Negative radius convention equivalent but not equal?
14 replies · 3K views · last reply
nomadreid
TL;DR
In Wikipedia's description of spherical coordinates, a convention whereby (r,A,B) is equivalent to (-r, -A, pi-B) is presented. It appears that they are not equal, but I guess isomorphic. Wrong?
In
https://en.wikipedia.org/wiki/Spherical_coordinate_system
under the heading
"Unique coordinates"
using the convention (r,P,A) =(radial distance, polar angle, azimuthal angle) ("physicist's convention")
we have
(r,P,A) is equivalent to (-r,-P, π-A).
My three dimensional imagination is horrible, and making a little model out of sticks just ended up in a mess, so I look at the cross-sections:
letting r=5, and either reversing the direction of r then rotating, or vice-versa
letting P=0, then (r,P) ≡(-r,-P)
Diagram of two-dimensional axes with a red ray and a purple ray from the origin, each with a dashed continuation and a green dashed arc; labels -5 on the left axis and 5 on the right.
and letting A=0, (r,A) ≡(-r,π-A)
Two-dimensional coordinate diagram with axes and a dashed green arc marking an angle; a red ray and a purple segment from the origin, with the label −5 on the negative horizontal axis and a 5 near the red ray.
They do not end up at the same place (if I am drawing these correctly), so either I am doing something wrong or what is meant by equivalent is that the systems will be isomorphic, not necessarily equal. However, I would be glad to be corrected.
Thanks for any help.
Another approach. Translation of Cartesian and polar coordinates are
[tex]x=r \sin \theta \cos \phi[/tex]
[tex]y=r \sin \theta \sin \phi[/tex]
[tex]z=r \cos \theta[/tex]
We can observe the transformation you say, i.e.
[tex]r\rightarrow -r,\ \theta\rightarrow -\theta,\ \phi\rightarrow \pi-\phi[/tex]
in RHS would / would not change LHS.
anuttarasammyak, thanks, that simplifies the approach tremendously!
anuttarasammyak said:
Another approach.
My central problem still remains, but now I can state it more succinctly.
Using the conversion above, I get
Three equations of spherical coordinate reflection: x' = -x, y' = y, z' = -z, each derived from substituting r negated, theta negated and phi replaced by pi minus phi.
Unless I have made some mistakes, this again does not end up with the original point. So I remain confused. Where am I going wrong?
we have
It rather says that ##(-r,-\theta,\phi)## is equivalent to ##(r,\theta,\phi)##.
The original quote is: "It is convenient in many contexts to use negative radial distances, the convention being (− r , − θ , φ) , which is equivalent to ( r , θ , φ ) for any r, θ, and φ. ​
Moreover , ( r ,− θ , φ ) is equivalent to ( r , θ , φ + 180° ) ."​
Elsewhere in the article it states "Nota bene: the physics convention is followed in this article;"
That is, where θ is the polar angle, and φ is the azimuthal angle. I have merely replaced θ by P and φ by A as a mnemonic for "polar" and "Azimuth". Then I put the two equivalences:
(− r , − θ , φ)≡( r , θ , φ ) & ( r ,− θ , φ ) ≡ ( r , θ , φ + 180° )
into the single
( r , θ , φ )≡(− r , − θ , 180°- φ), i.e., (− r , − θ , π- φ)
I had hoped that this was clear, but I apologize if it was not. (I also apologize for the bold font at the beginning of my posts; I do not know why that happens and why I can't get rid of it.)
Now, with my notation explained, perhaps it will be easier to find where I am making a mistake? Thanks for the patience.
into the single
Yes, your notation was clear from the beginning. The mistake I see is here: "( r , θ , φ )≡(− r , − θ , 180°- φ)". How do you get this?
You seem all right. We may doubt the description of Wiki.
How about another one
[tex]r \rightarrow -r, \ \theta \rightarrow \pi-\theta, \ \phi\rightarrow \pi+\phi[/tex]
Does it work ?
