Newton's Interpolation, numerical methods question
3 replies · 10K views · last reply
albema
Can anyone tell me what is the equation for First Order of Newton’s Interpolation?
The one of Interpolation I know is Lagrange’s Interpolation such as
[tex]p(x)= \frac {x-x1}{x0-x1} f(x0) + \frac {x-x0}{x1-x0} f(x1)[/tex]
and so on ...
Thanks in advance
well...
well, i don't have math type on this computer, so you will have to bear with me, but:
the nth term is found by dividing the function evaluated at the n-1th term by the derivative of the function evaluated at the n-1th term and then subtracting that from the nth term.
that's it!
How can you find the nth term by subtracting something from the nth term?
The only Newton Interpolation formula I know is "Newton's divided difference" formula- which does not involve finding derivatives. It's a bit complicated to write out but here is a good explanation from Wolfram:
http://mathworld.wolfram.com/NewtonsForwardDifferenceFormula.html.
As far as "first order" is concerned, it is just f(x)= f(x0)+ (f(x1)- f(x0))(x- x0)/(x1-x0). Which obviously takes on the correct values at x= 0 and x= 1 and linearly interpolates between. If you look closely you will see that it gives exactly the same values as Lagrange's formula: all linear interpolation schemes between two points are the same.
that's it!
good point... should be subtracted from the n-1th term. bad typing on my part! thanks for noticing;-)
