Natural log's and trigonometric identity's.
7 replies · 12K views · last reply
stf
prove the identity.
ln csc(x) = -ln sin(x)
With a calculator I am able to prove it is in fact an identity, but I have NO clue why? In fact I am quite unclear on logarrithms in general as my algebra class just barely covered them and did not mention the natural log's at all except in passing (As "it would be covered in calculus")...So any help is great as to what's going on!
stf said:
prove the identity.
ln means logarithm base e, where e is about 2.71828.
What properties of logarithms, in any base, do you know? One of them is the key to this problem, along with one trig identity.
Ok, Revisiting logarithm rules, it looks like it would be ln 1/sin = ln 1 - ln sinx, so I am assuming that ln 1 = 0 which gives the equation...I still don't fully understand why ln 1 equals zero though...I suppose I need to revisit all this old material. Thanks.
Yes, or equivalently, there's another rule that states [tex]ln(a^b)=b*ln(a)[/tex] and in this case [tex]csc(x)=(sin(x))^{-1}[/tex] so b=-1.
Log is the inverse of the exponential e, just like the square root is the inverse of squaring. If we have [tex]y=e^x[/tex] then [tex]x=ln(y)[/tex] such as if we have [tex]y=x^2[/tex] then [tex]x=\sqrt{y}[/tex].
So ln(1)=x, well this is the same as saying [tex]1=e^x[/tex] and for what value of x does [tex]e^x=1[/tex]?
you forgot an important fact
[tex]e^{-ln(x)} = \frac{1}{x}[/tex]
If he/she uses that fact then it explains the rest :)
I did? I showed the OP the two basic rules that he needs and can manipulate those in such a way to get the answer.
[tex]e^{-lnx}=\frac{1}{x}[/tex] isn't so quickly obvious if you're only just starting to learn the rules [tex]e^{lnx}=x[/tex] and [tex]ln(a^b)=b*lna[/tex]
But you can easily get the result by using these rules that they are learning.
Oh well, I am sure that Jedi Hal will find this post and correct us all, but that said
I learned in High School [tex]x^{-1} = \frac{1}{x}[/tex] which implies
[tex]e^{-x} = \frac{1}{e^x}[/tex] thus
[tex]e^{-ln(x)} = \frac{1}{e^{ln(x)}} = \frac{1}{x}[/tex]
Use this property to prove you problem, OP!
Who's Jedi Hal?
Sure, there's lots of ways to do it.
[tex]e^{-ln(x)}=e^{ln(x^{-1})}=x^{-1}=\frac{1}{x}[/tex]
[tex]e^{-ln(x)}=(e^{ln(x)})^{-1}=(x)^{-1}=\frac{1}{x}[/tex]
[tex]e^{-ln(x)}=(e^{-1})^{ln(x)}=\left(\frac{1}{e}\right)^{ln(x)}=\frac{1}{e^{ln(x)}}=\frac{1}{x}[/tex]
