Newton's Cooling Temperature formula problem
6 replies · 2K views
Lami
*Given Newton's Cooling formula, where T(t) predicts temperature, and where Te is the temperature of the enviornment, T[0] is the temperature when t = 0:
T(t) = Te + (T[0]+Te)e^-rt
predict Te when
T(120)= 86.632
T(240) = 79.210
r = 0.001
I don't know how to even remotely go about solving this hence the lack of the template. I feel like I'm being overloaded with information. What should be my first steps towards rationalising this?
Lami said:
View attachment 231340 I don't know how to even remotely go about solving this hence the lack of the template. I feel like I'm being overloaded with information. What should be my first steps towards rationalising this?
You are given sufficient information to solve this problem. What would you get if you substituted the first data point into the equation?
T(t) = T[e] + e^-rt (T(0) - T[e])
Where r = -0.001
At T(120) = 86.632
=> 86.632 = T[e] + e^-(-0.001*120) (T[0] - T[e])
86.632 = T[e] + T[0] e^0.12 - T[e]e^0.12
This is why I don't understand what to do because I have no idea how I should even be substituting, or what I should be substituting, into these equations after this point or if I've even went about the right way of doing it.
Lami said:
*Given Newton's Cooling formula, where T(t) predicts temperature, and where Te is the temperature of the environment, T[0] is the temperature when t = 0:
predict Te when
T(120)= 86.632
T(240) = 79.210
r = -0.001
The edited version of Post #1 is much easier to read than the image was. However, there appears to be one item that needs correction. The cooling rate, r, is a positive number. The negative sign is carried in the overall formula.
That should be: ##\ r=0.001##
Where r = -0.001
At T(120) = 86.632
As Sammy points out, using ##e^{-rt}## and ##r = -0.001## is wrong; you want ##e^{-0.001 t}##, so that the temperature will go from ##T_0## towards ##T_e## as time goes on. If you had ##e^{+0.001 t}## the two temperatures would grow farther apart!
Anyway, you have one almost-correct equation containing ##T_e## and ##T_0## obtained from information at ##t=120.## Write a similar equation using information at ##t = 240.## You will then have two equations in two unknowns. Quantities like e^0.12 or e^(-0.12) are just numbers that you calculate before proceeding.
Ray Vickson said:
As Sammy points out, using ##e^{-rt}## and ##r = -0.001## is wrong; that would give you ##e^{.001 t}##, so the temperature would increase to infinity as time goes on!
Anyway, you have one equation containing ##T_e## and ##T_0## obtained from information at ##t=120.## Write a similar equation using information at ##t = 240.##
I was thinking of doing that but I wasn't confident whether I could cancel but I'm now regretting my lack of confidence. Thanks.
Where r = -0.001
At T(120) = 86.632
=> 86.632 = T[e] + e^-(-0.001*120) (T[0] - T[e]) **
As has been pointed out, and you acknowledged, r = (+)0.001.
So, the above equation I marked as (**) becomes:
86.632 = T[e] + e^(−0.001*120) (T[0] − T[e])​
I suggest keeping (T[0] − T[e]) together for the time being. After all, it's just some constant, the same for all values of time, t .
So that equation then becomes:
86.632 = T[e] + (T[0] − T[e]) e^(−0.120)​
As @Ray Vickson says, write the similar equation for time, t = 240 seconds.
