Nitrate and pH in a Fishlessly-cycled Aquarium
  • Thread starter Thread starter Frank Pike
    Aquarium Ph
1 reply · 2K views
Frank Pike
Prior to introducing livestock, a fishkeeper may establish colonies of nitrosifying and nitrifying bacteria by repeatedly inoculating an aquarium with a solution of ammonia (to simulate the presence of fish). At the end of the process there is a high concentration of nitrate in the water - typically of the order of 80mg/l.
May such a concentration of nitrate lower pH?
[none understood]
And anyway, what kind(s) of nitrate is it? Cations can come only from the virgin water (usually tapwater) in which there is typically a preponderance of calcium and magnesium. Is calcium nitrate more likely than magnesium nitrate? I have read that the former's pH is around 4 or 5 ; while the latter's is around neutral. So if calcium nitrate forms there'll be a heap of extra H+ ions around ...
... which is fine so long as there's sufficient buffer (in the form of bicarbonate) to soak them up. If not, then presumably high nitrate in low-buffered water would indeed tend to acidify? Would nitric acid form?
Or am I on the wrong track altogether?
The only thing I can think of is that oxidation of ammonia can acidify the solution:
NH3 + 2O2 -> HNO3 + H2O
You don't produce calcium or magnesium nitrate, these cations were in water and they are still there, nothing have changed.
