Need a better definition of anticlockwise
  • B
  • Thread starter Jonathan212
  • Tags
    Definition
In summary, the orientation of a rotation motion is conventionally defined by left and right hand. There is also a cross product orientation which is defined by left and right hand and the coordinate system is given by the person's position to the experiment.
Jonathan212
198
Dictionary says it is the opposite of clockwise. But if a clock is transparent and you look at it from behind, the same direction that was anticlockwise before is now clockwise. So it seems to depend on the point of view. But there are some electromagnetic equations that depend on clockwise versus anticlockwise. So it is not just a mathematical concept that depends where you're looking at it from, but the universe has it hard-wired in its laws. What would be a more profound definition of anticlockwise?
Mathematics news on Phys.org
You are asking about an orientation in a rotation motion. Hence you will need a coordinate system, especially an angle ##\varphi##. Then ##\varphi \longmapsto e^{i\varphi}## is anticlockwise and ##\varphi \longmapsto e^{-i\varphi}## clockwise.
The coordinate system too is drawn in a certain... wiseness which is by convention. Or is it not by convention but there is a fundamental reason to put the x-axis to the right, the y to the top and the z towards the viewer?
These things are conventions. You cannot distinguish between left and right if you have no orientation. And an orientation is by definition related to something given, the coordinate system.
The cross product orientation is defined by left and right hand. So the coordinate system is given by the person's position to the experiment.
In any case you need a gauge.
Stepping back from clever math, you have 'Faraday's Thumb'. If electrons travel 'thus', the magnetic field wraps 'so'...
Still got to choose a sign convention, though, which is why us kids were bemused by 'Conventional Current'. Which, in turn, had its little joke of showing up as 'holes' in eg NPN silicon devices...
Stepping back even further, an anthropology professor referred to clockwise as "sunwise" (North America). Old lore defines counter-clockwise as "widdershins" (Northern Europe).
IIRC the maps the ancient Greek and Romans used had Africa in the north and the Alps in the south. So from an anthropological point of view ...
Likes Klystron
With the advent of digital clocks I visualize the rotation of the Earth as viewed from the north for counter-clockwise. So, earthwise?
You cannot but nature can apparently. It has laws such that the one that generates the Lorentz force on a particle. This force distinguishes clockwise and counter-clockwise, see #5.
EDIT: or maybe B's direction (towards the north pole) is purely a convention. Introduced by people on the hemisphere where Europe lies. But I'm sure there are other laws that have the cross product in them and they do not apply to arbitrary directions like that of B.
Whether you all a certain orientation clockwise or counter-clockwise, left handed or right handed, left or right, up or down, positive or negative has not the least to do with nature.
Look, there is a law of nature that includes a cross product. Don't you think you should account for it too.
Your thread title has asked for a definition of clockwise. This is a deliberate human name for a certain rotation. A rotation which depends from which side you look at it. There have been several helpful comments given to you.
Nature might have processes which are oriented, but how you call this orientation, and a definition is nothing else, has nothing to do with nature.
I have the impression what you really want to know is, why certain physical quantities behave according to the left hand rule and not the other way around. But this cannot be answered. Have a look at:
Likes Klystron
So if there is a separate civilization on Australia that has not had any contact with us up until the middle ages, and develops its own science where they draw maps upside down (and their campuses point to their version of north, the Antarctic), and they make their clocks run like their version of sunwise, then when this civilization discovers the motion of charged particles in a magnetic field, would they make different predictions for their motion or would they derive the same law but with a negative sign in front of their cross product and that's ok, different cultures different laws of nature?
Jonathan212 said:
... would they make different predictions for their motion ...
No.
... or would they derive the same law but with a negative sign in front of their cross product and that's ok, ...
Yes.
... different cultures different laws of nature?
No.
The same laws, different names, different conventions.
No discussion of "clockwise" is complete without a discussion of nonconservation of parity. I will simply recommend the master Richard Phillips Feynman:
Likes pinball1970
Alright try this. We stick a negative sign in some laws NOT by convention but to say that an opposition takes place, here's one such law:
https://en.wikipedia.org/wiki/Lenz's_law
We don't stick a negative sign wherever convention requires it. Name a law of physics where a negative sign is the result of convention!
Of course this is a convention. Physics won't change if we substituted ##\Phi_B## by ##-\Phi_B##. You simply moved the point of convention to another place.
Lenz law's negative sign is a result of convention? It relates to RATE of change, it would be the same for the hypothetical Australian civilization.
Why is one rate called negative and the other one positive? What's a negative rate for ##\Phi_B## is a positive rate for ##-\Phi_B##.
This thread is running in circles.
Thread closed.
Likes YoungPhysicist and weirdoguy
1. What does "anticlockwise" mean?
"Anticlockwise" refers to the direction of rotation that is opposite to the direction of the hands on a clock. It is also known as counterclockwise or counter-clockwise.
2. How is anticlockwise different from clockwise?
Anticlockwise is the opposite direction of clockwise. While clockwise refers to the direction of rotation of the hands on a clock, anticlockwise refers to the direction of rotation that is against the hands on a clock.
3. In which situations is the term "anticlockwise" commonly used?
The term "anticlockwise" is commonly used in various fields such as physics, mathematics, and navigation to describe the direction of rotation. It is also used in everyday language to give directions or describe movements.
4. Is "anticlockwise" an official term?
Yes, "anticlockwise" is an official term that is widely recognized and used in various scientific and technical contexts. It is also listed in most dictionaries as a valid word.
5. Can you provide an example of an anticlockwise movement?
One example of an anticlockwise movement is the rotation of the Earth around its own axis. Another example is the movement of the blades of a ceiling fan in the opposite direction to the hands on a clock.
  • Calculus
  • STEM Academic Advising
  • Topology and Analysis
13K
  • Mechanics
