Auto/Motor How to Calculate the Correct Gear Modulus for a Motorcycle Project?
  • Thread starter Thread starter Kleinelars1
    Gear
Lars is working on a project to create a "paddock starter" for a motorcycle racer using a 12V car starter from a VW T5 transporter 2.5 TDI. He is struggling to find the correct gear to match the starter motor's gear/pinion, having calculated a modulus of 2.3 instead of the expected 2 or 2.5. He provides specific measurements for the starter motor gear, including outer teeth diameter, pitch diameter, axle diameter, height of teeth, and width of teeth. There are suggestions to check the number of teeth on the gear and to measure the flywheel gear from the VW, as small gears may have a profile offset that affects pitch diameter measurements.
Kleinelars1
Hey Guys,
Sorry for my poor englisch, I'am Lars from the Netherlands and currently working on a project. For my motorcycle racer I'm making a "paddock starter" by a 12V car starter from a VW T5 transporter 2.5tdi.
No I am having difficulties finding the right gear to match the current starter motor Gear/pinion. Obviously I tried finding the Modulus, but encountered the problem of receiving a 2.3 as a result, but this sould be 2 or 2.5
So, is there anyone who can help me find the matching gear, or explain how to calculate it properly?
Specs of starter motor gear;
Outer theeth top diameter 27.7mm=1.0905 inch
Pitch diameter 23.7mm=0.9330 inch
Diameter of axle at bottom of the teeth 19.7mm=0.7755inch
Hight of teeth from foot to top 4mm=0.1574
Teeth is 4mm=0.1574 wide at bottom
Hope anyone can help me.
Lars
How many teeth on your gear? How did you measure the pitch diameter?
Small gears (small number of teeth) are sometimes designed with profile offset to make the teeth stronger. If that is the case, the pitch diameter will not be what it looks like. Can you measure the flywheel gear from the VW? Any profile offset will have only a small effect on your measurements.
Hey folks! So I’m kinda losing my mind over my hedgie’s setup lately. No matter what I do, the enclosure keeps getting super humid and it’s starting to smell funky. I clean it, switch bedding, crack the window, the whole nine yards… but it still ends up damp and I’m worried it’s gonna mess with my little dude’s health. I’m starting to feel like I’m doing something wrong even though I’m trying so hard. Has anyone dealt with this before? Any tips, hacks, gear recs… literally anything would...
13K
