Need Help With Identifying My Precipitate, .
  • Thread starter Thread starter justinh8
The discussion focuses on identifying solid Copper Hydroxide produced from the reaction between Copper Sulfate and Sodium Hydroxide. The participant confirms that the solid is Copper Hydroxide after filtering out aqueous Sodium Sulfate. To verify the identity of the solid, it is recommended to observe its color when dry and to conduct tests with ammonia solution and strong acid solution, as these will provide further confirmation of its chemical identity.
  • Copper Sulfate and Sodium Hydroxide chemical reactions
  • Properties of Copper Hydroxide
  • Basic filtration techniques in chemistry
  • Understanding of acid-base reactions
  • Research the color changes of Copper Hydroxide when dry and wet
  • Learn about the reaction of Copper Hydroxide with ammonia solution
  • Investigate the effects of strong acids on Copper Hydroxide
  • Study the process of precipitate filtration and identification techniques
Chemistry students, educators, and laboratory technicians involved in chemical analysis and identification of compounds.
justinh8
Hi, i need some help on how to identify,
I mixed Copper Sulfate solution with Sodium Hydroxide solution to produce solid Copper Hydroxide and aqueous Sodium Sulfate. I than filtered out the aqueous sodium sulfate and was left with solid copper hydroxide. My teacher than asked me to verify that my solid was Copper hydroxide. How can i verify that my solid is Copper Hydroxide?
Please explain and help, Thanks!
Is it pale blue when dry?
if its wet it will react with water and form copper hydroxide which is black.
(I grabbed this from wikipedia)
Drying it won't be easy, I guess you have just a solution containing blue precipitate.
Check what happens when you add an ammonia solution. Check what happens when you add a strong acid solution.
