The Origin of Venus's Retrograde Rotation: A Collisional Hypothesis
  • Thread starter Thread starter ion
    Force Nature
The discussion centers on the unique retrograde rotation of Venus, attributed to significant collisions during the planet's formation. Participants highlight that the rotational dynamics of celestial bodies result from a combination of inertia and gravity, with Venus's unusual spin direction likely caused by a massive impact that altered its angular momentum. The conversation also touches on the conservation of angular momentum and how it relates to the initial formation of planets from a gas and dust cloud. Key insights include the role of collisions in shaping planetary rotation and the historical context of solar system formation.
  • Understanding of angular momentum conservation
  • Familiarity with celestial mechanics
  • Knowledge of planetary formation theories
  • Basic concepts of inertia and gravitational forces
  • Research the impact of collisions on planetary rotation dynamics
  • Study the conservation of angular momentum in celestial bodies
  • Explore the formation and evolution of the solar system
  • Investigate the rotational characteristics of other planets, particularly Uranus and its axial tilt
Astronomers, astrophysicists, and students of planetary science will benefit from this discussion, particularly those interested in the dynamics of planetary rotation and the historical processes that shaped our solar system.
ion
A simple question,but to which I can't find a ready answer.
What is the nature of this rotational force that affects all celestial bodies? What was the initial impetus? How does physics explain it?
Thank you,
ion
I think you should try to clarify the term "rotational force". However rotations and revolutions of celestial bodies are in general a combination of inertia and gravity. In some extreme cases (e.g. our moon), the rotation and revolution periods are locked, so we always see the same face.
I know what you mean, I've been trying to figure this out as well.
I've come across this site which details the rotation time of each planet on it's axis plus the revolution time around the sun. The revolution time of each planet is as expects ie it increases the closer a planet is to the sun. Check this site out for exact figures
http://www.marsdenshs.qld.edu.au/subjects/science/junior_science/astro/solar.html
Also another thread that might interest you is
[URL]https://www.physicsforums.com/archive/topic/1689-1.html
Hopefully someone might be able to give us a full explanation. At best I would guess a planets rotation was initiated/set by the rate of impacts on the planets surface during the creation of our solar system.
Silvershadow
... At best I would guess a planets rotation was initiated/set by the rate of impacts on the planets surface during the creation of our solar system.
Silvershadow
The above is very true. Many people's idea of the formation of the solar system is of 9 planets forming simply from a cloud of swirling gas orbiting the Sun. However, the system was much more dynamic than this, with proto planets colliding, enormous collisions with other large masses etc. The rotational period of a planet reflects their development history, as well as, in the case of the Earth, the effect the moon has slowing us down.
Venus was tipped almost upside down in its early history and spins very slowly the opposite way to all the other planets! Uranus is on its side too, due to collisions.
Just out of interest how do astronomers know what the original axis of the planet was?
Silvershadow
Conservation of angular momentum. As the initial gas and dust cloud collapsed, it would have spun faster and faster, in one direction determined by any tiny initial angular momentum. (like an ice skater pulling in her arms)
Venus, or any other planet for that matter, formed by gravitational attraction of particles, in this collapsing swirling mass. It is not possible, for it to have formed from matter with a different orientation of angular momentum than the rest of the Solar system. Hence, it must have been tipped upside down by a huge collision to account for it spinning on it's axis in a different direction to all the other planets.
:smile:
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 19 ·
  • · Replies 21 ·
11K
