Nginx 500 errors affecting post submissions
- Thread starter Fredrik
- Start date
76 replies · 9K views
- 423
Didn't it start around the time of the style change? Maybe there was some bigger problem around that time. There was one night when I got 500s all the time. Couldn't post for hours, I think. Not entirely sure though. Maybe it was just random and I happened to get a lot in a short time.
Mentor
- 15,828
- 10,716
so the best strategy is to compose your post then copy it to the clipboard and submit. if the 500 occurs you can save it in a file or try again.
- 10,876
- 423
This is what you need to do if you are unable to just wait a few minutes and reload the page. If you can do that, you don't even have to copy the text to the clipboard. Just wait a few minutes, reload the page, and make sure to answer "yes" when you're asked if you want to resubmit the data.jedishrfu said:so the best strategy is to compose your post then copy it to the clipboard and submit. if the 500 occurs you can save it in a file or try again.
Mentor
- 29,217
- 4,650
Have you tried the "back" button? On most browsers it gets you back to the page where you were composing your post, and the content is still there.
- 10,876
- 423
No, you shouldn't go back. You won't find the stuff the stuff you wrote there. Not the latest version of it anyway. (You may find what you typed for the last successful preview, but that won't help if you have made major changes since then, or if what you just tried to do was the first preview). What you should do is to just wait a few minutes and then press the reload button. Then you answer yes when you're asked if you would like to resend the information.
If you made the mistake of going back, you should undo that by going forward again. (Unfortunately I'm not sure if that works. I can't rule out that the message gets lost forever once you press the back button).
Edit: I remembered some of this wrong. I did some experiments to refresh my memory. So see my next post.
Mentor
- 15,828
- 10,716
I've always lost my post completely back button or otherwise. This may be browser dependent. I use Chrome usually and this is what I've experienced.
- 10,876
- 423
Can you try the following experiment? (It could save you some future headaches). Type something in the quick reply field below. Then pull out the network cable or disable your network interface, and then click "go advanced". Wait for the error message to appear. Now insert the cable, or enable the network interface. Wait a few seconds for it to get started. Now press the reload button and confirm that you want to resend the information. This should give you a successful preview of the text you typed.
I just did some experiments like this of my own (using Firefox). When I typed in advanced mode and then failed to preview (because I wasn't connected to the network), the back button actually worked. I did see the stuff I had typed when I went back. However, when I typed the text in the quick reply box, failed to "go advanced", and then went back, the quick reply field was empty. But I could recover the text by going forward again, and confirming that I want to resend the information.
Danger
- 251
If I get an error, I always hit the back arrow and copy, then paste it in later if immediate resubmissions don't work. I'm running Leopard on a MacBook.
- 10,876
- 423
Yes, this seems to work if you were already in advanced mode, but if you were typing in the quick reply box, you will find that there's nothing there to copy. What you can do then is to go forward again, and probably get the same error message. Then you just wait a while, reload the page, and confirm that you want to resend the information.Danger said:If I get an error, I always hit the back arrow and copy, then paste it in later if immediate resubmissions don't work. I'm running Leopard on a MacBook.
Danger
- 251
Fredrik said:if you were typing in the quick reply box
Aha! I've used that only a couple of times in my life. My usual method is to use the "Quote" button.
- 20,002
- 11,122
I believe I have fixed the 500 errors.
Danger
- 251
Greg Bernhardt said:I believe I have fixed the 500 errors.
Good. That's behind us. Now, what about the next 500?
- 20,002
- 11,122
no errors?
- 10,876
- 423
Not for me, but I've been asleep for half of the time since you posted that.
Evo
Staff Emeritus
- 24,114
- 3,277
Just got a database error trying to open "my pf".
Danger
- 251
Fredrik said:Not for me, but I've been asleep for half of the time since you posted that.
So? I've been asleep for the past 3 days and it's not stopping me from posting.
