Need help with algebra in proving kinetic energy is not conserved
The discussion revolves around proving that kinetic energy is not conserved in inelastic collisions, utilizing the conservation of momentum. Participants explore the algebraic manipulation of kinetic energy expressions before and after the collision.
  • Some participants propose using the conservation of momentum to derive the final velocity after an inelastic collision.
  • Participants express the need to show that the initial kinetic energy does not equal the final kinetic energy, leading to algebraic expressions that need simplification.
  • One participant suggests examining the expression for differences in kinetic energy and simplifying it to identify conditions under which it is non-zero.
  • Another participant points out potential errors in algebraic manipulations and emphasizes the need for symmetry in the variables involved.
  • There are discussions about the conditions under which the difference in kinetic energy is non-zero, specifically focusing on the velocities of the colliding objects.
  • Some participants note the importance of ensuring that the masses are positive and how this affects the conclusions drawn about kinetic energy differences.
Participants generally agree that kinetic energy is not conserved in inelastic collisions, but there is disagreement on the specific algebraic manipulations and conditions that lead to this conclusion. The discussion remains unresolved regarding the precise formulation and simplification of the expressions involved.
Limitations include unresolved algebraic steps and the dependence on the definitions of kinetic energy and momentum. The discussion highlights the complexity of proving non-conservation of kinetic energy in inelastic collisions.
Obliv
I'm trying to prove that kinetic energy is not conserved in inelastic collisions using the conservation of momentum. This is the set-up. An object A of momentum ##{m_1}{v_1}## collides inelastically with object B of momentum ##{m_2}{v_2}##
using momentum conservation ##P_i = P_f##
{m_1}{v_1} + {m_2}{v_2} = ({m_1}+{m_2}){v_f} solving for ##v_f## we obtain
v_f = \frac{({m_1}{v_1}+{m_2}{v_2})}{({m_1}+{m_2})} now the fun part
prove that KE_i \ne KE_f
\frac{{m_1}{{v_1}^2}}{2} + \frac{{m_2}{{v_2}^2}}{2} \ne \frac{1}{2}({m_1} + {m_2})(\frac{{m_1}{v_1} + {m_2}{v_2}}{{m_1}+{m_2}})^2
I realize that the two quantities are no longer equal, especially if you try plugging in numbers. I was just wondering if this can be simplified to be seen more clearly.
I multiplied out the numerator and denominator and got some pretty nasty algebra.
\frac{{m_1}{{v_1}^2}}{2} + \frac{{m_2}{{v_2}^2}}{2} \ne \frac{1}{2}({m_1}+{m_2})\frac{({m_1}{v_1})^2 + 2{m_1}{v_1}{m_2}{v_2} + ({m_2}{v_2})^2}{{m_1}^2 + 2{m_1}{m_2} + {m_2}^2}
I'll continue working on it later but if anyone has any shortcuts to simplifying this I would appreciate it.
Mathematics news on Phys.org
You could look at the expression $$X=\frac{{m_1}{{v_1}^2}}{2} + \frac{{m_2}{{v_2}^2}}{2} - \frac{1}{2}({m_1} + {m_2})(\frac{{m_1}{v_1} + {m_2}{v_2}}{{m_1}+{m_2}})^2$$
You want to see under what condition ##X \neq 0##.
Simplify the expression by multiplying with ##2(m_1+m_2)##:
You get $$2(m_1+m_2)X=({m_1}{{v_1}^2}+ {m_2}{{v_2}^2})(m_1+m_2) - (m_1v_1+m_2v_2)^2$$
Now work out the RHS.
Okay I continued and got this
2({m_1}+{m_2})X = ({m_1}{v_1}^2+{m_2}{v_2}^2)({m_1}+{m_2}) - ({m_1}{v_1} + {m_2}{v_2})^2
2({m_1}+{m_2})X = ({m_1}{v_1})^2 + {m_1}{m_2}{v_2}^2 + {m_1}{m_2}{v_1}^2 + ({m_2}{v_2})^2 - (({m_1}{v_1})^2 + 2{m_1}{v_1}{m_2}{v_2} + ({m_2}{v_2})^2)
Which simplifies to 2({m_1}+{m_2})X = {m_1}{m_2}{v_2}^2 + {m_1}{m_2}{v_1} - 2{m_1}{v_1}{m_2}{v_2}
and if you take out an ##({m_1}{m_2})##
2({m_1} + {m_2})X = ({m_1}{m_2})({v_2}^2 + {v_1} + 2{v_1}{v_2}) and we can conclude now that ##X \ne 0## when neither ##{m_2} \ne 0 ## nor ##{m_1} \ne 0## or if ##{v_2}^2 + {v_1} + 2{v_1}{v_2} \ne 0##
Is this correct?
Is this correct?
No.
The result has to be symmetric in ##m_1, m_2##, which it is.
But also in ##v_1, v_2##, which your result is not.
Check the term ##{m_1}{m_2}{v_1}## ...
There also is a sign error in your last expression.
I think you can take as given that the masses ##m_1, m_2## are strictly positive numbers.
Samy_A said:
No.
Yes I forgot a power of 2 2({m_1}+{m_2})X = {m_1}{m_2}{v_2}^2 + {m_1}{m_2}{v_1} - 2{m_1}{v_1}{m_2}{v_2} here
2({m_1}+{m_2})X = {m_1}{m_2}{v_2}^2 + {m_1}{m_2}{v_1}^2 - 2{m_1}{v_1}{m_2}{v_2}
and then 2({m_1} + {m_2})X = ({m_1}{m_2})({v_2}^2 + {v_1}^2 - 2{v_1}{v_2})
If this is correct, ##X \ne 0## when either ##{m_1} > 0## or ##{m_2} > 0## as well as if ##{v_2}^2 + {v_1}^2 - 2{v_1}{v_2} \ne 0##
"either ##{m_1} > 0## or ##{m_2} > 0##" is not correct, as the masses are both positive numbers.
For ##X \ne 0##, the condition is ##{v_2}^2 + {v_1}^2 - 2{v_1}{v_2} \ne 0##.
This last expression can be simplified, using the well known identity ##(a-b)²=a²-2ab+b²##.
You then will get a nice condition for ##X \ne 0##, which will make sense if we remember that ##X## is the difference in kinetic energy (before and after the collision).
Samy_A said:
The masses are positive numbers.
So, for ##X \ne 0##, the condition is ##{v_2}^2 + {v_1}^2 - 2{v_1}{v_2} \ne 0##.
so it can be written as 2({m_1} + {m_2})X = ({m_1}{m_2})({v_1}^2 - {v_2}^2) and expressed such that ##X \ne 0## when (##{m_1} > 0## and ##{m_2} > 0##) and ##{v_2} \ne {v_1}##? is this correct or should I go further?
No, this is not totally correct.
From ##2({m_1} + {m_2})X = ({m_1}{m_2})({v_2}^2 + {v_1}^2 - 2{v_1}{v_2})##, you get ##2({m_1} + {m_2})X = {m_1}{m_2}(v_2-v_1)²##,
##(v_2-v_1)²## is not necessarily equal to ##{v_1}^2 - {v_2}^2##.
The conclusion is correct. The kinetic energies will be different when ##(v_2-v_1)² \ne 0##, that is when ##v_1 \ne v_2##.
I was very tired and wrote the tex incorrectly. I meant what you wrote and that's what I had on my scrap paper. Thank you for your guidance :)
You are welcome.
  • · Replies 18 ·
  • · Replies 30 ·
  • · Replies 16 ·
