Need help identifying correct answers to math questions
  • Topic:
  • Thread starter squexy
4 replies · 2K views · last reply
squexy
  • Multiple-choice geometry problem 38: right triangle KLM with a right angle at L, hypotenuse KM labelled 12 cm, leg ML labelled 10 cm, and answer choices F to K as fractions for sin M.
  • Geometry problem 39: points A, B, C lie on a horizontal line, with D and E on a parallel line above; segments drawn from D and E meet at B. Answer choices A through E listed below.
  • Coordinate plane with a circle centred at (2,3) passing through P(6,6), with answer choices A to E listed at the left: (2, 3), (3, 2), (5,-1), (6, 0), (7, 3).
squexy said:
https://www.physicsforums.com/attachments/2941
Answer: K
38. $$\sin M=\frac{\text{ opposite }}{\text{ hypotenuse }}=\frac{KL}{MK}$$
From the Pythogorean Theorem: $$(KL)^2+(ML)^2=(MK)^2 \Rightarrow (KL)^2=144-100=44 \Rightarrow KL=\sqrt{44}$$
Therefore, $$\sin M=\frac{\sqrt{44}}{12}$$
Prove It said:
What have you tried so far?
37
By estimative I can find the answer, since radius is 5 coordinate units I decrease 5 from Y and add 5 to X having (7,-2) 39
a = b = c3x = 180
x = 60
squexy said:
37
a = b = c3x = 180
x = 60
For 37 I would find the equation of the line passing through your two known points. Then try to find the equation of the normal to this line through the centre of the circle (keep in mind that the gradients of perpendicular lines multiply to give -1). Once you have the equation of this normal you can find where it intersects with the circle, solving your problem.
For 39 I have no idea what you are talking about. What are a, b, c? Are you using these letters to represent the sides of the triangle. If so, how do you know the sides of the triangle are all equal in length?
