make sure I found the image that you posted. I couldn't find it. So I kept at it and found Buckaroo.
Here's the image I found from Nashville that almost caused me to post the wrong answer:
phinds said:
Jeff Goldblum but I forget the movie
EDIT: OK, I know what it is now. Can't even remember if I saw it, but since I love Jeff G. I probably did.
Yeah, my conclusion is that the rules are too hard. So the revised rules is that the only thing you
can't do is upload the image to google images (or equivalent). Anything else is fair game. So in this case, I took the fact that I knew it was Jeff Goldblum, and then I typed his name into google along with "white scarf" and "cowboy hat." And even after that I almost got it wrong because Buckaroo didn't show up, only Nashville.
So if you're presented with an image whereby you don't even recognize the character, you're going to be in big trouble. Therefore, google searching is OK to use through using clues in the image. So I'm going to try and be clever with my next image not to give away too many clues. But at the same time you should include enough clues not to make it impossible...
Ok, here's an easy one:
