Why is the natural frequency of a cantilever beam higher than a spiral spring?
The natural frequency of a cantilever beam is significantly higher than that of a spiral spring due to differences in their stiffness calculations. The formula for the natural frequency of a spiral spring is given by fn = 1/(2*pi) * sqrt(k/m), where k is derived from the spring constant. For a cantilever beam, the natural frequency is calculated using f = 1/(2*pi) * sqrt((3*E*I)/(l^3*m)), where E is the elastic modulus, I is the inertia of the cross-section, and l is the length. The calculations provided indicate a natural frequency of 1 Hz for the spiral spring and 46.6 Hz for the cantilever beam, highlighting the impact of geometry and material properties on frequency.
  • Understanding of natural frequency calculations
  • Familiarity with mechanical properties such as elastic modulus and moment of inertia
  • Knowledge of cantilever beam theory and spring mechanics
  • Ability to perform basic mathematical calculations involving square roots and constants
  • Study the derivation of the natural frequency formula for cantilever beams
  • Research the stiffness calculation for helical springs as described by Shigley
  • Explore the effects of geometry on the natural frequency of different mechanical structures
  • Learn about the relationship between material properties and vibrational characteristics in mechanical systems
Mechanical engineers, students studying dynamics, and professionals involved in structural analysis and design will benefit from this discussion.
Sami Lakka
Hi
Natural frequency of spring is fn = 1/(2*pi) * sqrt(k/m), where k = spring constant and m is the mass.
Ok, so I have a spiral spring which means that spring is coiled couple of times. Its spring constant is (according to Hartog's Mech. Vibrations), k = E*I/l, E=Elastic Modulus, I = Inertia of cross section and l = length. All good at this point.
Now I straighten the coil so I get an cantilevered beam. Its natural frequency is (according Hartog):
So assume we have a beam with 1 mm width and 10 mm height. Let's plug couple of values:
E=22*10^9 Pa, I = b^3*h*1/12, b=1*10^-3 m, h= 10*10^-3 m, l = 40*10^-3 m
m = 0.01 kg (just some value)
f (spiral spring) = 1 Hz
f (cantilevered beam) = 46.6 Hz (??)
Why is the natural frequency of the cantilever beam so much higher than the spiral spring? Am I using wrong equations?
For a standard helical spring, Shigley states the stiffness is:
k = \frac{d^4 G}{8D^3 N}
Where d is the wire diameter, G is the shear modulus, D is the spring diameter, and N is the number of coils. Your formula doesn't take into consideration the number of coils. May I ask where you got it from.
  • · Replies 22 ·
