Neutron Generators: Build, Usage, Pictures, Plasma Focus
  • Context: Undergrad
  • Thread starter Thread starter JB Mandengue
    Generators Neutron
The discussion centers on neutron generators, specifically their construction, operation, and types, including the Plasma Focus (PF) Neutron Generator. Participants explore various methods of neutron generation, applications, and visual representations of these devices.
  • Homework-related
  • One participant seeks a simple description of neutron generators, their construction, and operation, as well as images of these devices.
  • Another participant mentions two common methods for neutron generation: the (d+t) reaction and the (alpha, Be) reaction, noting that there are other methods as well.
  • Some participants express familiarity with isotopic sources using the (alpha,n) reaction but seek clarification on the (d+t) reaction, particularly regarding the acceleration of deuterons and the portability of the device.
  • One participant describes the acceleration of deuterons through electrostatic means or by heating a deuterium-tritium gas mixture to create a plasma, discussing the principles of neutron howitzers and fusion confinement methods.
  • Another participant inquires about the power source for the neutron generator, specifically questioning the use of batteries versus high voltage power supplies.
  • A participant shares links to articles and patents that provide schematics and further information on neutron generators and their operation.
  • One participant expresses gratitude for the information received and seeks clarification on how the Plasma Focus fits into the discussion.
  • Another participant notes the application of compact pulsed D-T neutron generators in oil well logging and provides a link to a resource with images.
Participants generally agree on the existence of multiple methods for neutron generation, but there is no consensus on the specifics of the Plasma Focus or the details of the (d+t) reaction and its applications. The discussion remains unresolved regarding the integration of the Plasma Focus into the broader context of neutron generators.
Some participants express uncertainty about the specifics of neutron generator designs and operational principles, particularly regarding the acceleration of deuterons and the role of different power sources. There are also unresolved questions about the classification and functionality of various neutron generator types.
JB Mandengue
a) I need a simple description of how a Neutron Generator is built and how it works.
b) Where can I see a picture of what a Neutron Generator looks like?
c) What is a Plasma Focus (PF) Neutron Generator?
d) Is PF the only type of Neutron Generator or are there other types?
Is this a homework problem?
Two common methods would the (d+t) reaction using accelerated deuterons on a tritiated target, and an (alpha, Be) reaction in which alpha particles from a radionuclide of a Pu, Po or Ra isotope bombard Be nuclei.
There are other methods.
Thanks for the answer. I am familier with isotopic sources using the (alpha,n) reaction. It is the (d+t) you mention that I don't understand. How are the deuterons accelerated? Is he (d+t) a portable devise?
BTW this is not a home work problem.
For the d+t reaction, there are two possibilities. One is to electrostatically accelerate deuterons across a potential difference of a few keV. The deuterons then stike a triton (nuclear of tritium) which could be in the form of a metal hydride. This is the principle of a neutron howitzer.
Another possibility is to heat a mixture of deuterium and tritium gas until is ionizes into a plasma. At sufficient temperature (with a reasonable density) deuterons and tritons will fuse, and in fact one might obtain d+d fusion, with production of He3+n or t+p. This is the principle behind magnetic confinement (low density) and intertial confinement fusion (high density).
The third alternative is a hybrid of the other two, using electrostatic fields to accelerate deuterium/tritium gas into a central confinement volume in the presence of a magnetic field.
Example - http://www.physics.ucla.edu/icnsp/PDF/bromley.pdf
Thanks again. Thanks so much. If I may ask further. Is a battery connected to the Neutron Generator to create the potential difference that accelerates the deuterons? Do you have a picture of one of these devises?
Batteries are not used. Rather high voltage power supplies would be used.
Here is an article with a schematic.
http://fsl.ne.uiuc.edu/IEC/Miley_Radio.Nuc.Chem(2005).pdf
Fusor time arrangement
http://www.absoluteastronomy.com/topics/Inertial_electrostatic_confinement
A patent - Neutron tube comprising an electrostatic ion source
http://www.freepatentsonline.com/5152956.html
Thank you Astronuc. The principle and method of operation is now clear to me. With the drawings you indicated, I can visualize the equipment. I guess the only question left now is how "Plasma Focus" fits into all this.
Thank you Bob. I have just read the thermo article. very informative - especially the simple sketches and the photo which shows exactly how the NG looks.
  • · Replies 20 ·
