Negative potential energy and negative mass
71 replies · 7K views
Vicara
My question is:
If gravitational potential energy is normally negative, and E=m•c^2, doesen't that means that negative mass could exist?
(I don't know much about general relativity so please explain as simple as posible)
Why do you say gravitational potential energy is normally negative?
Because Ep = -G•M•m/r
Usually you choose the potential being negative, i.e., for a spherically symmetric mass ##M## in the origin of a coordinate system the potential of the force on a test mass ##m## is
$$V(\vec{r})=-\frac{G m M}{r},$$
where ##G## is Newton's gravitational constant. Here masses are always positive.
I've, however no clue, what this might have to do with the rest mass-energy equivalence of special relativity. For a relativistic theory of gravitation you neen general relativity.
No. What it does mean is that a system consisting of two widely separated objects will have a mass very slightly greater than if the same two objects were close together. The difference in mass (multiplied by ##c^2## according to ##E=mc^2##) will be the energy that was needed to move them apart, which is the difference in potential energy between the two configurations.
It's important that we work with the difference between two configurations because potential energy itself is defined that way. It makes no sense to say that the potential is positive or negative until you've specified what you're calling zero. A very common convention is that we call the potential energy zero when the two objects are infinitely distant, and with this convention the potential energy will always be negative.
I think that I'm just mixing concepts that I don't really understand, its just that I learned this formula (before i used Ep = m•g•h ) and the fact that the other formula gives a negative result for energy confused me and I thought that negative mas could be possible by the mass-energy equivalence
Hmmm, that makes sense...
And in the case of maseless particles like photons?
Sorry, you'll have to be more specific about what you're asking.
I mean, if a photon gets closer to a mass, the potential energy will decrease, hence, his mass will decrease too. But it don't have mass, so what will hapend?
E = mc2 is a special case (for a massive body at rest) of the general relation:
E2 = p2c2 + m2c4
For light, m is zero, and energy is related solely to momentum
Also, note that as something moves from higher to lower potential with no other forces acting, its kinetic energy increases. Since the energy of light is pure kinetic energy, this means the locally measured energy of light increases as it approaches a massive body, i.e. it blue shifts.
I do not see how this answers the question. Why is the energy that is needed to move the objects apart always below the total energy of the separated object? As the classical gravitational potential would allow a negative total energy for sufficiently small distances, the question can be answered in the scope of general relativity only.
No matter how far apart I move the objects it will always require the addition of more energy to move them farther apart; so the potential energy at infinity is always greater than the energy at any finite distance, no matter how large. Thus, if you're going to make the (arbitrary, but very convenient) choice to take the energy at infinity to be the zero point, then the potential energy at any finite separation distance must be less than zero. However, we could have taken the zero point of potential to be the minimum when the two objects have approached as closely as possible and compressed, and reshaped themselves under the gravitational forces as they merge. Do this, and the energy will be finite and positive everywhere including in the limit as ##r\rightarrow{\infty}## and whether or not we further offset the zero point by an additional constant ##m_1c^2+m_2c^2## contribution from counting the rest masses.
(And do not fall into the trap of thinking that because ##F=-Gm_1m_2/r^2## blows up as ##r\rightarrow{0}## that the minimum of energy is not a finite number that we can take as the zero point. The infinity here is just telling us that the ideal point particle approximation upon which that formula is based breaks down when ##r## becomes small enough).
This is a digression from the original poster's question, so followup should happen in a new thread in the Classical Physics subforum.
The question remains: Why is there a closest possible approach with a positive total energy?
The original question can't be answered in classical physics because there is no mass-energy equvalence and no lower limit for the gravitational potential.
E2 = p2c2 + m2c4
I´ve seen this formula before, but I don´t understand how light could have momentum or kinetic energy, as both of them include mass in their expressions...
Well, for starters, there is empirical fact: how would a light sail work if light did not have momentum?
For light, momentum is E/c, not anything involving mass.
In SR, kinetic energy is simply total energy minus rest energy. Since light has no rest energy, all of its energy is kinetic. Note that mass, per se, is not involved in this definition.
Summary: for light p = E/c, and KE = E, with E being the total energy of the light.
Vicara said:
?..as both of them include mass in their expressions...
You are thinking of the classical ##p=mv## and ##E_k=mv^2## or the relativistic ##p=\gamma{m_0}v## and ##E_k=(\gamma-1)m_0c^2## which do indeed include the mass. However, these formulas only apply in the special case of particles with non-zero mass and traveling at less than the speed of light, and clearly that doesn't include photons. Do note, however, that the formula @PAllen quoted is equivalent to the two relativistic ones in the ##m_0=0## case.
We also have a FAQ: https://www.physicsforums.com/threads/how-can-light-have-momentum-if-it-has-zero-mass.512541/
So, what i thought that light could have negative energy (or mas, by the mass-energy equivalence) is wrong because light don't have potential energy?