PS I corrected transformation of ##\phi##.
You seems all right. How about another one, i.e.
[tex]r\rightarrow -r,\ \theta \rightarrow \pi-\theta,\ \phi\rightarrow -\phi[/tex]
I don't see how they get this: "( r , θ , φ )≡(− r , − θ , 180°- φ)" from this: "(− r , − θ , φ)≡( r , θ , φ )".
Thanks, Hill. You are right, I have made some elementary mistakes. Mainly misplaced negativee signs. But I am still a bit at a loss.
My first mistake was to trust this answer:
https://math.stackexchange.com/ques...-r-be-negative-in-spherical-coordinate-system
So, backing up, and using Wiki to put the two together
( r , θ , φ )≡ (− r , θ , φ+π)
But then I still seem to be making mistakes, but I am not sure where:
Three equations: x' = (-r) sin(θ) cos(π + φ) = -r(sin θ)(-cos φ) = x; y' = (-r) sin(θ) sin(π + φ) = y; z' = (-r) cos(θ) = -z.
Thanks, anuttarasammyak. I'm not sure your version works either
Three equations in plain math layout: x' = (-r) sin(θ - π) cos(φ + π) = -r(-sin θ)(-cos φ) = -x; y' = (-r) sin(θ - π) sin(φ + π) = -y; z' = (-r) cos(φ + π) = z.
Changing the sign of [itex]r[/itex] is one sign change; we need to operate on [itex]\theta[/itex] and [itex]\phi[/itex] in order to produce one further sign change in each coordinate.
Consider these two maps:
1. [itex]\alpha \mapsto \alpha + \pi[/itex] is equivalent to [itex](\cos \alpha, \sin \alpha) \mapsto (-\cos \alpha, -\sin \alpha).[/itex]
2. [itex]\alpha \mapsto \pi - \alpha[/itex] is equivalent to [itex](\cos \alpha, \sin \alpha) \mapsto (-\cos \alpha, \sin \alpha)[/itex].
Note that the second maps [itex][0, \pi][/itex] to itself, whereas the first does not. That suggests using the second for [itex]\phi[/itex] and the first for [itex]\theta[/itex]. Hence [tex] (r, \theta, \phi) \mapsto (-r, \theta + \pi, \pi - \phi)[/tex] should fix [itex](r\sin \phi \cos \theta,r \sin \phi \sin \theta,r\cos \phi)[/itex].
I think that both sources you've mentioned are mistaken. It looks to me that the following are equivalent:
##(r,\theta,\phi)=(-r, \pi - \theta,\pi+\phi)=(-r,\pi+\theta,\phi)=(r,-\theta,\pi+\phi)##
Please check.
r→−r, θ→π−θ, ϕ→π+ϕ
Does it work ?
A little explanation. Transformation of angles
[tex]\theta \rightarrow \pi -\theta,\ \phi\rightarrow \pi+\phi[/tex]
make the point on the sphere transffer to the opposite point on the sphere. e.g. North Pole to South Pole.
Regarding it as a vector, multiply -1 to its length brings the point back to the original position.
Out of the four suggestions of Hill and pasmith, I get one which is suitable. The calculations:
Two labelled spherical coordinate calculations, A and B, each mapping (r, θ, φ) to a point with negative r and checking that x′, y′ and z′ reduce back to x, y and z; B is marked yes!
Handwritten calculations checking spherical coordinate points (-r, π+θ, φ) and (r, -θ, π+φ) by converting to Cartesian x, y, z, with each shown to equal the original x, y, z.
So, unless I have made an error in my calculations (always possible), I think I have the solution to my problem. Thanks for all the patience on the part of all!
I think that C is also "yes":
##y'=(-r)sin(\pi +\theta)sin(\phi)=(-r)(-sin(\theta))sin(\phi)=y##.
Oops! Thanks very much, Hill. I don't know how that extra negative got in there. So, wonderful bonus!
