Need help with two triangle problems
  • Topic:
  • Thread starter Thread starter wailingkoh
    Triangle
9 replies · 4K views
wailingkoh
Mathematics news on Phys.org
If the length of the base and the height of two triangles are equal then their area is equal.
Hi there,
Thanks, how about the other question?
wailingkoh said:
Hi there,
See if the following diagram inspires you...
Find the big tri and subtract?
But I won't be able to find the big tri
Yes, but you do know the base and altitude of the big triangle, based on the diameter of the semi-circle. :D
Hmm, how to find the green part?
- - - Updated - - -
Arr...1/2 *30*18 for the big Triangle. But the green part, what do I do??
- - - Updated - - -
- - - Updated - - -
Arr...1/2 *30*18 for the big Triangle. But the green part, what do I do??[/QUOTE
The small green tri has an arc to it formed by a a semi circle
Take the area of the square, and subtract away the red area of the quarter circle...:D
Awesome! Got it and thanks for the help
I would let $r$ be the radius of the semi-circle, and so the area $A_T$ of the big triangle in my first diagram would be:
$$A_T=\frac{1}{2}(3r)(r)=\frac{3}{2}r^2$$
Now, the green area $A_S$ to be subtracted away is:
$$A_S=r^2-\frac{1}{4}\pi r^2=r^2\left(1-\frac{\pi}{4}\right)$$
And so the area $A$ we are asked to find is:
$$A=A_T-A_S=\frac{3}{2}r^2-r^2\left(1-\frac{\pi}{4}\right)=r^2\left(\frac{1}{2}+\frac{\pi}{4}\right)=\left(\frac{r}{2}\right)^2(2+\pi)$$
Now, we are given $r=9\text{ cm}$, hence:
$$A=\left(\frac{9\text{ cm}}{2}\right)^2(2+\pi)=\frac{81}{4}(2+\pi)\text{ cm}^2$$