You should note that the choice of sign for the potential energy is really down to convention. You could easily define it as the following:
[tex]V(r) = \frac{GM}{r},[/tex]
such that the force associated with the above potential may be given by the usual
[tex]F = \nabla V(r),[/tex]
which gives the usual gravitational force produced by some body of mass [itex]M[/itex]
[tex]F = -\frac{GM}{r^2}.[/tex]
In relation to it's connection the rest energy in relativity, I think you are confusing the two theories and want to consult the general theory of relativity for a relativistic description of gravity as the other comments suggest.
It doesn't really matter whether light can have potential energy or not. You get to choose what zero potential is, so whether something has positive potential or negative is up to you. Something you get to choose can't have physical consequences.
Then the energy (and the mass) depends of the frame of reference?
Well, I think my math and physics knowledge isn't enough to understand such advanced theories hahahaha
No, they don't. This comes from an utterly flawed picture of photons. There's no other way to adequately describe what a photon is than relativistic quantum field theory, particularly QED in this case.
It's way better to think in terms of classical electrodynamics and electromagnetic fields first, because without some acquaintance with the classical theory, there's no chance to understand QFT. For the classical electromagnetic field (in Heaviside-Lorentz units) with electric and magnetic components ##(\vec{E},\vec{B})## the energy density is given by
$$\epsilon=\frac{1}{2}(\vec{E}^2+\vec{B}^2)$$
and the three-momentum density is
$$\vec{\Pi}=\frac{1}{c} \vec{E} \times \vec{B}.$$
Energy does. Whether mass does or not depends on what you mean by mass. The modern relativistic definition is the modulus of the energy-momentum vector, also known as the rest mass, and this is invariant. Some people do talk about relativistic mass, which is frame dependent, but the concept is falling out of fashion as it causes lots of confusion.
I need to study more physics to understand those beautiful formulas hahahaha
Okey, I will put an example of what I first asked to understand the problem better:
We have two objects, M and m. M have a mass of 10^30 kg and m 10^-6 kg. The distance is 66 m.
The potential energi of m is:
Ep = -G•(10^30)•(10^-6)/66
=-10^14 J
Then, the total energy of m is (I gess):
E = m•c^2+Ep (as kinetic energy is 0)
E = (10^-6)•c^2-10^14 = - 9•10^14 J
The potential energy is a property of the entire system consisting of both masses, so it doesn't make sense to add it to the rest energy of one mass and call that sum the "total energy" of anything. It does make sense to talk about the total energy of the entire system, and it does make sense to call the sum of the rest and kinetic energies of an object its total energy. However, you cannot get the total energy of the system just by adding the total energies of each mass that makes up the system.
Okey, now I see why it doesn't makes sense. I need to study harder hahahaha
Thanks to all the people that helped me :D
Energy is frame-dependent but rest mass (that's how the term "mass" is used today) is not.
=-10^14 J
As Nugatory already explained, Ep it is not the potential energy of m but of the system consisting of m and M. The total energy of this system is
[itex]E = \left( {m + M} \right) \cdot c^2 - G \cdot \frac{{m \cdot M}}{r}[/itex]
As it decreases when the objects get closer, your idea sounds reasonable so far. However, to get a negative total energy the objects would need to get so close that the Newtonian gravitational potential is no longer an acceptable approximation. It needs to be replaced by a relativistic potential energy V (which doesn’t need to be limited to gravity). If I understand correctly then you are asking whether
[itex]E = \left( {m + M} \right) \cdot c^2 + V < 0[/itex]
is possible in general relativity or not. My intuitive answer is No. I guess that the system will collapse to a black hole (which cannot release energy anymore, exept by Hawking radiatiation) before its total energy drops to zero or even below. But I have no idea how to prove it.
=-10^14 J
This is the potential energy of the system, ##m## is the mass of one of the constituents, and ##M## is the mass of the other other constituent.
The total energy is the sum of the rest energy and the kinetic energy, so in a frame of reference where the kinetic energy is zero, the total energy is equal to the rest energy. The rest energy of one of the constituents of your system is ##mc^2##, the rest energy of the other constituent is ##Mc^2##, and the rest energy of the system, as @DrStupid has pointed out, is $$mc^2 + Mc^2 - G \frac{{mM}}{r}.$$
The energy that binds the two constituents together lowers the rest energy of the system. Your mistake was in thinking you have to add the potential energy to the rest energy, but in fact the potential energy is already included in the rest energy term. This is why the total energy is the sum of the kinetic energy and the rest energy.
In another post you mentioned the expression ##mgh##. We often hear this cryptically referred to as the potential energy of ##m##. Actually, it's the potential energy of a system, and one of the constituents of that system is some object of mass ##m##. So, for example, ##m## is the mass of a book and ##mgh## is the potential energy of a system consisting of the book and planet Earth, with ##h## being the height above some arbitrarily chosen height of zero. If you lift the book from the floor to a shelf that's a height ##h## above the floor you've increased the potential energy of the system by ##mgh##. This is true whether you choose your zero of height to be the floor or the shelf or the ceiling.
