- 2,128
- 32
The torsional spring is needed only if a motor drive mechanism is used. In general, you would probably purchase the torsional spring and hinge separately, remove the hinge pin, cut a notch for the torsional spring, then reassemble the parts. But how you do it is up to you. You can use any approach you prefer.
The cable can be attached in any way you prefer, and is relatively easy to attach. How you do it is up to you. The cable does not need to be an exact length. You want the cable to be longer than necessary, so that the cable makes approximately one and a half extra loops around the empty side of the spool when the mechanism is fully extended or contracted.
For the axial force in linkage bar BC, use the maximum linkage bar axial forces listed in post 104, paragraph 4.
