Need help, Why is Matlab not writing to file?
  • Context: MATLAB
  • Thread starter Thread starter captain fink
    File Matlab Writing
1 reply · 3K views
captain fink
clc
clear
f = input('Enter the force applied in lbs: ');
p_c = input('Enter point closest to pivot: ');
p_f = input('Enter point farthest from pivot: ');
filename = input('name of file is: ','s');
points = input(' # of points to calculate: ');
x = [p_c;rand(points,1)*p_f-p_c+p_c;p_f];
y = sort(x);
pos = find(y<p_c);
pos1 = find(y>p_f);
y(pos) = [];
y(pos1) = [];
%disp(y) points
M = y*f;
%disp(M) moment
final = [y,M];
Mo = fopen([filename,'_',f,'_',points,'.txt'], 'w');
%fid = fopen(string, option)
%writing
fprintf(Mo, 'ID:\t%s\nF:\t%2.2f\n point closest:\t%2.3f\n point farthest:\t%2.3f...\n',filename,f,p_c,p_f);
fprintf(Mo, ' points\t moment\n');
fprintf(Mo, '%.2f\t.2f',y,M);
fclose(Mo);
Your thoughts would be helpful because I don't see why this isn't working
The variables f, and points (which are of type double), are used to generate you file name without being converted to string.
Try, using num2str function, for example
Code:
Mo = fopen([filename,'_',num2str(f),'_',num2str(points),'.txt'], 'w');
Also, you might want to have a closer look at:
think, it's missing a % after \t.
