NaN error in Fortran bubble radius calculation using RP model
  • Topic: Fortran
  • Thread starter Thread starter shipman
    Error Fortran
4 replies · 4K views
shipman
Hi to everyone,
I am quite new to forum and fortran. Basically, i am trying to calculate the bubble radius using RP model and this is my code:
Code:
	IMPLICIT DOUBLE PRECISION (A-H,O-Z)
	IMPLICIT INTEGER (I-N)
C	! Declare local constant Pi
	REAL, PARAMETER :: Pi = 3.1415927D0
C	*************************************************************
C	*    OUTPUT VARIABLES                                        *
	OPEN (10,FILE='DT12.csv',STATUS='UNKNOWN')
C	************INPUT   VARIABLES**************
      DT=1.0D-12	!time step
	TEND=8.0D-4 ! ENDTIME
      DIN= 8.0D-4    !Initial BUBle Dia ometer
C	********   SOME   VARIABLE DATA*****************
      ROL  =1.0D3  ! DENSITY   [LIQUID] kg/m-3
      DMYUL=1.002D-3 ! VISCOSITY [LIQUID]
     	PV=2.3D3    ! SATURATION PRESSURE
	SIGMA=7.277D-2 ! SURFACE TENSION
	BETA=1.4D0    ! pressure parameter
	VO=4.78D-9 !constant bubble volume
	PO=1.00072D5 !used in pres. calculation
	RO=0.5D0*DIN   ! BUBBLE RADIUS AT OLD TIME STEP
	R =0.5D0*DIN !0.5D0*1.07D-3  ! CURRENT BUBBLE RADIUS
	! Initial bubble volume
	VB= 4.0D0*Pi*(RO**3.0D0)/3.0D0
	PG = PO*(VB/VO)**BETA ! PRESSURE OF NON-CONDENSING GAS
	PBUB  =PG +PV !bubble pressure
	PSUR=1.01325D5 !enviroment pressure=constant
	TP    =0.0D0
	N     =0
C	************OUT PUT  INFOMATION*******************************
      NDATA=INT(TEND/DT)
      WRITE(*,100) DIN*1.0D3
      WRITE(*,300) NDATA
C	**************************************************************
C	 ***************LOOP 1  START*********************************
10    TP=TP+DT
      N=N+1
	! Solving RP equation
      RR=(PBUB-PSUR
     &    -4.0D0*DMYUL/DT*(R-RO)/R
     &    -2.0D0*SIGMA/R)/ROL
      RNE=2.0D0*R-RO-1.5D0*(R-RO)**2.0D0/R+DT*DT*RR/R
	 ! BUBBLE RADIUS AT NEW TIME STEP
	IF(RNE*2.0D0.LE.0)   RNE= 0.5d0*DIN
	IF(RNE*2.0D0.GE.2.0d-3)   RNE= 2.0d-3
	VB= 4.0D0*Pi*(RNE**3.0D0)/3.0D0
	PBUB  =PG+PV !bubble pressure
      DRDT=(RNE-R)/DT
	RO =R
	R  =RNE
	RNE=0.0D0
C	*						 OUTPUT                              *
C	*********************WRITE( *,400)*****************************************
	IF (MOD(N,NDATA/10000).EQ.1) THEN  !screen display data
       WRITE( *,400) N,TP,((3.0D0*VB)/(4.0d0*Pi))**(1.0d0/3.0D0)*1.0D3,
     & PG/1.0d6,DRDT
	end if
	if (MOD(N,NDATA/10000).EQ.1) THEN  !csv.data
     & PG/1.0d6,DRDT
      END IF
     	IF (TP.LT.TEND) GOTO 10  !time iteration
	goto 101
C *    LOOP END                                               *
C
101   write(*,*)RNE
  100 FORMAT('INITIAL DIAMETER(um)='F6.2)
  200 FORMAT('LIQUID PRESSURE(kPa)='F6.2)
  300 FORMAT('CYCLE NUMBER='8X,I16)
  400 FORMAT(I13,4(1X,1H,E13.6))
	CLOSE(10)
	STOP
	END
could someone tell me that why i get NaN error when i run the program?
Best Regards
Could you provide some more detail about how the program informs you that the NaN error has occurred?
What is the exact wording of the NaN error message?
took the source
saved the file as *.f90
replaced all "C" in first column for "!"
removed continuation marks "&" and simply glued lines back together...there is room
increased time step from e-12 to e-8, for good measure
compiled program
run it
First few lines:
Code:
INITIAL DIAMETER(um)=  0.80
CYCLE NUMBER=                   79999
            1 , 0.100000E-07 , 0.400000E+00 , 0.177292E-02 ,-0.291038E-02
            8 , 0.800000E-07 , 0.399999E+00 , 0.177290E-02 ,-0.232831E-01
           15 , 0.150000E-06 , 0.399996E+00 , 0.177286E-02 ,-0.436557E-01
           22 , 0.220000E-06 , 0.399993E+00 , 0.177278E-02 ,-0.640284E-01
Last few lines:
Code:
        79927 , 0.799872E-03 , 0.200000E+01 , 0.152885E+01 , 0.000000E+00
        79934 , 0.799942E-03 , 0.200000E+01 , 0.152885E+01 , 0.000000E+00
   0.00000000
Thank you so much for your all kind replies. Yeah "gsal" finally i could run the program correctly. I found that NaN shows mathematical error which can be derived from dividing by zero...Thank you
